Chris NottMonster Motorsport
Page 2 of 6 FirstFirst 123456 LastLast
Results 41 to 80 of 215
Like Tree2Likes
Thread: Haldex system confusion
  1. #41
    Jan 2012
    West London
    67
    Visit S3LOUD's Instagram Channel
    yeaah it was me that said that. My garage quoted £150 for the job .
  3. #42
    Jan 2012
    West London
    67
    Yeah you said that before but i still am not too sure of how to test the haldex on the vagcom. Im guessing it will be under transmission. I checked there and it came up with no faults but i wasnt listening out for any sounds or anything. Ikll give that a go in the week and report back
    Quote Originally Posted by thegoal007 View Post
    I have already mentioned about thes tests in vagcom, further up in my posts......
    with the engine ignition on only , run throguh the test and I'm pretty sure you should hear the pump make noise as it sets it on and then should stop when ending the test. Maybe someone who does not have any issues can try and confirm this for us.
    Mine does not make noise - so I think there is a problem.
    The startling discovery I have made is that when the engine is running and I run through the tests and put the laptop away I find the problem has completely gone away. Again what that means......I'm not sure (electrical Haldex controller issue ?).
    This discovery is a fact because as I do a sharp righ(or left) out of my garage I feel like the rear wheels are locking/ceasing. So I stop hook up the laptop, run through the test , disconnect and continue on my travels with no issue.
    When I switch the engine off and on the problem comes back.
    Maybe someone can figure out what the h*ll is going on here. Upshot - this problem is electrical and NOT mechanical, well certainly in my situation.
    Oh and I should add there is no corrosion on the wires/plug into the controller and no errors shown up on vagcom (which is pretty much nearly everyones experience with these issues).
    Further last note, running through the tests when engine is off and then starting car basically does nothing - the problem remains.
  4. #43
    Erf
    Oct 2006
    Kingston
    230
    Quote Originally Posted by S3LOUD View Post
    do you mind me asking which garage? I'm in kingston so if its not too far from me, might give them a call. I've had quotes of over £300...!
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
  5. #44
    Jan 2012
    West London
    67
    Quote Originally Posted by Erf View Post
    Whoaaa thats a lot :O! lol yeah of course its a place called yaashik motors that i used in wembley (near ace cafe) so not too far away from you. Give em a ring , they should have it done within the day for you aswell
  6. #45
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    713
    You will not find any faults - most people don't with this kind of problem. Don't expect to hear noises until you run through the specific tests in vagcom - which by the sound of things you don't know how to run them.
    I need to step you through the instructions when I do it tomorrow when I take the car out for a spin. I'm pretty sure I've explained the how to run the test in the past on these forums.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
  7. #46
    thegoal007's Avatar
    Apr 2008
    surrey
    713
    I was right, I've alerady posted the instructions here..and above.
    Here it is again.
    ..... pick 22-AWD and then select output tests - 3 and hit start/next. This will go through putting the precharge pump on and off and the awd clutch off/on. When the precharge pump is on it should make a noise (I think). Obviously with the ignition on only.
    Once you have done this. try starting the car up and doing the test cycle again and then remove cable and see if you still have the problem.
  8. #47
    Jan 2012
    West London
    67
    sorry i didnt recall reading that before. i'll try it using the steps youve explained and let you know what i find . Thanks for all the help mate,
  9. #48
    Jan 2012
    West London
    67
    Okay so the update! I plugged the car into vagcom, ran the haldex test and nothing came up as an issue however i did not hear any of the pumps or anything making any sounds during the test. I took the car for a drive and the issue had in fact gone away, but since turning the car off after that and driving it again the issue has come back.
    I am getting a very loud clicking/knocking noise from the back of the car when on turning or even when i slow down for a speed bump or something, as i change gear and re-engage i can hear that sound also. I am wondering if anyone may know what this could be and if this is some what interconnected with this haldex issue.
