EM TuningVolks Autos
    Nov 2011
    Waterlooville, Portsmouth
    7
    Fitting TT anti roll bar to A3
    Hi,
    Just bought a TT anti roll bar and wondering how to fit it correctly?
    advice would be much appreciated.
    Jake
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    If its the TT225/S3 style one, then afaik you need TT/S3 style dampers to enable you to use the TT/S3 droplinks, as they drop down off the shock rather than up from the wishbone!
    TD5 Land Rover Defender build
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    im guessing you lowered your car and now have driveshaft contact on the ARB ?
    you need to drop the subframe down to fit it. your more then likely need to replace the ARB bushes for the correct size to match the ARB unless they are the correct size as standard
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Feb 2012
    95
    as above, subframe needs to be drop, new correct bushes needed, you can fit the tt arb to the FWD cars with out changing the shocks, you need to used your standard FWD drop links with slightly longer bolts and some spacers (thick washers, i cant remember exactly how thick) to the wishbone, then you can go nice and low
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    i wouldn't bother to worry about spacing the drop link due to the angle they sit at, they are next to useless anyway when lowered
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    this is the angle of mine
  1. anti roll bar
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2010, 11:06
  2. rs 4 anti roll bar
    By boya in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd September 2009, 14:38
  3. Anti Roll Bar Link Fitting
    By cheekeemonkey in forum Handling
    Last Post: 25th August 2009, 22:36
  4. Fitting RS4 rear Anti-Roll Bar
    By razza1 in forum Parts Requests
    Last Post: 23rd June 2009, 21:28
  5. A2 anti-roll bar
    By petera2 in forum A2 forum
    Last Post: 25th January 2006, 17:06
