Chris NottMonster Motorsport
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Temp guage
    Jun 2007
    Darwen, Lancashire
    40
    Temp guage
    Hello,
    Just recently (about a week or so now), my temp guage isn't going up and the electronic reading is not going above 60. Hover between 50-60. Only when the car is idle will it sneek up above 60. Even the coolant is not getting boiling hot (so to speak).
    Had thermostat and temp sensor changed last spring. Can't figure out what could be wrong? Anti-Freeze leak perhaps..drip by drip...I dunno.
    Would this affect fuel consumption?
    Your help would be appreciated pls.
    Many thanks.
    P.S Tyres are inflated just in case..
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,474
    its either your CTS or stat again
    do you get good heat ? if so its the CTS
    did you buy oem or cheap tat ?
    failed CTS can affect fuel consumption
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,555
    ...and another one!!! LOL
    Sorry bud, this question has been asked so many times in the past few weeks its unreal...
    Its your CTS if you have changed the stat... seeing as you have asked the question about fuel consumption I would assume yours has got worse... the answer is yes, if the ECU is only seeing 60degs water temp it still thinks its in cold start and will use more fuel (like old skool chokes)
    Welcome to ASN :D
    <tuffty/>
    New2Audi likes this.
    Jun 2007
    Darwen, Lancashire
    40
    Whats CTS? Where does it go?
    Heats coming out ok. Bought the stat from local motor shop.
    Jun 2007
    Darwen, Lancashire
    40
    bit of HTML or XML going on there <tuffty/>!
    Sorry, yeh just read other posts also. Others problems are looking like failed stat.
    Need it getting looked at before getting stat, if thats the case or CTS (whatever that is)...
    bez101's Avatar
    Jul 2008
    8,474
    coolant temp sensor
    easy to fit
    get it from audi not much ££££
    on the right as you look at it from the front plugged into one of the coolant hoses above the gearbox,
    Jun 2007
    Darwen, Lancashire
    40
    Could that have failed already when it was only fitted in May?! :-/ Stat was fitted in April..
    bez101's Avatar
    Jul 2008
    8,474
    yep they can
    and if it was an aftermarket 1 they always fail quick
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,555
    The CTS (coolant temp sensor) contains two sensors... one for the dash and one for the ECU... first signs of the CTS going can be jittery engine temp gauge or it suddenly drop from 90 to 60 or something...
    Difficult to say when it could have gone but cheaper pattern parts are known to fail quickly... that said I have had a CTS and stat from GSF in mine for years...
    <tuffty/>
    Jun 2007
    Darwen, Lancashire
    40
    it was brand new..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,555
    They usually are
    Doesn't mean alot tbh...
    <tuffty/>
    Darren4's Avatar
    Feb 2009
    Surrey
    186
    Only buy genuine OEM CTS, stat etc because at least you'll have a guarantee to fall back on.
    Thin we need a sticky for the CTS stat etc, as it will save a lot of double threads lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,555
    Quote Originally Posted by Darren4 View Post
    It won't stop them coming tbh... nobody seems to read them lol...
    <tuffty/>
    Jul 2011
    169
    i have changed the stat on mine and temp sensor, the temp gauge use to occassionally worm but dones even register now
    The weapon of choice... The a3
  1. Temp Guage not working - coolant temp sensor changed... now what?
    By car4kids in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2012, 19:10
  2. Temp guage fluctuation
    By alibob in forum Diesel forum
    Last Post: 20th April 2008, 03:38
  3. water temp guage
    By fenian672000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2007, 14:16
  4. Wierd temp guage
    By neil20vt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2006, 11:44
  5. Temp Guage
    By necroeire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2006, 09:57
