Monster MotorsportChris Nott
Results 1 to 10 of 10
    imported_gek
    Air Bag Warning Light
    Hi All
    Had a 2 to 1 alarm upgrade done yesterday and since I picked it up the Air Bag warning light on the dash and the passenger light above my head are both on.
    Vag com reports the following:
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8L0 959 655 J
    Component and/or Version: Airbag Front+Seite 5008
    Software Coding: 01104
    Work Shop Code: WSC 01236
    1 Fault Found:
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    30-00 - Open or Short to B+
    Any ideas? The car is still under warranty but I'm thinking Audi might blame the alarm installer. Should having an after market alarm effect the warranty?
    Little_Si's Avatar
    UK
    64
    Re: Air Bag Warning Light
    Sounds to me as if the person fitting it has removed the glovebox and not reconnected the airbag disable switch when putting it back together.
    imported_gek
    Is that something I can check myself or is it a bugger to remove the glovebox?
    Little_Si's Avatar
    UK
    64
    Should be able to do it yourself.
    There are a few screws, most of which are abvious. I'll have a look later when I get home for the exact screw (torx headed) locations.
    imported_gek
    Thanks Si
    Also, out of interest, what do all the little buttons do behind the enable/disable airbag keyhole?
    imported_gek
    and another question....!!
    Having done some more digging, I've read some threads where they say the passenger airbag can be reconnected, but the light remains on, and needs to be reset.
    Anyone know whether this is something I can do with vag.com or is it a dealer only thing?
    Khufu's Avatar
    West coast of Scotland
    5,693
    it can be done with vag-com. mine doesnt have the key hole must be due to being a 1998 model
    imported_gek
    [ QUOTE ]
    [/ QUOTE ]
    Is there more to it than clearing the fault code as that does not do anything.
    The fault just reoccurs when I switch the ignition off and on.
    Little_Si's Avatar
    UK
    64
    Here's some instructions how to remove the glovebox. You can at leat confirm whether the switch is connected or not.
    Click HERE
    Si
    Oct 2007
    20
    passenger air bag light
    Hi I have just brought an a3 1.9 tdi 110 sport, and I have only just noticed that the passenger air bag light comes on, I have tried switchin it on and off to see weather it makes a difference but it doesn't. Could any body help me with this please
