Monster MotorsportChris Nott
    Aug 2011
    Plymouth
    604
    Add Lavis89 on Facebook
    Grinding whilst turning (lots of detail)
    Car: 2002 1.8T quattro sport.
    I've had this problem for a while now, not really sure what is causing it. the jist of it is im getting a grinding noise when i am full left lock and moving, the noise only happens if i touch the acelerator though, if i coast on full lock then i dont have a problem. that for me would rule out any c/v problems (and all the boots are intact aswell), as far as i know if a wheel bearing is on its way then it will grind whilst going straight aswell, i've replaced the bottom mount on the engine which didn't help. from inside the car the noise sounds like it is coming from the rear left side.
    would it be worth replacing the top mounts aswell? and would i need to get the car on ramps to do so?
    and any other suggestions would be welcomed aswell. im a bit lost :/ i've had all the "doughnuts" checked and they are all in good condition.
    and is it worth paying out a bit extra for powerflex mounts if i do need to replace them?
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    When was your last Haldex oil and filter change?
    Dan
    Aug 2011
    Plymouth
    604
    i've only had the car for 6 months or so, it does have quite a bit of service history though so i'll have to check when im in work
    Aug 2011
    Plymouth
    604
    right a bit more info here, i took it on a good 200 mile round trip at the end of last week and the grinding is still there when acelerating out of a corner but alot less loud and less vibration. i checked the service history and nothing is mentioned about haldex oil, there is oil change mentioned but haldex isn't mentioned on any recipts or anywhere in the book.
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    Check the front wishbone bushes.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    Oct 2013
    East Sussex
    204
    Is it possible to resurrect this thread.. as I have the same noise on my A4 sport. I would ask the dealers but may aswell ask the experts first and get it sorted by the dealer
  1. Rumbling / grinding when turning slowly.
    By Billy Young in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2011, 22:17
  2. Knock and Twang whilst turning steering wheel
    By devan in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2011, 03:57
  3. Weird noise whilst turning...
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2009, 21:53
  4. grinding/juddering when turning....
    Last Post: 16th June 2009, 19:25
  5. Occasional grinding when turning right..
    By Pegsta in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2004, 22:28