    Thanks for any help !
  10. #49
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    This is interesting, mines making a grinding noise on full lock, as a result I'm changing the haldex fluid this weekend in the hope of solving it. If that doesn't solve it then I'll be watching this thread very closely!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  11. #50
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    I had a similar problem with an old a3 quattro and it turned out to be a plug in the pillenium chamber (sp) might be way off the mark but might be worth a try. Basically it had a intermittent connection when driving.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
  12. #51
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    TBH my problem could be a number of things at this stage, I'm just trying the oil change first as its the cheapest option. My troubleshooting will be listed in this thread: Hladex Oil and Filter change prep...
    > S3 225 (03) - OEM+
    View: My S3 diary
  13. #52
    thegoal007's Avatar
    Apr 2008
    surrey
    713
    that's strange because you can clear the problem by running through the tests when the car is running and as soon as you switch the car off and on again the problem re-appears - Which is same as me, BUT the knocking noise are not very loud at all and no noises until I leave the car in that turned postion for more than about 15 seconds....and normally I'm not as the car would be straightened out by that time.
    I've been cycling through those tests every time I take the car out and on a few occasions lately I found there was no need becuase the problem was not there- maybe it's getting it's knickers untangled ?
    Personally, from what you describe about your knocking noises, i think it's a completely different issue.
  14. #53
    Jan 2011
    Glasgow
    226
    The oil in the haldex lubricates the clutch if not serviced the plates dry and grind and wear. the haldex spins the rear wheels at different speeds...one of the wheels rotates a shorter distance from the opposite hence why you can hear the noise at lower speeds or turning. It is far cheaper and easier to replace the rear haldex with a 2nd hand one.
  15. #54
    Erf
    Oct 2006
    Kingston
    230
    Quote Originally Posted by Greig300 View Post
    Can you replace just the haldex or do you need to replace the whole rear diff as one unit?
  16. #55
    thegoal007's Avatar
    Apr 2008
    surrey
    713
    as I have previously mentioned it's probably cheaper in the long run to do the whole thing. There's just too many variables and costly ones.
    One person changed all the plates as mentioned by greig3000 and still had the problem and the other end of the scale some people have just changed the oil & filter and were OK.
  17. #56
    Aug 2010
    1,540
    this wheel skipping problem is down to either, the haldex locking up 100% when it shouldnt be. or a purly mechanical fault with the rear diff locking up for some reason.
    what you guys are describing seems exactly the same as when you have an intentionally welded diff on a drifting car.
    i drove my e21 bmw drift car for around 3 years on the road so i know exactly what your describing.
    theory to understand how it all works..................
    obviously when you drive with a welded diff when going straight forward both wheels turn at the same speed, but when you turn a corner the inside wheel turns less and the outside wheel turns more. if the diff is locked then one of the wheels has to skip, the inside one! when turning a corner this effect is like a constant resistance to rolling (braking).
    if the car is 4wd then when turning a corner all the wheels are turning at different speeds..... but the sum turns of both front wheels will be different to the sum turns of both rear wheels.
    now on say a landrover.... with a front, center and rear diff. you lock the center diff and turn a circle on full lock at like tickover in first gear, you get this wheel skipping feeling somewhere and understeering feeling you dont get with the diff lock off.
    do the same in my bmw it was blatently obvious the inside wheel is skipping alot!
    on a tt s3 you dont actually have a center diff! the gearbox is driving the prop all the time the haldex takes the place off a center diff and should allow the the difference in the front wheel turns and rear wheel turns at low speeds completely without this resistance to rolling wheel skip.
    why dont you guys just do some basic things/checks to rule stuff out rather than guessing stuff and messing about with vag-com?
    on these cars if you simply unplug the haldex controller the car should be completely fwd. if your wheel skipping fault is still there, then were getting somewhere...... were 90% sure the haldex is ok.
