Badger5JMB Retrofits
Page 51 of 55 FirstFirst ... 41444546474849505152535455 LastLast
Results 2,001 to 2,040 of 2165
Like Tree355Likes
Thread: Stacey's Belated Yo Yo Build Thread
  1. #2001
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Would love to be able to confidently TIG especially ally, have tig welded in the past during my apprenticeship but due to not needing to and lazyness I'd be very rusty and hoe through a lot of tungsten tips lol
    Did contemplate getting some stainless wire but will require getting another bottle of gas (££££) so if DP needs modding ill tack with normal steel wire and get a mate to do it on a tig set
    Car in its new resting spot till further notice
    <tuffty/>, Westy and s3dave like this.
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  3. #2002
    Aug 2011
    Plymouth
    754
    Add Lavis89 on Facebook
    TIG is surprisingly easy, a lot of it just comes down to tonnes of practice, all I do in work is pipe welding with tig, the pipe could be 25mm Wall thickness or 1mm, still use tig for all of it, all nuclear stuff so got to be nice and clean
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
  4. #2003
    RIP S3dave
    May 2004
    nr Glos
    7,175
    she's allowing you to touch your car again?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  5. #2004
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Well it's not like she's going to let him touch her again
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  6. #2005
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Lavis89 View Post
    Tig is without a doubt the nicer form of welding, it's definately all about hours practice playing with settings on the set but have to say I would also be very rusty with MMA and would be constantly getting the rod stuck to the work lol
    May have to buy a set one day and play a bit
  7. #2006
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Westy View Post
    Haha.....I'm fixing things that need to be done like the gearbox as well as sorting a couple of other bits....if some parts like turbos, cams etc happen to mysteriously change then so be it
    badger5 and Westy like this.
  8. #2007
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Did a compression test with a slightly flat battery and it came out lower than I thought it would but at least was fairly consistent
    Pics in order cylinder 1-4
    Spark plugs in order 1-4, number one has quite a bit more of carbon deposited on it
    Sump plug had a bit of a build up on it
    Here is the state of play as was packing up due to darkness setting in
    Can anyone reconmend some plasti gauge to go for?
  9. #2008
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    Could be your cams... have seen this before on wildish cams... artificially lowers comp ratio... can't remember what spec yours are..
    <tuffty/>
    StaceyS3 likes this.
  10. #2009
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by ;2062107
    <tuffty/>
    True totally didn't think of that, cams are suspect for a lot of issues on this build, suppose if opening or closing to early or late would cause it
    Cams are currently catcams 3660 aka bobq purple grind, will be replaced with IECVA1's
  11. #2010
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Plastigauge....
    Does anyone know off the top of their head roughly what the clearance is that am looking for on the bearings? (Will check ELSA later if not)
    This one does from 1-7 thou or 0.025-0.175mm in new talk lol
    http://bit.ly/IsqFRG
  12. #2011
    Scullies's Avatar
    Feb 2012
    Dubai
    1,255
    Plastigauge PL-X precision bearing clearance Gauge,Car,Motorcycle,Aero,Engine | eBay
    The PL-A is probably the better option though.
    afaik the mains are pretty similar clearances.
  13. #2012
    Scullies's Avatar
    Feb 2012
    Dubai
    1,255
    Quote Originally Posted by StaceyS3 View Post
    I tested my compression on a hot engine after about 1000km at all cylinders were around 160psi, I was pretty bummed.
    I recently did another test on a cold engine at the compression is around 190psi across all cylinders - happy days
  14. #2013
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Scullies View Post
    Cheers for the info and link mate
    Stupidly I plastigauged the last engine as was a used crank but as everything was new in this I never bothered....fail lol
    Mine was as cold as can be when tested, had sat for 4 months without turning lol
  15. #2014
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Got a little more done this afternoon
    Finished pulling the loom out and draining fluids, although was quite shocked and dissapointed at the state of the hard pipe and block
    Pretty much all that's left is the DP but I want to pull it with as much of it attached as possible as will weld some support brackets to it as if need to cut the flange off to reposition I know exactly the position of the dp for adjustments
    Not much left with the subframe either as got another subframe and 2 driveshafts to go in, will also have to replace a track rod end as the nut picked up causing me to have to cut it off with the angle grinder
    State how I left it at the end of the day
    Can anyone reconmend tape to use on the loom as the insulation tape I used last time has just come off
  16. #2015
    Aug 2011
    Plymouth
    754
    Self-amalgamating tape - Wikipedia, the free encyclopedia
    can get it from quite a few places, can also get coloured tapes that people use on silicone hoses
  17. #2016
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    Heat shrink the lot. But that means taking all of it out to do it.
