Badger5Chris Nott
Results 1 to 12 of 12
    Dec 2011
    Hockley Essex
    309
    Cared out a pressure test today and found a big leak under inlet manifold! s3 8l
    hi all.
    Cared out a pressure test today on my s3 and found a big leak under inlet manifold! There is a split in the right angle piece just under the manifold next to the dip stick holder . Has anyone had this issue before? if so is it easy to fix ? and to buy a OME part or can you buy a silicone replacement ?
    Any help would be great
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Very common mate, yeh oem parts are fine until you remap i suppose.
    Simple job overall, you may need a little screw driver to get the factory clips off , and dont break the nipple on the mani as that will be a pita.
    Jan 2012
    Helensburgh
    36
    Had this replaced on mine last week.
    Dec 2011
    Hockley Essex
    309
    its stage one so is it best to replace it with silicone ? can you buy silicone right angle sections?
    Dec 2011
    Hockley Essex
    309
    did you replace it yourself?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Fairly typical place to split... your choice as to buying an OEM bit or using silicon... main problem with this pipe is that it is two different diameters... has a smallish one from the inlet mani then goes larger when connected to the pump valve... using silicon won't emulate this... I have used 8mm i/d silicon but its a compromise...
    What a lot of people tend to do is remove all of the PCV pipes etc and simplify it... it means less things to go wrong... if you don't fancy doing it then I would probably replace the hose with an OEM one unless its like £30 or something stupid which isn't unheard of from VAG...
    <tuffty/>
    Dec 2011
    Hockley Essex
    309
    Thanks for that . I would like to replace it all with silicone under there is it a big job ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Its fairly simple... the end game is to remove all the pipes etc from under the inlet mani and make sure you have no air leaks and the servo works properly...
    Here is a guide.... not model specific but you will get the idea...
    Guide - How to fit a catch can and simplify the PCV system
    Make sure you test your brakes are working before test driving.. biggest mistake here is getting the check valve the wrong way round... it needs to prevent boost from entering the servo but allow vacuum as this is how the servo operates..
    When I did mine I used one of the small outlets for the FPR, the other for the boost gauge and the one in the middle for my dump valve as I have done an N249 bypass... if you haven't done the N249 bypass yet or don't intent too then the other small outlet should go to the N249...
    Underside of my inlet looks like this...
    <tuffty/>
    Nov 2010
    1,673
    Quote Originally Posted by ;1492457
    <tuffty/>
    I think its about £16+vat from TPS. Il try and dig out the part number, if its the same as an AUM?
    Dec 2011
    Hockley Essex
    309
    Thanks for that tuffty . Just one final question , how much and what size pipe do i need to carry this out and do i need any T pieces .
    I have carried out the N249 .
    RIP S3dave
    May 2004
    nr Glos
    7,177
    06a 103 221 bk
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Dec 2011
    Hockley Essex
    309
    Thanks badger5 for all your help but think im gonna go for simplify option. cheers mate
  1. s4 inlet manifold
    By jutlis 3.0 in forum For Sale/Wanted - Audi Parts
    Last Post: 17th February 2012, 19:44
  2. A6 2.5 TDI 00575 Inlet manifold pressure exceeded
    By devine0969 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th February 2011, 18:36
  3. S3 inlet manifold
    By S3 AJ.X in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 17:19
  4. boost leak pressure test bad for turbo ????
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2010, 13:34
  5. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