    jack the back of the car up turn one back wheel, does the prop turn?
    with the haldex unplugged it certainly shouldnt be turning the prop, if it does then the clutch pack is locked when it shouldnt be.
    if the prop is behaving fine ie not turning. when you turn the wheel is the other wheel turning in the same direction? opposite direction? not turning at all? can you hold one still and turn the other?
    with the haldex unplugged you should be able to turn either wheel independant of each other without the prop turning.
    does it feel notchy or clunky while turning one one way and the other wheel the opposite way?
    if the this is all correct and the fault is only there with the haldex plugged in then you can say its deffinatly that.
    thegoal007 likes this.
  18. #57
    Jan 2011
    Glasgow
    226
    Removing the haldex fuse will still cause the noise as its mechanical fault. Just replace the haldex unit. The main box.
  19. #58
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    FYI it looks like my problem is the earth strap:
    Oh, and pulling fuse 31 did solve the dragging issue in my case...
    > S3 225 (03) - OEM+
    View: My S3 diary
  20. #59
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I've been having this problem since I upgraded my Haldex to a blue controller...when I do a 3 point turn my back wheels feel as if they are locking up and they make a clunking noise....Plus my Haldex pump is constantly ticking....
  21. #60
    Jan 2011
    Glasgow
    226
    Quote Originally Posted by cecilthesausage View Post
    The ticking is from the pre charge pump. Usually on ignition it will constantly suck and tick. Your wiring on the connectors to the haldex will be corroded or dirty. Giving the connectors a clean with electrical fluid and removing the junk it gathers can solve that problem.
  22. #61
    Jan 2012
    West London
    67
    Quote Originally Posted by shariain View Post
    ohhh really?? To be honest nothing surprises me with S3's loool. I'll defo have a look a that and see if i can find any issues there , Thanks a lot mate!
  23. #62
    Jan 2012
    West London
    67
    hmmm okay thats all defo a lot of different stuff to try. Firstly i am going to try taking out fuse 31 this morning and see if this resolves anything. If not then it is defo time to try the list of hints and tips above. So far i have done 2 oil and filter services, replaced the haldex clutch pack and haldex controller and the issue still persists. I realised after this that the diff should also be replaced so i have the diff which matches the clutch and controller ready to also go in at the start of next month.
    I will let you all know if pulling the fuse resulted in this dragging feeling no longer occurring. If that is the case then what would this mean???
  24. #63
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    If pulling the fuse solves it then it means the issue is electrical so check your wiring...
    > S3 225 (03) - OEM+
    View: My S3 diary
  25. #64
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Mine has always groaned on full lock from the rear but I read that it was normal? It's definitely not locked in 4wd as I pulled the fuse when my haldex leaked (changed controller and gasket was on wrong) and it was FWD for sure. Also very rarely when I launch, I catch out the Haldex and the front wheels spin very briefly. Anything else it could be? I am getting the rear diff and haldex serviced shortly along with all the other fluids.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  26. #65
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Is the full lock groaning different with and without the fuse?
    > S3 225 (03) - OEM+
    View: My S3 diary
  27. #66
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Not tried without the fuse but will tomorrow. If it does what does that mean?
    I have a blue controller and it all looked pretty mint under there so not sure if the earth strap is rusty or not.
  28. #67
    Mar 2012
    131
    Fundamentally, rear (or front) wheel skipping should only occur if a diff is locked and preventing differential wheel speeds on the same axle ... Plate diffs have inherrent drag and of course welded diffs will always drag, torsen diffs will lock or transfer torque but only when one wheel tries to spin.
    The rear diff on the haldex system (on the S3 8L) is open so the haldex clutches working or not should have no impact on whether one rear wheel is grabbing or not whilst cornering unless the open diff is faulty due to perhaps one of the planet gears breaking and locking it up - this could make grinding noises if the broken parts are rattling about but still in place. Some systems use electronic braking of individual wheels to alter the torque distribution on the axle, to compensate for the diff being open, but I think the S3 only has this on the front wheels and not the rear so this should not cause rear wheel locking either.