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  18. #2017
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Cheers guys it's always worth an ask as so many **** products out there
    It has already been heat shrunk on some individual cores where has been spliced and may be able to get some 3-1 ratio heat shrink over some of the plugs but will have to go with tape for the rest
  19. #2018
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    Use 3m cloth tape. Oem type finish and loom is still conformable
  20. #2019
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Broken Byzan View Post
    Cheers mate don't suppose you have a link as when searched on eBay I keep coming up with duck/gaffer tape?
  21. #2020
    Apr 2004
    12,521
  22. #2021
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Cheers mate will grab some
  23. #2022
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Anyone able to give any feedback on these track rods and ends?
    http://bit.ly/1c608Fz
  24. #2023
    Apr 2004
    12,521
    Generic product, for your power level etc, i'd get Meyle or Lemforder as they tend to be OEM +
  25. #2024
    RIP S3dave
    May 2004
    nr Glos
    7,175
    that hard pipe is nicked off another engine, as yours was perforated from corrosion...
    did you paint that block? let me know what paint so I know what to avoid - lol
    www.badger5.biz
    bill@badger5.co.uk
  26. #2025
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I've been looking at those track rods as well stacey, I emailed the seller to see what make they are and they replied with a company from doncaster that I've never heard of before.
  27. #2026
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Cheers for the responses guys
    May just buy one decent track rod end to replace the knackered one then
    Just saw the set on eBay and thought about replacing the lot as they're all still the originals afaik
    Will name and shame the paint lol
    But iiirc you painted the pipe? Is g12 very corrosive as had a lovely coolant leak during its short life back on the road
  28. #2027
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,785
    I got Meyle ones from ECS. Lemforder would be nice but mega money compared and my Meyle ones seem ok so far.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  29. #2028
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Whats power got to do with track rods....
    superkarl likes this.
  30. #2029
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,372
    Car is more likely to be driven hard, and at higher speeds, so wear and tear is likely to be accelerated on this car, compared to an estate agents wife who uses her S3 to go shopping.
    Cheap product might last 5 years on miss daisys car and seem perfectly suitable, with Stace at the helm and regular abuse it might only last 6 months, so less acceptable
    simples
  31. #2030
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its a a threaded bar that wont know if its steering 500hp or 100 hp, track rod ends of course may see a bit more action..
  32. #2031
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,372
    I was under the impression that we were talking about the ends, but the track rods themselves also have a ball and socket joint at the end, which will take just as much load as the track rod end I'd think.
    I know I'd certainly want only the highest quality joints at either end. OE track rods are SO expensive though!
  33. #2032
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Can definately see the sense I'm buying a higher quality item with how hard will be pushed (although limited millage) but wasn't sure if "cheaper" brand ball joints were that poorer product?
    I only need to replace one end where had to cut it off after the nut picked up, but wondered if the set was a reasonable product would it be worth replacing the lot
    Been working on the mrs a bit more on the buckets and rollcage, I keep pointing out that it's the most sensible mod ever wanted to do as safety related
    but digging her heals in on this one is an understatement lol
    Maybe next winter will get fully stripped
  34. #2033
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Oooo may have just bought a new (second hand turbo)
    <tuffty/> and Andrew@A.L.D like this.
  35. #2034
    Jun 2009
    Leeds
    3,470
    You got that one then? If so its a bargain
    Welcome to the GT35 family mate
    FOR SALE
  36. #2035
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Andrew@A.L.D View Post
    Maybe
  37. #2036
    Jun 2009
    Leeds
    3,470
    Maybe
    Just had a look and its been sold
    FOR SALE
  38. #2037
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Not sure if I'd know anything about that
  39. #2038
    Jun 2009
    Leeds
    3,470
    All hush hush then
    FOR SALE
  40. #2039
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Not at all but will wait till it's actually mine in my possession.....then it's truly mine
    Really shouldn't spend money when rather intoxicated lol
  41. #2040
    Lewis583's Avatar
    Mar 2010
    872
    On the contrary Stace, sometimes the best things are bought after some drinks. Look at Prawn, he bought his CAE shifter while drunk and now he loves it haha.
    Looking forward to updates chap.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. My build thread....
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2014, 20:58
  2. A4 Build Thread
    By AudiSport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th September 2011, 09:45
  3. My Build Thread
    By Triple.O.G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 20:36
  4. A4 Build Thread
    Last Post: 20th November 2010, 22:14
  5. My Build Thread....
    By L0WRiDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 20:28
