Monster MotorsportEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Trailing arm bush replacement (s3)
    My car was getting very nervous on the road and started skipping over rough patches /grates ive had this on my old BMW so i knew what it was, the bloody trailing arm bushes....
    So i replaced mine today, not a job for the faint hearted as your stress levels go through the roof, especially when the last guy that 4 wheel aligned my car rounded one of the bolts, the hardest one to get to as well right up in the chassis... i ended up chiselling it off
    20,000 swear words later i was left with this....
    To the untrained eye it does not look to bad....but i put a screwdriver in the middle and it could be turned at least 45 degrees and was as soft as jardos A3...
    So the drilling and cutting began, fairly easy to be honest and then it knocks out at the rear...
    Then the New bush is easily installed after been lubed up...
    Put back together very easy and the difference on the road is like night and day...much more planted
    if you are doing this pull the brake pipe from its holders around the petrol tank before you attempt to move the arm or you will snap the brake pipe, when it is loose there is plenty of play in the brake pipe when dropping the arm
    now got to pay another arm and a leg to get it 4WA again...ah well the joys of motoring eh....
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I really must do mine to be fair, mine is starting get a get nervous as time goes on. The winter not helping matters but I suspect that this will be the lead cause...
    Homer Simpson
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Nice one dave. I shouldve drilled mine but, mine looked totally fine.
    Doubt il get mine done before alignment on wednesday
    How long it take you?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Well with seize/rounded bolt about 5 *** hours... I would get yours done Karl, the rubber looked ok but had totally gone soft, not a nice job but the end results def outweigh....
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Deffo worth doing then.
    I need to do mine to as it wanders around especially on motorway ruts etc.
    It's much easier to fit the powerflex over the OEM for sure
    "As soft as........... .." LMAO
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    il pull my finger out then.....
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Welly yours is getting nervous because it never knows what turbo it's got in it.....lmfao..
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    Thanks Dave! Something else to do
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Can't say how much the rears helped directly on mine as done the whole car and arbs at the same time but it certinally tightened things up a lot
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Sep 2010
    498
    Trying not to sound too daft but how can you tell if this needs replacing?
    Chugger
    North Devon
    2,716
    This:
    57 A3 2.0 TDI Sportback (140)
    brasiliangringo's Avatar
    Mar 2010
    544
    Do you think most +90k s3s would need this doing ?
    Also, are any of you able to comment on the control arm bushes - are these fairly hard wearing on an s3 or also likely to need doing at the same sort of time on a high mileage car? Suppose its a hard question as depends how its been driven..
    Westy's Avatar
    Dec 2008
    17,281
    I had a look at this bush when I was under my car tonight and it looks like a royal pita to get the bolt out! The bolts look super rusty and will probably round off. Deep joy!
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by brasiliangringo View Post
    How does your car feel on the road? if it seems ok you should be ok but at 90+k they have had a good innings anyway, not the most pleasureable job, but once there done they should see the twilight years out nicely...
    Mar 2010
    544
    Thanks, i havent got one yet!! Just doing my homework.. Already lining myself up for a golden oldy..
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Holy thread revival!
    s3dave - did you polybush this or go with an OE bush?
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Powerflex mate...
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    All still well 12 months on?
    > S3 225 (03) - OEM+
    View: My S3 diary
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yes mate, and its had stick, very worthwhile,....
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    this along with my top mounts and anti roll bar bushes is next on my list. all powerflex.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I've just polybushed mine before Xmas....
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Thanks chaps
    > S3 225 (03) - OEM+
    View: My S3 diary
    Sep 2011
    Scotland Dumbarton
    246
    Just try'd to do mine there, when undoing the trailing arm bolt instead of the bolt coming out its just pulled the metal collar right through the Center of the old bush, think the bolt has corroded with the metal collar, any tips? Lol
    Noggy blue Bam engined S3. Complete with cr turbos stg4 turbo, xspower mani, dp and sports cat, rifle drilled IE rods, 550 injectors, forge 007, badger5 v2 tip, jetex with heatshield, wellycooler, catch can, weitec lowered shocks +springs, 15mm front 20mm back spacers, rtech custom map
    304bhp 290lbsft wmi soon to be fitted along with 986 brembo fronts!
