JMB RetrofitsAH Fabrications
Thread: Fault Codes
    S4 Muzza's Avatar
    oww! my giant blue head!
    May 2011
    Ayrshire
    306
    Fault Codes
    I got a mate to scan my car last week and there were a few fault codes thrown up. Can anyone help shed some some light on these problems and what the solutions might be? Cheers
    VCDS-Lite Version: Release 1.1
    Monday, 06 February 2012, 18:37:54:38549
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Controller: 8L0 906 018 N
    Component: 1.8L R4/5VT G 0002
    Coding: 05710
    Shop #: WSC 00000
    VCID: 3A07277E3551
    2 Faults Found:
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 35-10 - - - Intermittent - Is this likely to be a faulty sensor somewhere?
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent - Dont really understand this as it starts fine every time
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: Redir Fail!
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V003
    Coding: 18448
    Shop #: WSC 06435
    VCID: 3E0F2B6E2979
    2 Faults Found:
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    16-10 - Signal Outside Specifications - Intermittent
    Address 22: AWD Labels: 02D-900-554.LBL
    Controller: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F31F6EA8EB3
    1 Fault Found:
    01316 - ABS Control Module
    79-10 - Please Check Fault Codes - Intermittent
    Audi S4 (B5) - JUST ARRIVED :D
    Audi S3 (8L) - GONE
    Audi A3 SE (8L) - GONE
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Clear the faults and scan again,see if any come up again
  1. What do these fault codes mean ?
    By JeePee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2011, 22:40
  2. Fault codes
    By Greig300 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2011, 20:29
  3. fault codes
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2007, 19:57
  4. Can anyone tell me what these fault codes are please?
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2006, 13:16
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
