Badger5EM Tuning
Page 31 of 55 FirstFirst ... 2124252627282930313233343536373841 ... LastLast
Results 1,201 to 1,240 of 2165
Like Tree355Likes
Thread: Stacey's Belated Yo Yo Build Thread
  1. #1201
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    The return lines are usually equal or sometimes smaller than the feed as some of the fuel is consumed by the injectors and the fpr acts as a restriction
    There has been some cases where the return can't flow the amount that can be supplied and this will create uncontrollable fuel pressures
    There's some that run -8 feed with -6 return with no issues and think bill is running this iirc?
    Think I may just stick to -6 if I can find a -8 oring male to -6 male adaptor in the UK as not been able to find one this side of the pond
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  3. #1202
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    I was going to say, if you have more fuel going back to the tank then you've got an awesome engine, you'd never need to fill up! You'd be giving fuel away haha
    Just get fittings from abroad, they're dirt cheap in the US. I'm sure over there, like here, you get ripped off for fittings.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  4. #1203
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    Mate I found some brakes for you...
    Audi R8, RS5, RS4, S5, S4 Ceramic Brakes Brake Kit 380 x 38mm - BRAND NEW | eBay
    I mean, they're probably not as good as some LCRs but still...
  5. #1204
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Cheers mate but the brakes are a tad over budget lol although they do look sexy but I'd also want a car attached to them for that price
    Will have to order the parts from the states I reckon, as got to order some adaptors to go from oem lines to AN yet anyways
    I may just install it with the current set up for now (044 inline and standard fuel rail) to save on some ££ and see how it holds up?
  6. #1205
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    Stacey, have a chat with Bill if you haven't already... he did all the calculations for fuel line size on the Ibiza...
    IIRC the oe fuel line size is fairly capable but not sure what the cut off is, you want to keep the return fairly similar else it could 'add' fuel pressure if restrictive especially at idle etc..
    <tuffty/>
  7. #1206
    RIP S3dave
    May 2004
    nr Glos
    7,197
    Quote Originally Posted by StaceyS3 View Post
    Speedflow
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  8. #1207
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    You checked eBay? I got most of mine from there. Aeroflow/Speedflow/Earls etc, all much of a muchness. I ordered some Fragola AN -10 hose today for my new breather setup. Meant to be pretty good but all I could think of was fraggle rock.
  9. #1208
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Have now sent an email to speedflow to see what they come back with but if all else fails I will have to get them from the states
    Here's a link to some on summit racing
    http://m.summitracing.com/parts/sum-220167b
    Have had a look on eBay and in various uk suppliers online shops and can't find one to just click to buy
    Am going to get my hands on a mk4 washer bottle and see how much room that frees up as I don't need the windscreen washer pump (although am currently utilising it for the intercooler spray which I'm not fussed if I loose)
    I ideally would like to mount the surge tank under the bonnet but the spare wheel well is an option but I do like the security of having the spare as have had to use it a couple of times
  10. #1209
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    I used Summit racing for my new air/oil seperator, they ship out quick but they use iParcel who're a little ropey apparently. I should get my bits from them soon so I'll let you know.
  11. #1210
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    To clear one thing up I didn't know that fittings with the flare on the end still have the same dia and pitch thread as there straight cut o-ring designated counter parts and only need an o-ring fitted to them to be used in this manner so this means there's plenty of fittings about I just didn't know could be used like this....(hope that makes sense?)
    I've been having a browse about at oem looking boost gauges that read a bit higher than the stack as may be needing the extra range because everywhere I keep reading says that this turbo is designed to and needed to be run at higher pressure ratios to get good results due to the design of the comp wheel? Would also feel more comfortable being able to see if it is boosting much higher than what it should do?
    Anyhows I would ideally also like to run an AFR gauge and oil pressure
    Ideas were to use a steering column mount like Andrew
    Possible make something to go in the cubby hole below the stereo, on top of the dash above the central air vents and even considered mounting them on the A pillar?
    I did stumble accross this very OEM looking gauge solution which looks quite interesting and although is dear once you factor the cost of a reasonable AFR gauge I don't think it's to bad?
    http://www.getste.com/store
    What's your guys thoughts?
