poking badgers with spoons
help please on low boost
i had a problem with a bad idle when coming to a stop at traffic lights and round about's the same as dani has in the s3 - (Seriously at my wits end now...........)
i have solved it about three times now firstly i checked all my boost and vac pipes some of them needed tightening up so i did this,
second time it came back i changed all the vac pipes for new silicone ones and changed the plugs and temp sensor ( as the car was reading that the engine was -10 all the time) this then sorted the job out.
third time around i changed my fuel to super unleaded and fitted a boost gauge to see if there was any leaks, after fitting it i checked every thing again scanned it with vag-com it was sound no codes. i was also boosting 6-8 psi which if im right is normal for an unmapped AGU.
in the past week or so the bad idle has come back again but when i come to a stop if i leave the car in neutral and don't have the clutch in, it doesn't through this bad idle thing, also it depends what gear im in to what boost reading im getting on the gauge in 2nd i get some times the 6-8 psi but in third it will drop to 3-4 psi, also a slight burning smell when inside the car but when i pull over the burning smell isn't from the engine bay well i cant smell it when i stick my head under the bonnet. nearly forgot to add it feels quite lumpy when driving.
if its bad news that's not to worries, currently in the middle of saving and creating a list and gathering info for the k03s hybrid its getting when the weather gets a bit warmer, this will be along with an engine rebuild and rods and so on.
any help is muchly appreciated.
car is an a3 1.8T 1997 AGU
