MURRAYS444
Just a quick question mine is needing replaced and my garage have advised me it will take 3 hours I thought it was a simple job or am i wrong!
Its a good few hours, have to remove all pipes that prevent the rocker cover coming off. Charge pipes, coil packs and associated wiring. Then cover off and compress the tensioner slowly and fiddle the gasket out and replace that and the half moon seal.
And reverse proceedure to assemble etc
Easier way doesn't even require moving the cams or chain mate so don't worry about it.
Once the rocker cover is off and you can get to two torx bolts on top of the chain tensioner. You unscrew these and then you will need a mate (can be done on your own but more fiddly) to press down on the tensioner piston and you can then lift up the top o the tensioner just enough to slide out the old gasket and get the new one in.
It's still a bit of a fiddly job even with 2 of you but it saves having to mess with the cams and chain.
I think I'll use the tensioner all the same.
I know that I need sealant on the 90 deg points and the half moon insert.
Do I need sealant on either side of the tensioner gasket?
Are there any diagrams showing where exactly to put the sealant.
What's safest, be liberal or conservative with the sealant?
How long should I give the sealant to cure?
Thanks. Liam
from what i could see from the one i did the blue parts on the gasket are wee pockets of sealant, once torqued down they pop and fill where needed.
i used the tensioner tool and put the car in gear and rolled it forward slightly which slackened the chain a bit more and i could get plenty of room to replace the gasket. mine hasnt leaked since then.
when using the tool make sure you screw it down slowly as the tool may break if you animal it
Do you fancy doing mine for some money mate???
