After the wipe line splitting and frazzling my amp ive got a replacement sub and amp to fit but could do with a few pointers getting the rear interior panel out and fitting the new sub some pics as well would be quality
cheers
stu
cheers
stu
1992 Cavalier SRi 8V RIP
2002 Mondeo ST TDCi Good riddance!
2000 A3 8L 17" Ronal TT, -45mm, LCR Splitter, Matt Black Badging, Soon to attempt Lamin-x headlight tints
this guide should help, you don't need to do everything in it, just the part in the boot, so remove the cargo anchors, then the boot lip trim and then the boot panel. The boot panel will still be attached with a screw hidden behind the rear speaker panel, but you will have enough room to do what you need to do without removing the panel completely.
http://freepdfhosting.com/37841f9301.pdf
Alex Turner
stu_b thanked for this post
cheers andymac you the man will crack on tomorrow when its stopped snowing!! I picked up a 6 disc cd shuffler while i was at the breaker yard theres a bracket and black square cable above the sub in the boot should just plug in and play i assume?
Yes, just plug it in
Alex Turner
square plug round hole! ****ter. back tomorrow to try get an audi one VW/Seat have square plugs do they not? can you get a cable to make them work or is it not worth the hassle?
No you need the Audi one
Alex Turner