  12. #1211
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Well was really hoping to get my brakes sorted but my pads havent got here yet
    Heres a pic of the setup bar discs and pads
    Hopefully my pads should be here start of next week then i can have some brakes that can be used aggressively again
    Caught up with my friend who helped me build the engine thats in the car currently and talked about our cars....as usual
    His build is looking really quite interesting with some different ideas so thought although not related to mine i'd post it in here and share it anyhows
    The car is a celica gt4 which hes trying to get almost as light as possible without spending stupid money on carbon fibre etc, hes even gone to the length of removing the underseal on the chassis to bring weight down, he will be running a K27/K26 hybrid to start with then will be putting an EFR on there
    The main bit that interested me though was that he's having throttle bodies on a turbo charged car??
  13. #1212
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Throttle bodies on a turbo engine is nothing new, An old friend of mine did it about 15 years ago with his Fiesta Turbo
    Mountune ( The guys that built Fords Rally engines ) also fitted them to the WRC Esocort cosworth and Focus WRC engines
    Its kind of a strange sound also but i was told they can be a bi*ch to map
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  14. #1213
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    Shouldn't be any harder should it? Getting them balanced might be tricky though with the plenum on. Looks like there's vacuum ports on the first picture though. They were standard on RB26's I think.
  15. #1214
    Jun 2009
    Leeds
    3,472
    Yes they are standard on RB26 but most are swapped to a single T/B when they get to a level of tune.
    I have no idea on mapping them with ITB's but was told by my mate 15 years ago it took longer to map?
    FOR SALE
  16. #1215
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    I'm not entirely sure what his plan is but know he's going standalone and said he's going to map it on an engine dyno
    I'd just never heard if ITB on a turbo car but I am pretty new to engine tuning and modding
    Funny you should say about mountune as I used to walk past them every day as a kid to school lol
  17. #1216
    RIP S3dave
    May 2004
    nr Glos
    7,197
    Roller Barrel bodies on that Mountune engine... Hmmmmm Nice..
    Whats the branch thing on the Toyota Stacey? A NOS or air injection manifold or something?
    www.badger5.biz
    bill@badger5.co.uk
  18. #1217
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    It looks like some sort of cold start valve on there?
  19. #1218
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    I was curious about that and when asked he said its an idle control valve but can also be used for anti lag as i think it would be difficult on dbc...when he explained it, it all made sense but had never seen or heard of anything like it
  20. #1219
    Jun 2009
    Leeds
    3,472
    The only problem i see with your mates set up is that he is using spun aluminium trumpets. I have seen someone use them on a turbo engine with over 30 psi at the plenum he ended up bending/crushing the trumpets from the force of the boost hitting them. That was are theory anyway so we swapped to some cast ones like i have in my plenum
    FOR SALE
  21. #1220
    RIP S3dave
    May 2004
    nr Glos
    7,197
    force of the boost bending crushing them?
    Mega thin spinnings surely........ yowza
    www.badger5.biz
    bill@badger5.co.uk
  22. #1221
    Jun 2009
    Leeds
    3,472
    It was them thin spun cheap ones found on ebay
    FOR SALE
  23. #1222
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Bloody hell that sounds mental being able to distort and break trumpets through boost
    Had planned to change my brakes over yesterday.....I got cracking on the task at hand but had completely forgotten that I had cut down the carrier bolts for the 18z caliper carriers so wasn't able to fit the 996TT calipers I could have gone and got some cap head bolts for work but they'd rust badly and not something I'd wanna do and forget about
    On a plus note I fitted the discs which has made a massive improvement as can now use my brakes again
    You can really see the quality difference between the semi 2 piece oem discs and the cheap EBC ones.....cheers for sorting them out jase
    Have to say I think I will miss the 6 pots as they look rediculous lol but the 4 pots are quite a reasonable size
    Couple of pics of the coolant flange finished
    Fitted to the block with an old cts
    I've bought lots of alloy piping for the charge pipes as should hopefully be doing as much as possible in hard pipe
    I've gone for 63mm hotside and 70mm Coldside and am planning on replacing the elbow directly off of the cooler with 70mm but this will need some shaping adjustments to fit in the bumper gap and to match the cooler which is 63mm thick
    Jason.s and Sevv like this.
