Volks AutosEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 49
Like Tree1Likes
Thread: 1.8 T Awful MPG When driving like a grandad!!!!!! `
    Feb 2012
    10
    My MPG Is shocking like 20 MPG any ideas why?
    Im pretty sure the car is running to cold like between 60-70 Could this be causing the shocking MPG. Im not even driving fast.
    The temp readings are from the 49c test aswell.
    Any help would be appreciated.
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    I have a 1.8T Quattro S3 and I get 38 MPG. Using Cruise Control at 65MPH. (and 99 Octane Fuel)
    Could be a few things.
    When was your last service.. Oil and Spark plugs.
    Maybe run some Redex through your car to clean out lines and injectors.
    Faulty Maf Sensor?
    Cars:
    Now: Audi TT Project car but looking for An S3 Project.
    Past: Audi A5 3.0 V6 TDI 300BHP 481 lbft
    Past: Audi S3 MTM 345BHP
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Check your exhuast gaskets aswell. My mpg was terrible with a dead gasket
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    If your temps are 60-70 deg and not rising then you have an issue with the stat, coolant temp sensor or both... at 60-70 the ECU is still in cold start mode so yes your fuel consumption will suffer..
    <tuffty/>
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    if your temp sensor is reading cold (less then running temp) then it will inject a bit more fuel.
    temp should sit at 90C
    try replacing the sensor see if it is makes a difference
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Feb 2012
    10
    Was serviced 2 weeks ago oil and plugs changed, I will try the redex, I need to get it on VAGCOM I spose?
    Do you think it is running to cold?
    Would that affect it??
    Nov 2011
    Central Scotland
    160
    I just had same problem on my audi s3 was running cold and was only getting 20 mpg
    changed over the thermostat and now i get about 30 mpg
    either be thermostat or coolant sensor.
    there is a good guide here - Thermostat replacement procedure..>> - AudiWorld Forums
    just done my girlfriends car as well on her 1.6 a3 was not heating up and bad mpg. Cost about £10 for new thermostat and gasket. Also get some coolant as well always lose some got mine here - G12+ PLUS VW AUDI MERCEDES MINI FORD PURPLE ANTIFREEZE COOLANT 1.5L LITRE BOTTLE | eBay
    Feb 2012
    10
    Thanks for the replies I will do the Thermostat later, Is the coolant sensor in the tank?
    Is it easy enough to replace?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    sensor is right hand side of the block. (in one of the coolant pipes) should be a 4 pin sensor. sensor takes about 30 secs to replace
    stat is easy takes around 10/15 mins
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    does any ones sit at 80 with heaters on mine stays there and with heaters off sits at 90?
    A3AH's Avatar
    Dec 2011
    365
    My thermostat has just gone aswell.
    s3black's Avatar
    Aug 2011
    Scotland
    78
    My thermostat is GAY
    SCOTLAND - Audi S3 2001
    Cat-back system, Coilovers, forge recirculating dump valve, stage one re-map.
    Back rolling on 17" Avus wheels
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    Quote Originally Posted by s3black View Post
    just gay or super gay ?
    RyanS3TT's Avatar
    Feb 2009
    Bristol
    496
    Mine used to sit at 90 all the tmie, since the cold weather im getting about 70 max..
    i jsutput it down to the cold cold air getting to the rad?
    Is this norm?
    Quote Originally Posted by Syvo View Post
    Cars:
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    Alright chaps,i'm new to the forum. I have a 53 plate s3 and have just done water pump,tensioners,timing belt,rocker cover gasket and thermostat. When sat in traffic temp sits nicely at 90 but drops right off to 60-65 when driving...could this be the coolant sensor? Am getting about 23-25 average mpg? Is this normal? Heaters seem pretty good aswell? Cheers bez
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by RyanS3MTM View Post
    Is this norm?
    No, it does not matter what the temps are out side, hot or cold if its not sitting at 90 after 10 mins or so it is not working correctly..
    Nov 2011
    Central Scotland
    160
    As S3dave said since fixing mine on my car and the mrs car both sit at 90 all the time once it has warmed up after about 5 to 10 minutes.
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Quote Originally Posted by djx11b View Post
    Could'nt agree more. 10 mins max, 90oC
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    I had the same issue, changed sensor and sender and it went from low 20mpg to 35mpg. I had a warning light though...
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Cost £40 at a garage to fix, do it yourself for a bit less though
    Jul 2011
    Hereford
    72
    Is this norm?
    Nope, 90deg always once warm, Even driving to work at -16 and sitting in the car park with the heaters on full wack mine stays at 90
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,223
    Anyone got a link to the thread that shows how to use the climate control to check the coolant temp and other things?
    Feb 2012
    10
    Thermostat Done temp going up to 90 and staying there no matter what.
