Thread: Bumper Jet Leak
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Bumper Jet Leak
    Few months back, got a water leak from the bumper jets drivers side
    Woke up this morning and it's leaking on passengers side!!! ( with a nice frozen icicle)
    Now, the bumpers gonna be off next month for the FMIC anyway, but anyone have any ideas as to the source....
    Marcus
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    if the washers are sitting proud of the bumper then i would say the problem is the actual washer is leaking, usually caused by frost damage. both of mine were nackered when i got it and also the washer pump for the headlight washers too. just need to make sure u have a good mix of screen wash and make sure its all the way through to the washers
    AJC
    AJC's Avatar
    Surrey
    173
    This always happens when it's freezing outside. I wouldn't do anything until it warms up a bit and then see if the problem persists.
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Quote Originally Posted by AndyC-S3 View Post
    Had the wheel arches out yesterday. I basically bled them dry then flushed them with anti-freeze. Dried them both again and pointed the hoses going into jets vertical from the top NOT horizontal. So far so good - no leakes and ive been using them alot yesterday night to test and no leaks/
  1. leak leak leak,aaahhhh
    By Buzzer in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2011, 09:32
  2. s3 boost leak? front bumper removal?
    By S3BN_H in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2011, 12:12
  3. Bumper washer jet covers
    By floyd 1.8 turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2010, 22:33
  4. S3 front bumper washer jet covers
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 21:01
  5. Wanted Bumper Washer jet covers
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2009, 10:50