  24. #1223
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Mate those 6 pots looked too big IMO. Makes the car look like a tonka toy with 19" wheels too. The 4 pots look lovely and fresh, and I also like the Porka stickers. Looking good.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  25. #1224
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Great work on the coolant flange, fit and forget for sure...
  26. #1225
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Am hoping that these calipers will perform better by using a smaller pad (although still pretty large) making it a bit easier to get heat into them, the 6 pots do look bit on the large side suppose like the 19's do but the inner child loves them
    I do keep looking at dropping to 18's and possibly will do in the near future
    Cheers Dave that was my hopeful plan as am on my 3rd plastic one now
    Although the main reason for it was so I can use AN fittings with stainless braided hose to the bulkhead as was concerned my wastegate and mani may just melt rubber hose?
  27. #1226
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Have been doing a little thinking and have come up with a couple more ideas for the surge tank
    Could relocate the expansion tank to the passanger side fitting the surge tank in its place and re-route the coolant lines one of which already originates from that side next to the head in the plastic fitting that goes to the rad and the other will just have to weld a hose tail on the coolant hard pipe that runs round the block
    The other option is to fit the surge tank on the passanger side but will be PITA to route the fuel pipes over there avoiding hot things?
  28. #1227
    Jun 2009
    Leeds
    3,472
    under the battery tray?
    FOR SALE
  29. #1228
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    What about the area where the smic sits? Under the light?
  30. #1229
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    put it here:#463
    Sam_ likes this.
  31. #1230
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    Quote Originally Posted by Westy View Post
    Unfortunately dislike has been removed
    They look way better shoe horned behind nice wide 17s 4 pots are for girls
  32. #1231
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Had considered mounting it in one of the original Smic locations but had been worried of it being vulnerable in event of a crash, but looking at Karl's link it looks like I may be a bit more protected than first thought?
    May be a bit of a squeeze with the washer bottle there but it's another option I could try and work
  33. #1232
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    there may be a possibility you could put it on top of the chassis leg, i cant remember off hand what goes on and around there.
  34. #1233
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    If you make any brackets or anything, remember to make 2 sets
  35. #1234
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    It's all rather tight round there as was having a good look this afternoon
    I've got a mk4 washer bottle coming from a friend at a scrappy as when was measuring up the IE inlet vacuum take off and IAT are mounted right where the boost pipe runs so hopefully the smaller bottle should give me some room
  36. #1235
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Sam_ View Post
    Cheeky bugger
  37. #1236
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Boots all loaded up with lots of tools and bits and bobs for the up and coming week
  38. #1237
    Westy's Avatar
    Dec 2008
    17,283
    It's bound to rain all week now if you're doing work on your car. I remember last year...
    S3 Build Thread
  39. #1238
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Yeah it would just be my luck, but this is **** or bust as been told a moving date is start/mid June so got to get my arse in gear
    Here's the forecast although it tends to lie in the typical English way
    Have booked this week off to really crack on...although think I'm still going to have to go in for a shift or 2 which may slow it down
  40. #1239
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,612
    Have been doing a little thinking and have come up with a couple more ideas for the surge tank....What's your guys thoughts?
    Boot...
    <tuffty/>
  41. #1240
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    It's getting closer to possibly doing that but am more concerned about the safety side now due to the little one as could never forgive myself if the worst should happen and believe it or not the s3 is our main family car lol
    I may just see how the 044 copes inline for now with AN line to the fuel rail from the oem connectors as am quite set on keeping the spare and to be honest I've run out of money and braided hose is bloody expensive lol
  1. My build thread....
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2014, 20:58
  2. A4 Build Thread
    By AudiSport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th September 2011, 09:45
  3. My Build Thread
    By Triple.O.G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 20:36
  4. A4 Build Thread
    Last Post: 20th November 2010, 22:14
  5. My Build Thread....
    By L0WRiDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 20:28