    Feb 2012
    bedfordshire
    751
    Prob better of getting a new bolt mate for both sides, you got a TPS near you ?
    Sep 2011
    Scotland Dumbarton
    246
    I've got one near enough, but its getting the old one out....it's stuck solid to the metal insert inside the trailing arm bracket.
    Sep 2011
    Scotland Dumbarton
    246
    Any one got any ideas with this sleeve and bolt issue?
  28. #27
    May 2012
    RETFORD, NOTTS
    1,753
    Do you have a photo?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  29. #28
    Sep 2011
    Scotland Dumbarton
    246
    I don't mate ATM the picture s3dave has at the top of the page gives you an idea, it's the metal sleeve in the Center that's turning when you try to loosen the bolt that attaches it to the trailing arm bracket. I've try'd a punch from the nut side to try an push it through the sleeve but its not budging.
  30. #29
    Sep 2011
    Scotland Dumbarton
    246
    photo.jpgwell finally managaed to get my drivers side bush done this is what was causing the issue, the bolt is completly solid inside the bush sleeve, had to drill and cut about 10mm of the bush and also cut the head off the bolt in order to get it free from the trailing arm bracket. for reference the bolt is an M12x1.5x80mm just going to order some instead of going through the dealer.
  31. #30
    132
    Screws like that are often pretty cheap from the dealer or tps (a pound or two) and the nuts are cheaper, probably cheaper than ordering from a engineers suppliers or hardware place as a lot don't carry that pitch in M12. You know you're getting the right grade and the plating is normally more durable too.
  32. #31
    Erf
    Oct 2006
    Kingston
    234
    Can I just check wish part you guys ordered? Was it this? Audi S3 Mk1 99 03 Quattro Rear Trailing arm to chassis bush | eBay
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
  33. #32
    Feb 2012
    bedfordshire
    751
    Looks good to me, great mod to
  34. #33
    Erf
    Oct 2006
    Kingston
    234
    Anyone know what the equivalent oem part number is by any chance?
  35. #34
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Quote Originally Posted by sandwich1987 View Post
    bush done this is what was causing the issue, the bolt is completly solid inside the bush sleeve....
    Well what a fag of a job this is! I'm working through installing my new suspension bits and I'm having this exact problem, bush collar sized directly to the bolt.
    Sandwich - what did you cut it out with in the end?
    > S3 225 (03) - OEM+
    View: My S3 diary
  36. #35
    Sep 2011
    Scotland Dumbarton
    246
    Quote Originally Posted by [Dave B] View Post
    In the picture the threads at the top were covered by the rest of the Bush, I just drilled about 6 holes all around the outside and chiseled off the rest. After cutting the head of the bolt off this gave me enough room to drop it out off the bracket, was a complete bar steward!!!
  37. #36
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    ...was a complete bar steward!!!
    AMEN to that! I managed to get the drivers side one out last night, I've yet to see if the passenger side one has seized as well. Had both sides of yours seized?
    > S3 225 (03) - OEM+
    View: My S3 diary
  38. #37
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    see im half heartedly deciding whether to attempt this tonight after ive done my coilovers :/ the job looks straight forward, but I guess its really not haha.
  39. #38
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    It's straightforward IF the bush collar isn't seized to the bolt. If it is seized to the bolt then I'd advise taking it to a garage and paying someone else to get pissed off with it!
    > S3 225 (03) - OEM+
    View: My S3 diary
  40. #39
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
  41. #40
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Theyre both the right ones alex. God knows why the superpro are so expensive.
    I have the powerflex one myself
  1. Passenger side, Rear trailing arm & hub assy
    By hank3944 in forum For Sale/Wanted - Audi Parts
    Last Post: 27th May 2011, 17:16
  2. Rear Lower Trailing/ Radius Arm possibly bent? Is it possible?
    By absolutes3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2011, 17:39
  3. rear trail arm bush
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th June 2010, 14:05
  4. LCR Trailing Arm Bushes
    By Dubturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2009, 15:18
  5. rear trailing arm bush part number query
    By s3_kev in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2008, 21:20