    Hopefully the MPG will now improve greatly
    Erf
    Oct 2006
    Kingston
    233
    Hmmmm...my thermostat gets to 90 after about 10 mins, but I'm only getting about 22mpg and I'm not pushing it by any means. All town driving though. For those getting 30mpg in an S3, is that town driving?
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    Darren4's Avatar
    Feb 2009
    Surrey
    186
    Only used this link for the coolent trick, better then nothing lol:
    The Audi TT Forum :: View topic - HOW TO CHANGE A THERMOSTAT ON A 225TT
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    Ive changed my temp sensor for a brand new one and still no different,still dropping off to low 60-70 degrees c when driving. Its had thermostat and temp sensor, water pump and full coolant change. When sat sits bang on 90 and doesn't move... Until i drive off! Faulty temp gauge do we think?
  28. #27
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    Its the thermostat if it drops when moving and climbs again when stationary.
    TD5 Land Rover Defender build
  29. #28
    Feb 2012
    10
    Have you done the 49c test bez?
  30. #29
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    No i haven't m8...also got a engine management light today after i changed coolant sensor?
    Aragorn...thermostat's a genuine vw/audi one and only been in for 1000 miles???
  31. #30
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    Definately thermostat symptoms tho!! Got me bAffled... Need to get code reader on it 2moro and see wot its logged!
  32. #31
    "Stick a V8 in it!"
    15,318
    Be warned, you will likely find a code saying "Coolant Temperature Sensor, Implausible Signal" when the thermostat is faulty. This appears because the ECU sees the temperature dropping, knows that shouldnt be happening, so logs that code.
    Your Audi stat and sensor should be under warranty, so i'd take it back to them!
    Bez480123 likes this.
  33. #32
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    Thanks alot mate, will definately look at that 2moro. Because it never changed its behavior even with new thermostat just assumed it was something else but seems a bit ov a coincidence that the light now comes on 10 mins after putting new coolant sensor in! What temp should thermostat open so i can test it? Thanks chief
  34. #33
    s3black's Avatar
    Aug 2011
    Scotland
    78
    Quote Originally Posted by coatesy View Post
    SUPER GAY! TIP blew last night too
  35. #34
    "Stick a V8 in it!"
    15,318
    Was it a genuine sensor? If not then i'd defo be fitting a genuine one, copy ones can act funny.
  36. #35
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    Done 49 c test and all tally's up with temp gauge also fan cuts in nicely at 97-98c! Put on code reader and brought temp coolant sensor performance so definately looking like a faulty stat!will get 1 monday and let you lads know! Just one more thing...when i did 49c test its changed the reading to degrees f..any ideas how to change it back?
  37. #36
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    Yes both sensor and stat genuine aragorn!
  38. #37
    "Stick a V8 in it!"
    15,318
    One way to confrim its the stat is to get a piece of cardboard and cover 1/2 to 2/3rds of the radiator, and then take it for a drive.
    If it then comes up to 90 and stays there you know its the stat. Just be careful you dont overheat it!
  39. #38
    Bez480123's Avatar
    Feb 2012
    North yorkshire
    20
    To be fair i only do local miles the drop in temp was emphasised cos it never fully got to temp b4 i set off. After leaving it today to get up to temp and fan to come in i went for a quick smoke about and although the temp dropped it did retain some ov its heat(only dropped to about 70-75) and e.m.l. Hasn't come back on! All pointing to dodgy stat but i've only had car 2 months so didnt know wot temp should run at! This forum been a great help tho chaps so thanks. Any ideas on changing temps back to degrees c aragorn?
  40. #39
    Steven.c's Avatar
    Auto-Motive Restored Deatail
    Sep 2011
    Shropshire - West mids
    282
    The average mpg my car says is 28mpg, i get about 40 miles to a tenner. That's with a stage 1 revo, Silicone TIP, Jetex filter, Forge split-r. sound about right guys? the 40 miles to a tenner is about 40-50mph 10 mile distance travels.
    steve
    Metallic Ming Blue a3 1.8t sport.
    K03s, Revo stage 1, Jetex(JR) filter, Silicone TIP,N249 Bypass, Forge Split-r'seee
    Mk3 GTI Project - < Click me
  41. #40
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    40 miles to tenner is about right IMO. working out at avergae fuel price of 1.339 only getting about 7.5 litres of fuel
    use the site fuelly. really good way of keeping tracking of mpg and spendind costs. can really see a difference when driving carefully and when boosting about
  1. A3 2.0TDI low poor sh*t MPG.. driving me crazy some 1help!!
    By AntonTDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th May 2012, 19:27
  2. MPG and driving styles??
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2011, 20:55
  3. 1.6 - Awful MPG
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2009, 23:39
  4. What's your average mpg on town driving?
    By dragonstyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2009, 13:03
  5. MPG & London Driving No Difference
    By Steve-L in forum General Chat
    Last Post: 14th March 2007, 11:04
