VAG CheckBackdraft Motorsport
    Jul 2011
    middlesbrough
    99
    Post Thanks / Like
    cd player stopped working?
    Hi there the cd player in my a3 has stopped working i changed the central locking pump today then it wouldnt work properly so had to change it all back. I only pulled the cd changer out slightly and couldnt see a plug on the back of it, when i put the cds in it says in the car its loading them then the radio just goes back onto the radio and when i press mode to go onto the cd's its as if the mode button itnt working nothing happens, i have evan dissconnected the battery and put in the safe code again but still the same... Anyone got any ideas?
    Regads Tom
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Quote Originally Posted by a3 1.8t View Post
    Regads Tom
    Possibly earthed it out. Check fuses mate
    Azure Blue, Pearl Effect
    1.8TQS, KO3s
    3" De-Cat - Straight Through
    Upgraded Coils / NGK / Mobil 1
    Carbonio Carbon Air / Bailey dv26
    Custom Stage 1 Re-map -> chippeduk
    Powerflex DogBone Mounts
    Eibach Pro Kit / ARB
    200 Horses Club
    SUMMER 2012 - KO3 hybrid / Wellycooler / TIP / Injectors
    Jun 2003
    World of my own
    9,427
    Post Thanks / Like
    There is a plug, just follow the lead from the changer back to under the rear seatbelt reel in the cubbyhole. It should be clipped to the bodywork, probably just needs nudging back into it's socket
    Alex Turner
    Jul 2011
    middlesbrough
    99
    Post Thanks / Like
    thanks lads will have a look tomorrow, its one of them jobs i started this morning and just thought i wish i left it, trying to get everything back to how it was haha, wish i had just left it!
    Jul 2011
    middlesbrough
    99
    Post Thanks / Like
    it was the cable had come loose thanks andymac!! All working okay now:D
    Jun 2003
    World of my own
    9,427
    Post Thanks / Like
    Wow sometimes there is an easy fix on an Audi! Glad you got it sorted
    Alex Turner
  1. VagCom stopped working
    By iyrix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2011, 21:47
  2. Replies: 3
    Last Post: 12th February 2011, 09:56
  3. Key Fob Just Stopped Working Lock/Unlock not working
    By tomgreen78 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2010, 23:53
  4. go stopped working, then started again. Why?
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2009, 06:52
  5. Its Stopped working?????????
    By Herby1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2006, 13:31
