UnicornKowalski
Results 1 to 15 of 15
    Benjiman46's Avatar
    2nd Gearbox...
    Feb 2012
    Worksop
    222
    Post Thanks / Like
    Headlamp washers not working -_-
    Hi all!
    I've got a 2000 S3 and my headlight washers don't work. It says in the manual that they will work every time you use the windscreen washers, and there is an additional "pumping" sound when the headlights are on and you use the washers... But the jets don't pop out
    Does anyone know of any quick fixes or known problems?
    Regards
    Ben
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    They only work when the lights are on and 3 to 5 secs after you have started using the windscreen washers...
    They also don't run if the temp is 5deg or less outside... which it has been
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    Benjiman46's Avatar
    2nd Gearbox...
    Feb 2012
    Worksop
    222
    Post Thanks / Like
    That explains it then! I've only had the car a week so I'm still getting used to it lol
    Cheers pal ^_^
    Mar 2010
    424
    Post Thanks / Like
    mine work below freezing......
    James
    Now Silver Audi S3....fun in the snow (when it comes ! )
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    Gone Imola Yellow S3...
    and many many cars and bikes in the past!!
    Benjiman46's Avatar
    2nd Gearbox...
    Feb 2012
    Worksop
    222
    Post Thanks / Like
    Ahhh :-/ lol
    Mar 2010
    424
    Post Thanks / Like
    My last audi the pump had split,quick cable tie fixed it,have you checked for any water loss near the drivers side front when you try them?
    James
    Benjiman46's Avatar
    2nd Gearbox...
    Feb 2012
    Worksop
    222
    Post Thanks / Like
    I don't think there is any water. The front and rear washers work, the headlight washers just don't pop out... I think they're trying to... Because there is another noise when they are supposed to work.
    Mar 2010
    424
    Post Thanks / Like
    maybe they are frozen shut? run some warm water over the covers? if still no joy i suspect the pump is toast as the pump when operated creates pressure which pushes up the headlamp washers
    James
    Benjiman46's Avatar
    2nd Gearbox...
    Feb 2012
    Worksop
    222
    Post Thanks / Like
    I'll give it a try... I'll get it in one of the warehouses at work for a while and let it all thaw out lol
    Mar 2010
    424
    Post Thanks / Like
    mine break the ice when worked...so they do have some strength for sure!
    James
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,461
    Post Thanks / Like
    You can try prying them out of the bumper with your fingernails. They just work on the pressure of the water in them to lift them out of the bumper. Can just get stuck with road grime if they've not been used in ages.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    8,020
    Post Thanks / Like
    Mine work under 5 degrees.....
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Quote Originally Posted by AudiS3-Turbo View Post
    Mine does this on a full washer tank.
    Fill it 1 litre at a time, and it dosnt!, When bumper comes off for FMIC, it's getting fixed!!!
    Azure Blue, Pearl Effect
    1.8TQS, KO3s
    3" De-Cat - Straight Through
    Upgraded Coils / NGK / Mobil 1
    Carbonio Carbon Air / Bailey dv26
    Custom Stage 1 Re-map -> chippeduk
    Powerflex DogBone Mounts
    Eibach Pro Kit / ARB
    200 Horses Club
    SUMMER 2012 - KO3 hybrid / Wellycooler / TIP / Injectors
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    Quote Originally Posted by Nilz View Post
    You know what... I have no idea where I got that info from so I'll retract it... I have a feeling it was when my washer bottle was getting low... when the low light comes up on the dash they don't work then and I may have confused that with them not working below 5 deg... not difficult for me to get confused and befuddled these days lol..
    <tuffty/>
    My build thread...
  16. Likes Nilz liked this post
  17. #15
    sideways steve's Avatar
    Dec 2011
    258
    Post Thanks / Like
    To be honest I actually find mine annoying at times, when you want to give the windscreen a good blast to clear it they pop up and cover the your front and, bonnet and wings in screenwash which then leaves marks all over it LOL The lights are always on up here lately going to and from work as its still quite dark outside so im finding this happens alot !
  1. Headlamp washers
    By Der_Techniker in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2012, 22:30
  2. S3 Headlamp Washers.
    By its_neil in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2010, 19:14
  3. Headlamp Washers.
    By Don76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2009, 18:17
  4. Headlamp washers
    By Audi_TT 83 in forum TT/TT-S/TT-RS Forum
    Last Post: 12th February 2008, 21:28
  5. Headlamp Washers
    By ZAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2003, 11:13
