JMB RetrofitsAH Fabrications
Results 1 to 23 of 23
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    how have you mounted your fmic?
    May sound like a silly question but want to know how you guys have done it. I've got a toyo fmic as it should be enough cooling for stage 2. I thought about cutting the crash bar, to fit the cooler behind it or should I just mount it on the bottom if the c bar? Opinions welcome
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    I assume you have read the massive FMIC thread linked too in the stickies? loads of pics of them being fitted in there including eBay coolers etc...
    <tuffty/>
    S3 Paul's Avatar
    Oct 2006
    2,764
    I trim'd my crash rail then used a flat alloy plate bolted to the top of the cooler then bolted to the crash rail... allowing me to set the height with spacers, This was because i didnt have people local that could tig weld me brackets directly to the cooler.
    Works for me and its a fit and forget set up
    Noggy Blue 2001 S3
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    Every time I got into a thread to point someone towards the stickies Tuffty has already beaten me to it!
    Anyway, check the FMIC thread mate. Also I can't see any other way of fitting the toyo cooler in without cutting the crash bar.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Just looking for you opinions and yes I have read that fmic thread. I wanted to fit it behind the bumper if possible. I have 2 silicone elbows which I will put on each side of the intercooler to try tidy up the install
    Word!!!
    Westy's Avatar
    Dec 2008
    17,281
    Quote Originally Posted by Paradox1 View Post
    So far the only way anyone has been able to get the toyo to fit behind the bumper with keeping the fog lights was to turn the cooler upside down and have custom welder pipes onto the end tanks.
    What's your thinking at the moment?
    S3 Build Thread
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    It's going on my mk4 golf so no need to worry about fogs,would just like it to look subtle as possible. As I have no welding equipment, Im thinking if I cut half of the intercooler to throttle body pipe and pull a silicone hose from that pipe to the intercooler, it should make a cleaner fit. I will update on Saturday and leg you know how it goes
    Word!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Ah... all bets are off mate then... not gonna be easy to advise due to bumper shape and other such differences... can't compare fitments easily despite being the same chassis...
    <tuffty/>
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    yay its a golf forum YAY
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    The principles of fitting maybe more like the A3 I guess as they share the same sorta pipework but as for clearances and issues with routing pipework the shape of the bumper will dictate that and that something no one here could help with unless they have owned a Mk4 Golf before really...
    Just gonna be a case of fit and measure... thats how I went about designing the 2 x AH Fabs ones I did for the S3...
    <tuffty/>
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Sorry, should have mentioned its for a mk4 golf earlier. Tuffty, I know exactly what you mean as the golf bumper has a curve on the lower end. I've got. Angle grinder so im sure ill be putting that to use for the best fit. I don't think it will be done in a day though,I feel it will be more of a work in progress. I'll post pictures up on Saturday
    Word!!!
    Westy's Avatar
    Dec 2008
    17,281
    Yeah dont try to get it done in a day or you'll rush parts of the installation. Mine took maybe a week of on/off tweaking and cutting to get it right. The bumper has been off a LOT
    S3 Build Thread
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Loool I'm looking forward to it lol, the fitting of the pipework will be fine, its just im very picky of how things look so will be chopping my bumper here and there for a while. I've sprayed the pipes black aswell so even if they don't fit behind the grilles it should still be fairly hidden.....I hope
    Word!!!
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    this is how i fitted my Toyo cooler
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    if you got the same Toyo cooler kit as me the pipes stick miles outside the bumper. had to hack it up alot to make it fit behind the bumper
    i got so bored in the end i just ended up cutting the whole plastic grille out.
    when sprayed matt black its a bit more hidden
    but if you cut the pipes and keep playing then you can make it fit behind, spray it black and its hidden away
    Dec 2011
    16
    ^^^^^^ have you got any pics of cut down pipes etc???? I notice youve lost the fog lights, id personally like to keep mine, will that just mean getting custom pipe work made???
    mines for an AUM ko3s setup
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    mine never had fog lights mate. i've got a new bottom bit which has the fog light holes that i am using for air intakes.
    i'm going to start getting custom pipes made to take out the joins (less places to leak) and i want to keep a OEM engine bay
    the cold side.
    i'm using the standard intercooler to TB pipe
    in the red is a straight piece of silicone cut to length
    in blue in the pipe cut up to fit behind the bumper
    this is what it looked like before
    hot side
    is red is the 180 degree bend pipe which i cut bits off until fits behind the bumper
    i bought a 1 metre black straight silicone off ebay to make my own joiners
    Dec 2011
    16
    thank you for that =D did the A3 come with grills without fog lights then??? dont like to have big holes where there shouldnt be, ill have to have a look behind mine before doing this, see what i can do but this is a great help
    stumpy83's Avatar
    one legged wonder
    Dec 2011
    Plymouth
    90
    Jay do you have an agu engine if so what route did you take the piping please in bay??
    Audi A3 1.8T Auto few mods lined up but looking to clean up first few bits still needed.
    FRONT FACELIFT HEAD LIGHTS - FRONT ASHTRAY - SEAT RAIL PLASTICS -
    BATTERY COVER AND BOTTLE COVERS
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Thanks for the pictures jay,will let you know how sucessful am I lol
    Word!!!
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by stumpy83:1497852
    As its a agu Ll the pipes go in.the same route,if you have a AUM you need to weld a flange for the map sensor(throttle body side) and weld another 6mm hose for the n75 hose to join to.
    Word!!!
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    yeah i got the AGU lump
    heres my bay pipes
    i normally keep the engine cover on, but its off in this photo
    i want to get them hidden to keep the OEM looks but for now it all works
    Customboy's Avatar
    Jan 2012
    SE London
    836
    I just had my forge fmic fitted today but my intercooler was slightly different as both outlets of the intercooler was on one side, it took over a week of trial and error but have included all pics I have below plus I did cut small bits from my crash bar and inside plastic edges and bumper hope these help
    My intercooler
    Fitted using custom brackets
    Now trial and error for pipe work
    Pipes that where ordered
    Now fitted sorry I know they are not great but just went out and took them a hour ago
    Now finished product and without hacking to much from the bumper
    Hope it helps
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
  1. Front Mounted Intercooler
    By ross_broughton in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2010, 11:29
  2. FMIC- calling all a3s/s3s with FMIC
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 15:00
  3. Front mounted intercooler
    By dribz-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2009, 13:38
  4. Floor mounted excelerator
    By phantom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2008, 20:14
  5. AndyMac stealth sub mounted :-)
    By olekvi in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2005, 17:09
