Sky InsuranceDTUK
    Dec 2011
    Hockley Essex
    176
    Post Thanks / Like
    speedo stopped working and fuel gauge going crazing!
    Hi all !
    Driving to work this morning and my speedo bounced up and down twice then stopped working all together and the MPG stopped too . Then i noticed that my fuel gauge fluctuating aswell! . Anyone had the same problem ?
    Mar 2011
    135
    Post Thanks / Like
    The mpg and fuel gauge fluctuating is related to the speedo not working. The instruments use the speed signal to determine when the cars moving and make the fuel gauge 'lazy' so it does not fluctuate under hard cornering. The mpg has stopped working as it can't calculate how fast your driving. First port of call is to check the connection to the speed sensor on the gearbox (3pin connector towards the back of the box) they have a habit of corroding, if that looks ok, chances are your speed sensor has died and replacement is necessary.
    Dec 2011
    Hockley Essex
    176
    Post Thanks / Like
    niceone thanks for that ! do you have any idea of the cost of a new one? and also the part number?
  1. Temp gauge stopped working?
    By aterro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th May 2011, 16:49
  2. A3 Speedo/Fuel gauge issues
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2010, 19:21
  3. Replies: 4
    Last Post: 9th June 2009, 13:42
  4. Speedo Stopped working.
    By Cviji in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2007, 19:14
  5. speedo stopped working!
    By paul_brad in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2005, 18:00
