EM TuningMonster Motorsport
Page 37 of 53 FirstFirst ... 2730313233343536373839404142434447 ... LastLast
Results 1,441 to 1,480 of 2108
Like Tree328Likes
Thread: Stacey's Belated Yo Yo Build Thread
  1. #1441
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Ah... bugger... didn't think of that LOL... I asked Bill to weld mine...
    Ah well... it is due to be modded to feck anyway
    <tuffty/>
  3. #1442
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,066
    Quote Originally Posted by StaceyS3 View Post
    Cheers mate
    Think its definitely worth running an afr gauge when got so much at stake
    I got this, i know its egt but you can add modules to it and its touchscreen..
    PLX DM-6 Multi Gauge with Exhaust Gas Temperature Sensor Module SM-EGT | eBay
  4. #1443
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Quote Originally Posted by ;1878467
    <tuffty/>
    Due to be modded to feck anyway....you rearanging some hotside components?
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  5. #1444
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Cheers Dave am looking at lots of options at the mo....ideally want boost, AFR and oil pressure...oil temp would be nice but dont want to clutter to much with gauges
    If going the gauge route im thinking of either making a triple gauge holder to go in the gap below the radio and getting rid of the cubby hole or other gauge route would be the double steering column mount like Andrew
    It all swings on wether I can find some gauges I like the looks of as stack dont do a mechanical boost gauge that goes over 2 bar and of coarse got to wait and see what it will happily run at boost wise
  6. #1445
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    Lovely cheers...cant believe they make them to order?
    Hoping that if 3.5" is possible it will aid spool? Although I'm sure the 3" cat back should also help?
    Knew there was something else meant to ask you on the phone earlier. ... would you be able to put an extra lambda bung in as will be putting an afr gauge in once have decided a brand of gauges will be using (as want it to match the boost gauge once we see what boost range will be needed)
    cat? Am I fitting a cat? I will make a removable section for either front silencer OR cat.. Is that what you want?
    let me know dude
    cheers
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  7. #1446
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Picked up my old block and head from my local machinists and they confirmed my suspicions
    The block on the back corner of cylinder 1 by the oil feed was 5 thou lower than the rest of the block deck, this will definately be the reason why I kept having oil leaks from there after the rebuild until I used gasket sealant (which im not proud of lol
    Just got to reasemble this weekend all being well then it will work its way on to gaybay
  8. #1447
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    Gayboy? Who's having this then Stacey?
  9. #1448
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,170
    Says "gaybay", so I'm assuming eBay
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  10. #1449
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Yeah sorry will be making its way onto ebay lol
    Have got to try and claw as much £££ back as possible from selling bits now
  11. #1450
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    oh yea, so it does.
    I'm so used to seeing people refered to as Gayboy, that I assumed you'd sold it to Karl
    StaceyS3 and Scullies like this.
  12. #1451
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    oh yea, so it does.
    You been on Vag Talk again?
    <tuffty/>
  13. #1452
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    Hey mate, I just realised you're not running a girdle. Did you consider it? David Blais (owner of IE) added me on FB today and I had a chat about the spec for a 500hp build and he mentioned the girdle. He said the billet main caps are for pretty serious builds so might be a bit much but they do mean a bit less machining to fit the girdle. I'm thinking I'll get one for my build but leave the main caps standard.
    I finally got some specs for mine out of the guy doing the build:
    + 1mm Ferrea exhaust/inlet valves
    Ferrea spring + retainer kit
    JE 83mm pistons
    TFSI crank + oil pump
    IE rifle drilled rods
    IE inlet
    Wavetrac diff
    ...and I'll be ordering an IE girdle, forge baffled sump, Hemi TB, IE rail, timing belt gear + dowel pins, manual tensioner and the fluidampr like you. Not cheap eh? Not sure what else to get?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  14. #1453
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,462
    oh yea, so it does.
    cheeky git!
    im not joking, i was going to say the same thing to you last night lol
    StaceyS3 likes this.
  15. #1454
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Quote Originally Posted by Sam_ View Post
    JE 83mm pistons
    IE inlet
    Wavetrac diff
    Thats a wicked spec mate....not sure if a girdle is needed but it certinally wont do any harm
    A set of cams would really set it off, but cant think of much else engine spec wise?
  16. #1455
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    girdle is also going to lower the sump, unless you get this one.......
    https://www.facebook.com/photo.php?f...type=1&theater
  17. #1456
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Sorry only just seen this....that looks like another lovely bit of kit from IE
    Well the misses has eventually started to understand that a decent bucket seat and harness's are worth having for safety (well sort of) and ive gone ahead and bought one
    Will post up pics in a bit....
    Jason.s likes this.
