Revo TechnikBadger5
    Sep 2010
    Devon
    281
    Post Thanks / Like
    Timing problems....Resulting in cambelt failure!!
    Aaaaaarrrrgggghhhh!!!!
    I've been having loads of timing issues with my APY S3, running a stage 1 REVO map its throwing up code 17745 which is camshaft sensor fault g40 short to ground. When logging on vcds its showing blocks of 7+ which clearly isn't correct. There is a little mid-range hesitation, I swapped the sensor three times to experiment, always with genuine Audi parts and still the same result. I checked the wiring and multimetred the output and it was showing 5v so thats all good.
    Only thing I can now think of is that I have a recon head. I didn't realise this at first when I bought the car. The issues can't of been because the cambelt was a tooth out ( it was changed in october ) or it would have driven like an absolute sack!!!
    Anyway car was a nightmare this morning so I opened it up and found the cambelt was uber frayed and really, really loose. Car had been really suffocated, hesitant and unwilling thats why I opened her up.....Its buggered.
    I'm now looking at getting a AGU head to replace the crappy recon one and hoping that and a cambelt change fixes it>
    Any suggestions or ideas to what may have caused this welcome!!!!
    Stage 0.25 S3, as Audi intended it, except with a little wear and tear. And a few extras
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Plymouth. Devon
    1,980
    Post Thanks / Like
    Bloody hell Russ! This is tearful!
    Good job you're minted eh'
    Beer soon?
    I like him, he's my friend, and no amount of internet muppetry is going to change that I'm afraid
    But I wish I had an S3
    Jun 2009
    Leeds
    2,046
    Post Thanks / Like
    I would of thought it might of been your tensioner?
    Stroked 2067cc (2.1) S3. AEB Ported & Gas flowed head, Piper cams, Valve + Spring kit, Big intercooler, IE rods, JE Pistons, CP rings, Milltek, GTX3076r Turbo, External Gated, 870cc injectors, Twin pumps, Wide Band conversion, ALD Custom inlet with R32 T/B, MkV TSI Coilpacks conversion, Fluidampr pulley, 4kg Billet steel flywheel, 4 paddle clutch, Coilovers, R32 rear ARB, Blue Haldex, 350mm 6 pots fronts & 330mm rears. Going for 550bhp, 600bhp with new injectors and more boost
    Sep 2010
    Devon
    281
    Post Thanks / Like
    Sorry Jarod I can't afford a beer now...Just done rear calipers discs and pads, mot, tax, starter motor, haldex controller and I treated myself to a new number plate s3 *&% because I got it for a good deal...oh yeah and two new tyres. And a couple of bulbs. Also getting married in 5 months. Now this!!!!! Wish I kept the A3 now, never gave me problems as stressful as this and all the hard work was done, I havn't even started modifying this yet.
    Andrew: would the tensioner cause such timing issues like block of 7s? I know it sounds silly but I think the timing problems were there before the cambelt died....
  1. What are my options? Cambelt Failure.
    By baynesey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st August 2011, 03:30
  2. TDI was cutting out, now cambelt failure - Any ideas on what caused it?
    By Aaron TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2011, 13:27
  3. pump timing problems?
    By shufti in forum Diesel forum
    Last Post: 1st December 2006, 05:29
  4. Timing Belt Problems?
    By gkat29 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2006, 17:04
  5. Cambelt Failure?
    By Chimera in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2005, 08:21
