Revo TechnikEM Tuning
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By DJ_Troopa
Thread: S3 2001, engine very hesitant during acceleration.... helppp!
    Jan 2012
    West London
    48
    Post Thanks / Like
    okay, new member and new audi owner and having some issues with my S3.
    When accelerating, the car feels very hesitant as if it is missing. I get up to around 4000 revs and the car just doesn't wanna give me any more, i then let off the accelerator and hear a little pop from the engine then once i get back on the accelerator it lets me continue through the rev range but still very hesitantly.
    I ran the car on a VAGCOM and got back a that knock sensor 1, signal too low: P0327 is showing up as a fault. Now the day before i also ran the VAGCOM system and saw Fuel erin: Bank 1 (add): system too lean: P1136.
    Is it possible that by replacing the knock sensor it will correct the engine running too lean??
    Also does anyone know the location of knock sensor 1 on an AMK engine?
    Any help will be much appreciated, thanks a lot
    Aaron
    DJ_Troopa's Avatar
    Audi S3 Driver
    Oct 2008
    West London
    1,683
    Post Thanks / Like
    You like to follow me around don't you
    If you need anything give me a shout.
    S3LOUD likes this.
    Lava Grey 2.0 TDI 140 Sport
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,778
    Post Thanks / Like
    lean missfire through the inlet mani perhaps, is your car mapped?
    May 2009
    Midlands
    197
    Post Thanks / Like
    Sorry to thread crash however My s3 has identical symptoms. Crank case signal intermittent and also mentions retarding ignition on intake camshaft??Car was Recently remapped.
    Jan 2012
    West London
    48
    Post Thanks / Like
    LOL well what can i sayy mr troopa ;O haha. yeah will do bro thanks a lot man :D!
    Well I've bought the car recently and was told that it has been mapped but not 100% sure as didn't come with receipts or anything.
    When i did the VAGCOM that showed the fuel running lean it also showed "engine control module incorrectly coded: P1612. But this is no longer coming up. Would this mean that the issue could also be down to a dodgy re-map?
    May 2009
    Midlands
    197
    Post Thanks / Like
    I think my fault code was crank shaft sensor intermittent (signal implausible). Intake camshaft retard point not set. Codes were cleared and these two came back after one run.
    However on a run mine displays identical symptoms, refuses to pull above 4k revs and hesitates throughout the entire range, almost like she's starved of fuel??
    Pulling my hair out however cars now at local VAG specialist being looked at :-/
    Jan 2012
    West London
    48
    Post Thanks / Like
    Yeahhh mines got the same sort off issue. I'll get to 4000 and then just very hesitant. I believe it is fuel starvation aswell but... ahh i dunno lol.
    If you could let me know what the VAG specialist say when you get yours back it'll be of great helpp !
    fran-s3's Avatar
    1,075
    Post Thanks / Like
    Quote Originally Posted by benh999 View Post
    Good move taking it to a VAG specialist - I had similar problem few years ago and after I spent £££ changing the MAF, sparks etc I then dropped it off to a VAG specialist and it turned out to be the fuel pump! Be interesting to see what they say about yours - keep us posted hope they find it the problem.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    820
    Post Thanks / Like
    Was about to say fuel pump
    BAM S3, MTM K26 With External Gate, Hayward & Scott Custom Downpipe & Decat, Custom 3" TIP & Jetex, Lots of Silicon & Alloy Piping, Supersize DV, Southbend Clutch & Single Mass Flywheel, WMI, Porsche 6 Pots, 300mm Rears, AH Fabs V2 FMIC and to much more to list
    Power & Torque 335bhp 285ftlb
    My Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    May 2009
    Midlands
    197
    Post Thanks / Like
    Not heard back yet, anyone else have any thoughts on why our cars show these symptoms?
    got an S3 8L: living the dream
    Mar 2010
    Kent
    144
    Post Thanks / Like
    when i had the codes you've got, it was the crank speed sensor on its way out. I dont recall it stuggling through the rev range though. mine was temperature related.....when the car warmed up the crank sensor struggled and the signal faded......so the ecu got out of sync with the intake sensor.....hence throwing up the cam sensor code.
    when this happened, the car went into limp home mode.........eventually the crank sensor gave up on the M2.......tow truck time.
    is yours going into limp home? (EPC light)
    2002 S3 8L AMK
    May 2009
    Midlands
    197
    Post Thanks / Like
    Quote Originally Posted by chazza55 View Post
    No engine management light at all. Doesn't limp, just hesitates constantly, throws up fault codes tho..
    Jan 2012
    West London
    48
    Post Thanks / Like
    Yep same here. Car doesn't go into limp mode but just feels very sloppy and hesitant through the rev range
    www.badger5.co.uk
    May 2004
    nr Glos
    3,851
    Post Thanks / Like
    lean... weak fuel pump sounds plausable..
    I found this on an S3 when loading it on the dyno whilst logging afr's... Instantly confirmed the suspicions.
    Big Brakes, AP Racing, Brembo, Ferodo DS2500/DS3000, Motul RBF660, Remapping, Dyno Tuning & logging, Big Turbo conversions, bespoke fabrication, Race Proven/Winning products and services.
    http://www.badger5.co.uk, Tel:01453822880, Mob:07976 800775
    bill@badger5.co.uk
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Quote Originally Posted by S3LOUD View Post
    Seems people always assume too much.....always check fuel delivery first.
    (advise from my dad - on my first petrol power remote control car...happy days)
    Azure Blue, Pearl Effect
    1.8TQS, KO3s
    3" De-Cat - Straight Through
    Upgraded Coils / NGK / Mobil 1
    Carbonio Carbon Air / Bailey dv26
    Custom Stage 1 Re-map -> chippeduk
    Powerflex DogBone Mounts
    Eibach Pro Kit / ARB
    200 Horses Club
    SUMMER 2012 - KO3 hybrid / Wellycooler / TIP / Injectors
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    149
    Post Thanks / Like
    Fuel pump certainly sounds very possible. Diagnose by measuring fuel pressure. Then I log various lables within the ECU to see what is happening inside, and why.
    Rick
    Jan 2012
    West London
    48
    Post Thanks / Like
    After doing some searching around i found out that the garage who replaced my alternator actually ripped the wire straight out of my knock sensor and thats why it had the issue. After soldering the wire to the connector and got it all hooked up the car is now driving smooth with no more hesitation :D!!!
    May 2009
    Midlands
    197
    Post Thanks / Like
    Mines cured also, again it was a faulty knock sensor, car couldn't read engine speed etc...
    On a big plus note RSD have also fitted my V2 Badger5 T.I.P, the only downer is I don't pick up my car until tomorrow morning :-/
  1. Help needed!..3.2Q DSG Hesitant engine ~ 2k rpm
    By 3.2 Ju in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2011, 22:21
  2. Hesitant Under Acceleration
    By Barks in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 22:55
  3. TDi hesitant/ misfire engine problems
    By DSan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2010, 01:50
  4. More 3.2 woes - Engine Management Light flashing - hesitant acceleration
    By Hellz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2010, 09:11
  5. hesitant acceleration
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th July 2006, 22:30
