Badger5Monster Motorsport
Results 1 to 10 of 10
    May 2011
    85
    If I paid would anyone want to fit facelift lights to my pre facelift 8l? please
    Just wondering if anyone from Gloucestershire area would like to fit me some facelift lights to my pre facelift a3 I'd pay just that I am not technically minded when it comes to wiring and I can tell I would probably break something, or damage out of frustration.
    brasiliangringo's Avatar
    Mar 2010
    538
    Quote Originally Posted by nealb View Post
    To do it properly, You will need a new slam panel as the pre lift has different fittings for the older headlights. I only know this as had to replace a slam panel on a 2002 a3 and the breaker sent me one from an 07 or pre facelift and the headlights didn't fit into the sockets. I cannot comment on wiring differences, if any.
    Good luck!
    May 2011
    85
    ok screw it I'll do simple FK black projectors haha
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    All you need to do is cut the wing in order for then to fit. There is a wiring guide if you search for it on the forum.
    May 2011
    85
    yea I found it but I'm so untechnically and unspanner skilled, I would break stuff
    Mar 2010
    538
    Do you mean cutting the wing to allow outer edges of lamp to fit ? Sounds like there is quite a lot of scope to bodge that as will all be free hand cutting job if I understand right? What about painting the cut edge of the wing to avoid pealing etc and weathering damage?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    That's right, cut the wing as in here Audifans.net: You are using an invalid IP
    The guy in this thread does spray the cut panel so it doesn't rust which is easy enough but because the light masks it you won't see it.
    Its easy enough to do Neilb, but take your time and do it right, I'm sure you can do it
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,108
    Nice to see my thread from Audifans popping up from time to time
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    May 2011
    85
    great thread there markyboy! and thanks for the encouragement I'm going to think it over and probs steal my step Dad or maybe mates haha
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Quote Originally Posted by 666markyboy View Post
    Its a really good thread, loads of info and in depth too! I've got it saved on my favourites lol!
  1. How easy is it to fit facelift rear light casement to pre-facelift?
    By Jimgrim77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2012, 21:18
  2. Will S3 facelift lower console fit pre-facelift
    By SunnyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2011, 16:28
  3. Will facelift 1 piece headlights fit a pre facelift A3??
    By lexyy_a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2009, 21:23
  4. Is it possible to fit facelift wingmirror covers on pre-facelift mirrors?
    By Blue_Thunder in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2008, 12:54
  5. How easy is it to fit a facelift centre console in a pre-facelift?
    Last Post: 16th August 2007, 13:09
