Monster MotorsportVolks Autos
Results 1 to 9 of 9
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    How do I fit an oil temp gauge?
    Hi all!
    How would I fit an oil temperature gauge to my S3 8L APY?
    I need to know where I would put the sensor or where I would get the reading.
    Hope you can help
    Ben
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    put a sensor in the oil drain plug. adapter is about £5 from ebay. and just buy a external gauge for the readings
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Thanks for the reply.
    And will the oil drain plug sensor set-up be ok? I've heard mixed reviews about these.
    I've ordered the Gauge and it comes with a "Fitting Kit" so I'm guessing I'll need the sump plug with a certain thread in it that matches the kit?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    The oil drain plugs for these sensors are quite frankly an pile of sh*te
    Stick it in the top of the oil filter housing or tee it into where the oil pressure sensor is...
    All the cars I have seen that have these things leak or have rounded the stupid brass or aluminium POS adaptor nut so you can't get them out to change the oil..
    <tuffty/>
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    i didn't have one problem with the sensor being in my sump. i've still got the sensor and adapter in now (taken the gauge out to fit a wideband AFR gauge instead)
    i've done 2 oil changes having the sensor didn't cause a problem (oil change every 6 months)
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Ok, mixed views there lol the kit I've bought has a 1/8 NPT threaded sensor included (which is M10 I believe) is there ANYWHERE on the engine, oil filter housing or sump where I can just bolt this straight in?
    If not, what size sump plug adaptor will I need? Is it M14 x 1.5?
    Cheers in advance!
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Anyone? I'm going to have a look tomorrow, but would love for someone to save me a job hahaCheers
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    the sump plug is m14x1.5
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Nice one! Thanks very much
  1. Fitting an oil pressure / oil temp and boost gauge...
    By JonBoi21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2013, 00:14
  2. Would like to fit an oil pressure gauge...
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2011, 10:56
  3. oil temp gauge not reading any ideas
    By pirate in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2011, 20:12
  4. oil temp gauge
    By marks-krazy-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2010, 09:43
  5. oil temp gauge
    By jimya4t in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th April 2007, 19:27