    Martin
    S3 2003 Avus Silver, Sunroof, Chrome Mirrors, Symphony II, Cruise, Heated Seats, Centre Armrest, Ambient Lights, GTRS Turbo, Forge FMIC, Sports Cats, MillTek, Coilovers ...
  29. #68
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Quote Originally Posted by k1ano View Post
    Martin
    Almost correct. On mine the earth strap failed and caused the haldex clutch to permanently engage the rear drive. Removing fuse 31 disengaged the haldex clutch and released the clutch. Yesterday I had the earth strap replaced and subsequently replaced fuse 31, this has resolved the dragging.
    Sam_ - TBH I'd be surprised if it is actually mechanical failure, unless you've done interstellar mileage or something out of the ordinary has happened. For reference here's an explanation of the haldex system that I found useful: http://www.billswebspace.com/HALDEX.pdf
    > S3 225 (03) - OEM+
    View: My S3 diary
  30. #69
    Jan 2012
    West London
    67
    Okay so a little update with mine, (sorry been a bit busy with work). This morning on before i left for work i removed the haldex fuse and now obviously as a result it is running front wheel drive HOWEVER the dragging issue has completey disappeared!
    Does anyone know what this may mean???
    Thanks a lot for all the help its much appreciateddd! !
  31. #70
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    It means your fault is electrical. Checked the earth strap yet?
    > S3 225 (03) - OEM+
    View: My S3 diary
  32. #71
    Jan 2012
    West London
    67
    Quote Originally Posted by Funk_Junky View Post
    Hopefully a ramps free sometime during the day today and i'll quickly throw the car on and take a look and hope that we've sourced the issue. Do you know where abouts the earth strap is by any chance just so i know where exactly im looking??
    Cheers mate!!
  33. #72
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    You don't necessarily need a ramp TBH but its easier if you have one. Under the car, on the passenger side at the rear end. The strap runs from the diff to the body under the boot area: It might look like this:
    On the left of the pic you can see the diff end of the rear passenger side drive shaft, should help you get your bearings.
    > S3 225 (03) - OEM+
    View: My S3 diary
  34. #73
    Jan 2012
    West London
    67
    wow thanks for that! :D im hoping that thats all that is causing me the issue. I will try and check that today and keep you updated.
    Thanks mate thats made my life a lot easier when looking for it!! Top man!
  35. #74
    Jul 2010
    Teesside
    933
    Is this my Earth Strap...
  36. #75
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    No, that looks like arm for the xenon level sensor, which looks like its been disconnected.
    > S3 225 (03) - OEM+
    View: My S3 diary
  37. #76
    thegoal007's Avatar
    Apr 2008
    surrey
    713
    there you go so many people with the same problem and so many reasons. Pulling the fuse on mine doesn't resolve the issue, but running through the output tests (just like you) of vagcom clears the problem. so go figure !
    What I would say is leave the fuse out for a week just to make sure it really does cure the problem because I have to remind you that it is not a problem that is consistent.
  38. #77
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    No... thats a broken headlight level sensor... you nee to fix that for the MOT...
    <tuffty/>
  39. #78
    Jul 2010
    Teesside
    933
    Its at the rear of my car Paul.... Passenger side
  40. #79
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Correct, but it is for the headlights. Look above this attached to the boot floor for the earth strap.
    > S3 225 (03) - OEM+
    View: My S3 diary
  41. #80
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
  1. leads confusion
    By goon in forum In-Car Entertainment
    Last Post: 19th May 2010, 16:02
  2. Information on the 2ns gen Haldex/Quattro system
    By mwstewart in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2008, 21:52
  3. model confusion
    By goon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th August 2007, 19:47
  4. haldex system......
    By One in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2004, 13:39
