AH FabricationsVolks Autos
Results 1 to 9 of 9
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    Chesterfield, Derbyshire, United Kingdom
    612
    Charge cooler VS Fmic
    Just wondering if anybody here has evr fitted one to there 1.8t and has there ever been any tests done? Looks like a realy good idea to me and they run this setup on the celica st185 back in the day which ran 300bhp (group A rally car). The plus sides are you could place this where the battery now sits and keep the pipe work as short as possible which is always a plus.
    anyway if you have no idea what a charge cooler is or you think of somthing negative to say please check out this website which should exsplain everything to you. Technical : AVT | www.chargecooler.co.uk | The UKs Leading Chargecooling Specialist, drag and race PWR Barrel Chargecoolers, charge cooler radiators, chargecooler tanks, chargecooler pumps, chargecooler pump, pipe kits, charge cooler accessories, 400
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    This is the setup im going on my k04 conversion unless anyone can persuade me not to lol. Here is a pic of what they look like plumbed in.
    S3 Paul's Avatar
    Oct 2006
    2,764
    Ive never seen one on a VAG car but a lad i know with a mad Focus RS was planning on using one... but then decided an efficient and well placed/ thought out FMIC set up would be a better bet.
    Noggy Blue 2001 S3
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Didn't b5 use one on his hybrid plus before he got a fmic for it?
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Chugger
    North Devon
    2,716
    charge coolers are only as good as the system cooling them...
    there great for drag racing or if you have no space to route IC pipework, but if you have the space, Front mountied cooler is far better.
    57 A3 2.0 TDI Sportback (140)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,595
    Quote Originally Posted by Paradox1 View Post
    The Lupo used to run one on its K03s but proved too much for the K03 hybrid plus...
    Water is a better heat exchanger than air but there are so many decent FMIC solutions now for out cars its hardly worth the effort...
    A decent charge cooler would work but would take up a lot of space then there is the plumbing and charge coolers still use a radiator to help cool the water...
    <tuffty/>
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Its all down to the size of the cooler, and the size of the radiator cooling the water for the cooler.
    Typically they're used when space is at a premium and that ends up meaning the cooler itself ends up too small, and the cooler for the cooler ends up inadequate too.
    The cooler in the photos above looks smaller than the standard side mount intercooler!
    TD5 Land Rover Defender build
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    442
    Quote Originally Posted by S3 Paul View Post
    The Mk1 focus RS uses a charger cooler as standard, my mate was running a healthy 370 break using the standard cooler with no troubles. . . Not sure bout the MK2 RS tho
    AGU-TURBO. That charger cooler set up does look f*kcool tho! could be worth the hassle just to have something different to look at when you pop the bonnet
    Jul 2012
    Guildford
    97
    Sorry to bump an old thread, I was searching for charge coolers on S4's and it seams no one in the world has ever tried it! That charge cooler core in the picture is the exact same one I have for my MR2, rated to 600bhp. Thats another reason for a charge cooler, when the airflow to the engine is no good (because its in the back!) you can pipe the water to wherever you need it to be cooled.
    With Air to Air you have to let the ehat transfer from the intake air to the metal of the cooler, air to metal is very good heat transfer but then you have to cool the outside of the intercooler with air, metal to air is very bad. With a CC you go (intake) Air to metal = good, metal to water also good then in the radiator water to metal and then metal to air. This is why the charge cooler core itself can be much smaller but the radiator needs to be bigger. CC's also take longer to heat soak and then longer to recover after ehat soak.
  1. AGU Charge pipe and charge pipe to pancake pipe hose
    By Steveo_A3_1.8t in forum For Sale/Wanted - Audi Parts
    Last Post: 20th December 2011, 20:59
  2. Parking charge
    By waring192 in forum General Automotive Chat
    Last Post: 11th May 2010, 23:56
  3. S3 charge pipe
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2010, 17:31
  4. How much should i charge ??
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2008, 19:03
  5. S3 Charge Pipe
    By S3_Jack in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2007, 14:17
