Adrian S FluxEM Tuning
Results 1 to 12 of 12
    Jan 2012
    Helensburgh
    30
    Post Thanks / Like
    Turbo and ESP issue, need help.....
    I put the car into the garage to get a breather pipe replaced. When they replaced the pipe and smoke tested it, they discovered to turbo itself was loose, they tightened that up but still I'm not feeling the whoomph effect I had before this problem.
    The turbo used to kick in from 2000 Rpm and the car went like a scalded cat. Now it just limps its way up through the rev range. The garage said the turbo appears to have had a new valve installed (forgot the actual name) recently but can't explain the loss of power.
    The turbo is still spinning up but it's not delivering the power expected. There's no leaks, any ideas?
    Also the ESP light is coming on and VCDS is showing a faulty lateralG sensor. Any ideas how to fix this?
    Im putting the car in next month for a full service and get all the faults fixed on it while it's in.
    Also, nearly forgot, when I put the foot down and get a tiny bit of boost, the car stutters at 4.5k RPM and just goes kinda meh!
    Hopefully some of yous can lend some suggestions to the above problems. I love driving this car but these niggly faults are starting to put me off!
    Jan 2012
    Helensburgh
    30
    Post Thanks / Like
    Really need feedback/advice guys. My oil light came on tonight despite there being maximum showing on the dipstick. The car now sounds like its sucking the last of the juice out of a McDonalds cup and it's lost power. This happened about 400 yards from my house. I just made it home. Temperature is reading ok and it's idling ok and the oil light goes away when I start it.
    Any ideas?
    Feb 2012
    60
    Post Thanks / Like
    oil level warning or oil presure light?
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Well ESP light on was faulty sensor in my case, but im sure that the first port of call is gonna be VAGCOM for error codes.
    Hard to diagnose on word of mouth. There is a sticky for members in the uk with the kit.
    Good luck.
    Marcus
    Azure Blue, Pearl Effect
    1.8TQS, KO3s
    3" De-Cat - Straight Through
    Upgraded Coils / NGK / Mobil 1
    Carbonio Carbon Air / Bailey dv26
    Custom Stage 1 Re-map -> chippeduk
    Powerflex DogBone Mounts
    Eibach Pro Kit / ARB
    200 Horses Club
    SUMMER 2012 - KO3 hybrid / Wellycooler / TIP / Injectors
    Jan 2012
    Helensburgh
    30
    Post Thanks / Like
    It was flashing so looks like its an oil pressure issue. Guess its a garage issue now!
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Quote Originally Posted by Kami View Post
    Considering the sucking....oil pump. But like i said theres 101 things it "could be" VAG-COM is Job 1
    1.8TQS, KO3s
    200 Horses Club
    Jan 2012
    Helensburgh
    30
    Post Thanks / Like
    Defo sucking noise! Here's hoping its not a new engine job. I drove it nearly half a mile to get home thinking it was just an oil level light and having just checked the level.
    I bought this car as I thought it would make a reliable daily. I can't really afford for it to break on me. It took all my savings to buy this.
    s3dave's Avatar
    mediator
    west yorks
    6,956
    Post Thanks / Like
    Sounds like a blocked pickup or failing oil pump, either way dont even start it again until diagnosed and fixed..
    Quote Originally Posted by 16Klappe View Post
    And anyway, less of the thinking because I'm ALWAYS right!
    Jan 2012
    Helensburgh
    30
    Post Thanks / Like
    Got a call from the garage today, the pickup was all sludged up and the pump was knackered, also the turbo's impeller came loose and one of the pins/bolts that hold everything in place came out and rattled about inside the turbo destroying everything.
    New turbo it is now, can't afford a new one so having to go recon.
    Any issues with a recon turbo?
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    scummybrummie
    1,126
    Post Thanks / Like
    Hi dude, sorry to see all your trouble, oil pick up is a bugger when not caught in time.
    Why where they messing with your turbo? And no problems from a recon unit if done properly. What have you been quoted for a recon k04?
    2002 51plate Audi A3 1.8T sport AUM, Minger blue, xenon conversion, piano black recaros, forge 007p, jet ex filter, cold feed, silly tip. That's the good stuff listed
    Jan 2012
    Helensburgh
    30
    Post Thanks / Like
    I already had a seperate issue with the turbo mate, I had a separate post about that problem where I tried replacing a leaking breather pipe but it still never cured the problem. It was then it was picked up that the turbo had came loose and I got it to a specialist to check over it. Sorry for the confusion LOL
    For all the work with new Turbo, it's near he £2k mark, slightly less with a recon turbo. I nearly fainted!
    Jan 2012
    Helensburgh
    30
    Post Thanks / Like
    Got my car back last night. It seems like the turbo was a cheap nasty copy which explains why it broke. Also the oil pick up pipe has been off before but was completly blocked. Someone hadnt cleaned it out before refitting it. Someone really bodged the car up. Could have been the garage I bought it from but I'll never know.
    Just glad to have it back now.
  14. Likes s3dave liked this post
  1. ESP Issue thats Got Me Stumped
    By Martin82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2012, 16:39
  2. ESP warning on start up and esp light on dash all the time!
    By Ripitup in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2011, 11:41
  3. 2007 TDI 140 possible turbo issue
    By Damo M in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2011, 17:45
  4. Engine issue - No EML, ESP light on
    By bn9af in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd January 2011, 19:02
  5. Turbo Issue Questions
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th September 2004, 08:46
