Volks AutosSky Insurance
    Feb 2012
    70
    Changing the coolant tomorrow, where do I drain the block?
    I've had a search and have found there is a drain on the bottom of the rad this is all well and good, but where do I drain the block? A picture would be handy if anyone has one floating about.
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    The tap is at the lowest point in the system so aslong as you remove the header tank cap then you should get "most" of it out. The only other option beyond this is to remove hoses, namely the bottom pipe which goes from the thermostat housing to the tap, but its a pita and not worth it. You could flush the system to ensure all the old coolant is out but i just empty, then mix a fresh batch up and refill
    beachbuggy's Avatar
    Surrey
    1,746
    Lowest point on the block is the turbo coolant drain. You can drain most out by the rad drain and then running then engine for a short while to pump the rest out but you have to be mindful of the lack Coolant. To be honest I don't think you'll ever get it all out as some will remain in the heater matrix, pipe work and other bits. just make sure you use g12 or your rust the block and hg.
    Feb 2012
    70
    Brill. It's just the standard G12 from Audi? Because I've been seeing types like G12 ++ etc crop up.
    beachbuggy's Avatar
    Surrey
    1,746
    Yeah g12 plus plus is just the latest version. New and improved.
  1. Engine coolant block attachment.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2012, 09:53
  2. Coolant Drain Tap Assembly.
    By mcglynn in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2011, 08:24
  3. coolant / water leak - pipe to block
    By TeKnodriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2011, 15:03
  4. Necessary to drain the coolant system when changing thermostat?
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2010, 13:25
  5. Advice on changing brake fluid reservoir- how to drain?
    By Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st October 2009, 18:55
