AMD TechnikAWEsome GTI
Results 1 to 13 of 13
Thread: what ecu?
    Jan 2012
    6
    Post Thanks / Like
    what ecu?
    hello just a quick question,
    im changing my engine from a APY to AMK, but im wondering can i use the apy ecu or will i require a AMK one to match?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,083
    Post Thanks / Like
    Don't know 100% to your case but I have a BWA Engine with a AXX ECU.
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
    Dec 2011
    89
    Post Thanks / Like
    It should run the car. Not sure about parameters etc, pick up a second hand ecu and if your chip is the same inside swap it over, no need to program immo in. Think its a 24C16 chip or could be a 93C86 or something alike. If you do this let me know what 8 legs chip you find tell me the numbers and I will tell you if it's correct. So log as they're same chip you can change them. It's got immo details and bin number on that chip so a little bonus by keeping your vin if you decide to get ecu for AMK pm me if you get stuck
    beachbuggy's Avatar
    Surrey
    868
    Post Thanks / Like
    If you're just changing the engine it's self,nothing, including the ecu needs to be changed. You just take the old engine out and put this one in. Swapping all sensors etc over. Not sure why the talk of immo and chips is being mentioned! If however you want to run an AMK engine in your car and benefit from the EGT, wideband and other associated improvements then you'll need to run the engine, loom and ecu. Then yes you'll need to recode the ecu but again no need for swapping chips.
    May be just explain a little clearer what your plans are and therefore we can advise more.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    AMK won't have prevision for SAI and will come with a VVT cam chain tensioner.... the tensioner should be ok disconnected (have run one recently in a Mk3 Golf 20v conversion) but you would need to do an SAI delete
    As has been said, the engine will drop straight in... watch the metal water pipe that runs from the water pump to the heater hoses as this can vary and the PCV pipe from the block to the cam cover is different to route past the vvt
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    Dec 2011
    89
    Post Thanks / Like
    Quote Originally Posted by beachbuggy View Post
    No you don't 'need' to swap chips, but if he hasn't got vag com he can save time/money and do this. Also keeping his VIN which is a bonus. No need to make me look a fool mate.
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    Swapping chips isnt going to work if one ECU is ME7.1 and the other ME7.5, and i'm pretty sure thats the case here!
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    633
    Post Thanks / Like
    Yep APY is 7.1 and AMK is 7.5.
    Swap the engine, junk the sai and use the original loom and ecu, simples...
    Dec 2011
    89
    Post Thanks / Like
    You would be right, but I did state they have to be the same chip.
    beachbuggy's Avatar
    Surrey
    868
    Post Thanks / Like
    Quote Originally Posted by Craig1.8t View Post
    Who said anything about making you look a fool? I was just stating that mentioning chip removal wasn't necessary and you never mentioned not having vagcom in your post. For your reference it's the EEPROM 95040 chip you are referring to with 8 legs. No need to remove as fully readable and programmable whilst still on the ecu. The chip is the same through the me7 range so yes in theory it will work by removing and swapping, but then the me7.5 ecu won't work on the me7.1 loom so that would need to be changed as well. And do it continues. Sorry if you took offence.
    Dec 2011
    89
    Post Thanks / Like
    None taken, yes its EEPROM (ST family) 95040 (Couldn't remember from top of head was just giving the guy advice, maybe I didn't mention vagcom but surely he would discard my advice if he did.
    Jan 2012
    6
    Post Thanks / Like
    right guys sorry for late reply forgot all about the post, thank you for replys!
    had the engine fitted decided to keep my APY ecu to save some pennies, however the engine seems to be misfiring
    could a different ecu cause the misfire (even tho its still 210bhp), i have had it on a diagnostic (not vagcom just a cheap tool) and it shows no faults, coilpack has been changed.
    the new engine is a forged engine, had 81000, and was rebuilt 1500 miles ago.
    Jun 2009
    Leeds
    2,046
    Post Thanks / Like
    You seam to have a ecu fetish lol
    Changing it isn't going to solve the misfire problem
    Check the plugs and loom for the coil pack, you could also have a coil pack thats starting to fail but not showing codes
    Stroked 2067cc (2.1) S3. AEB Ported & Gas flowed head, Piper cams, Valve + Spring kit, Big intercooler, IE rods, JE Pistons, CP rings, Milltek, GTX3076r Turbo, External Gated, 870cc injectors, Twin pumps, Wide Band conversion, ALD Custom inlet with R32 T/B, MkV TSI Coilpacks conversion, Fluidampr pulley, 4kg Billet steel flywheel, 4 paddle clutch, Coilovers, R32 rear ARB, Blue Haldex, 350mm 6 pots fronts & 330mm rears. Going for 550bhp, 600bhp with new injectors and more boost
  1. Audi S3 2008 Built (8P). Retrofitted Cruise Control. NEW ECU or no ECU?
    By moley147 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1 Week Ago, 20:05
  2. Gearbox ECU’s by ECU Testing.com
    By FuAudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2012, 19:57
  3. Help Please: Abs Ecu Coding and help with ecu.
    By asasprey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2011, 18:02
  4. ECU and what else
    By tazzy baby in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2010, 19:54
  5. ECU problems - attempting to match Immobiliser with ECU....and failing
    By stefanhenchoz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2010, 18:44