  18. #1457
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Posted in here just for reference
    I found some interesting info on my turbo eventually as never been able to find much, not sure if its the exact wheels but seems like the bigger comp and smaller turbine are pretty close size wise (within half a mm but will check part numbers when near the turbo)
    Looking at the comp map I must of been getting nearly every ounce of air out of the comp wheel possible
    It seems they do also a bigger turbine with the exducer being pretty much same size as a gt30 where as mine is neary the same exducer as a gt28 im comparison
  19. #1458
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    teaser
    bill@badger5.co.uk
  20. #1459
    Westy's Avatar
    Dec 2008
    17,170
    teaser
    Bloody hell bill I didn't realise you'd started fabricating sex toys!
    burns3 likes this.
    S3 Build Thread
  21. #1460
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    teaser
    The taper on that looks like a brilliant match to the tial outlet and should flow lovely
  22. #1461
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    yea, lucky that.
    fluke
    material is 316l stainless dairy pipe bends.. perfect finish, mandrel bent.. lovely to work with.
    bill@badger5.co.uk
  23. #1462
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Pretty sure ive said it before but will look like a work of art once finished
    It feels a shame to cover up lovely bits of engineering like the mani and the downpipe will be with heat management items like wrap and ceramic
  24. #1463
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    The dairy bends are pretty awesome. I had an inlet manifold fabricated using them yonks back. Awesome quality.
    Get it finished already
  25. #1464
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    and there's a teaser..... 4" out of turbo, transitions into 3.5" which will just fit past prop, and then into 3" for rest of system
    and into 3.5"
    and some figures showing the relative cross sectional area differences between 3", 3.5" & 4" tubes
    Code:
    Tube	diameter	radius	pi	CSA ^mm
    3"	72.7	36.35	3.1415927	4151
    3.5"	86	43	3.1415927	5809
    4"	97.5	48.75	3.1415927	7466
    A slight pause whilst ordered 3.5" vband clamps arrive... so the downpipe can be actually installed, in 2 pieces.
    <tuffty/>, StaceyS3 and Gizmo20VT like this.
    bill@badger5.co.uk
  26. #1465
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Nice work Bill
    Where is the external waste gate going to meet the down pipe?
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  27. #1466
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Stacey's going screamer pipe FTW
  28. #1467
    Gizmo20VT's Avatar
    Jun 2012
    289
    Quote Originally Posted by Scullies View Post
    Haha, Im not sure there is a choice when you run 4" DP.
    Awesome work Bill!
  29. #1468
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    Quote Originally Posted by Andrew@A.L.D View Post
    Nice work Bill
    somewhere after the prop, and I think its going to pass the other side of the prop looking how things sit... stupid tight as you know..
    external gate pipe will be 50mm tube also.. same as my ibiza.
    bill@badger5.co.uk
  30. #1469
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Looking brilliant Bill didn't catch the second pic last night, looks tight
    Yeah of coarse screamer pipe straight out of the bonnet lol
  31. #1470
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Only joking on the screamer, not sure how bills planned it as of yet but sure it will be shoe horned into a gap in the tunnel somewhere
    I forgot to put up pics of the new bucket seat...
    Another with the little one
    It should hold her nicely in the S3
    But for some reason the Mrs still cant (want to) accept that i'd be safer with buckets, harness's and a cage...one day maybe?
    superkarl likes this.
  32. #1471
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,532
    Wow that downpipe I saw on FB and looks sexy. Can't wait to see what this runs like! And that recaro seat is ace lol!
  33. #1472
    burns3's Avatar
    Jun 2011
    221
    You may be safer with bucket seats, harness and a cage but would you be safe from the mrs if you went out and bought them is more the point lol
    Booooooosting just a little bit
  34. #1473
    Jun 2009
    Leeds
    3,353
    You will beat my old figure of 531 bhp I bet by the looks of it
    FOR SALE
  35. #1474
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    just how small does a 3" pipe look next to its bigger brothers! wow!
    bill@badger5.co.uk
  36. #1475
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,462
    dunno about you but if i had a 3 inch pipe or more id be pretty worried
  37. #1476
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    lost me
    bill@badger5.co.uk
  38. #1477
    May 2010
    Bedford
    2,877
    Talking about his wang Bill lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  39. #1478
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Would love to think so but will have to wait and see....
    The more i look at them pipes the more i cant believe its going to fit in that space stricken engine bay, think it should flow very nicely and hopefully spool reasonably quickly
    Lol at the rest of you guys
  40. #1479
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,462
    Quote Originally Posted by Jason.s View Post
    wang? pipe, i mean arse! 3 inch pipe is suspicious!
  41. #1480
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,462
    what engine mounts do you have? gonna need to be pretty solid in there
  1. My build thread....
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2014, 20:58
  2. A4 Build Thread
    By AudiSport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th September 2011, 09:45
  3. My Build Thread
    By Triple.O.G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 20:36
  4. A4 Build Thread
    Last Post: 20th November 2010, 22:14
  5. My Build Thread....
    By L0WRiDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 20:28
