I have a feeling the clutch plate splines are different, but don't quote me on that. I know the VR6 clutch and pressure plate will fit as that's what I have on mine.
G60 and vr6 clutches are identical fitment. The vr clutch is a common upgrade on the g60 as it has a slightly higher clamping force. But all 02a boxes share the same input spline and same 228mm size friction plate.
Yeah exactly, I did have the tech data from Sachs somewhere, the abf and g60 were similar but the vr was a bit stronger. Vr6 box is an 02a although it does have a different bell housing to accommodate the different bolt pattern on the vr6 block. You can swap to a 02j box on a vr by using the mk4 golf v5 5peed box and early agu 100mm output flanges.
