Sky InsuranceKowalski
Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By s3 Hoggy
  • 1 Post By sportstractor
  • 1 Post By bez101
Thread: HELP PLEASE!possible fan problem????
    Sm3g's Avatar
    STANDARD S3 (225bhp)
    May 2009
    leeds
    48
    Post Thanks / Like
    evening all
    right lastweek temp gauge started going dodgy and eml light came up,so i changed the temp guage sender and was still getting dodgy readings, so today iv had the thermostat changed as it has been stock open hence the temp gauage giving me daft readings.
    all seems ok and is now going up to 90degrees as normal but its just staying at 90 for ages until the fan comes on even when driving,im pretty sure that usually when i start my engine on a morning the fans kick stright in for the climate control and are always running uless you press the econ button?
    am i right in thinking this should be happening guys as the fans are not working when i start the car anymore,hope you understand what i mean as im not up to scratch on what should and shouldnt be happening,haha???
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    scummybrummie
    1,126
    Post Thanks / Like
    So whats the problem then mate? If its staying at 90degrees then its fine. Fans will only come on to cool it down.
    2002 51plate Audi A3 1.8T sport AUM, Minger blue, xenon conversion, piano black recaros, forge 007p, jet ex filter, cold feed, silly tip. That's the good stuff listed
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    yerh but dont the fans usually start running as soon as you start the engine and the climate control unit kicks in,if you know what i mean,im sure this is what always used to happen??
    Nov 2010
    scummybrummie
    1,126
    Post Thanks / Like
    Quote Originally Posted by Sm3g View Post
    To be fair i cant say iv ever noticed my fans come on straight away from start up, i may be wrong(usually am) but hopefully somone with more knowledge may help out here, but id say your car is fine if it goes to 90 and dosent move, maybe your faulty stat was telling the fans to come on as it was stuck open ? Id pm some of the knowledge gods on here if its somthing thats really bugging you.
    dan_a3quattro's Avatar
    Jan 2012
    50
    Post Thanks / Like
    do u mean when u turn ignition on you here fans come on? if so my car does it now and again donno if it surpost to?
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    yerh mate,usually when i start the engine the air cons fans start running and constantly do unless i press the econ button on the climate controll unit,think this may of not been happening as if iv heard correctly if the temperature is under 5degrees the aircon fans do not engage,
    it might be just me been funny,but when im driving around the temp just contantly sits at 90degrees,even if im driving down the motorway surely with the wind force it shouldnt still show 90degrees always?????????
    s3 Hoggy's Avatar
    Bouncing down the Iffley Road
    Apr 2009
    Oxford
    1,332
    Post Thanks / Like
    I'm pretty sure the engine management tells the temp gauge to just sit at exactly 90 even if the water temp is a few degrees either way, everything sounds normal with what you've said to me mate
    Sm3g likes this.
    bez101's Avatar
    Jul 2008
    3,403
    Post Thanks / Like
    sounds normal
    does your aircon still work ?
    if so alls good
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    yes mate aircon still works and fans run as long as the display does not show the frost icon that is,cos apparently the aircon fan do not run under 5degrees,,,,well thats shut me up then lads just thought it seemed a bit strange it always sat at 90degrees when the engine as warmed but you guys know more than me,so if your happy,then im happy!
    cheers for all your help guys much appreciated as always!!
    sportstractor's Avatar
    Gangsta
    North Devon
    2,403
    Post Thanks / Like
    Yeah it's a thing the vw Audi group do, between 75-105 (or something like that), the gauge will show 90. Presumably to give the impression of quality and to stop over worrying customers bringing their cars into the dealers. If you press recirc and up button then select 49c, it will show the actual engine temp
    Sm3g likes this.
    S3 - Minger AMK - Stage 2 Custom 'R-Tech Powar' Remap - Badger 5 Tip - Welly Cooler - 25mm eibach springs - S4 reps
    "Remember one thing, No matter how pretty she is, Someone, Somewhere is sick of HER SH*T!"
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    ok mate il wait for the car to get up to 90degrees,then il access through the climate controll unit and find out what that says the temp is at,il report back later on with what it says,thanks!
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    right sat in the car and started it up,temp gauge said 60degrees,,so i then did what you said and accessed through the climate control to number 49c,and it brought up the temp and that also said 60degrees,more or less stayed with the in car temp guage as that moved,but when the in car temp needle hit 90degrees,,the number on the climate just sat between 84-85???? this about right ??
    bez101's Avatar
    Jul 2008
    3,403
    Post Thanks / Like
    i think your worrying to much
    as long as it sits at 90 its good
    no car will ever stay at 90 my st sits there but realy its always 86/87
    Sm3g likes this.
    Gangsta
    North Devon
    2,403
    Post Thanks / Like
    Sounds about right...
  1. Need help - Fan Problem !!!!
    By marwayg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th October 2011, 17:07
  2. fan problem
    By MTW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2011, 15:43
  3. Audi A3 fan heater resistor problem - Fan only works on full power!!
    By Blueie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2011, 10:36
  4. Fan problem on the S3
    By RS-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2009, 13:34
