Volks AutosAH Fabrications
Results 1 to 14 of 14
Thread: Turbo Noise
    Aug 2005
    London, UK
    11
    Turbo Noise
    Hi all,
    Newbie here, so hope somebody can help.
    I've recently started gettting some turbo noise on gear change on my '01 1.8T A3. It sounds like the wastegate, though I have never heard this until a couple of weeks ago. There's no loss of power or anything unusual.
    Anybody any ideas, and is it something to worry about?
    Dec 2004
    North London
    209
    Re: Turbo Noise
    is it like a fluttering noise when you lift off the throttle?
    Aug 2005
    London, UK
    11
    Re: Turbo Noise
    Yeah thats a perfect discription!
    When I lift off the throttle even at low revs or when changing gear.
    Any ideas?
    imported_gek
    Re: Turbo Noise
    DV sounds like it's pooped
    imported_alecblack
    Re: Turbo Noise
    Thats what it sounds like to me too. I had heard that noise for 4 months assuming it was normal as this wa my first turbo car but i noticed on this website that it is the sound of a knackered DV. I got a new one and the noise went away. You can pay about 20 for a standard one or 70 - 90 for an uprated one.
    Aug 2005
    London, UK
    11
    Re: Turbo Noise
    Cheers guys, I thought the turbo was on it's way out at first!
    Off to the mailn stealers it is then.............
    Sep 2004
    Glasgow
    919
    Re: Turbo Noise
    I think dealers aren't too bad on the DV..but remember to shop around at places like www.vagparts.com (not everything listed so worth a call) or on ebay as a habit before going anywhere near a dealer.
    Aug 2005
    London, UK
    11
    Re: Turbo Noise
    Thanks,
    Vagparts have the A3 OE dump valve (the 710N) for only 15.41 +VAT. I'll get it ordered, so hopefully that should cure it.
    Thanks for all your help.
    imported_gek
    Re: Turbo Noise
    Don't forget to get some clips. At least one of the DV clips (top one I think) is one use only.
    imported_Gibbsy
    Re: Turbo Noise
    I gotta say i had this and changed the DV, but the new one makes the same noise!
    imported_Nigma
    Re: Turbo Noise
    Mine is having the same problem.. If i go for a forged DV, will it still be silent like the OEM.? Can't be doing with all that Chssssss! noise every time i easy off.
    imported_Pures3work
    Re: Turbo Noise
    No point in uprated DV's. Just get the OEM "N" version and you will be fine.
    And no the forge DV wont make a chav whooosh noise [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    Feb 2004
    UK
    1,320
    Re: Turbo Noise
    definetly worth uprating the dv if you have a remap.
    Aug 2005
    London, UK
    11
    Re: Turbo Noise
    Job Done!
    Replaced the DV with a standard OEM 710N from Vagparts for 15.
    Cured the problem straight away!
