EM TuningVolks Autos
Page 28 of 54 FirstFirst ... 1821222324252627282930313233343538 ... LastLast
Results 1,081 to 1,120 of 2160
Like Tree351Likes
Thread: Stacey's Belated Yo Yo Build Thread
  1. #1081
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Ahh spot on.....what a numpty lol
    Haven't tried them on the mani yet but the sleeves/spacers do come off and just turn them into the small port ones lol
    When I ordered them I just ordered the largeports as I knew some small port injectors you can't get to fit the largeport bungs (like my MTM ones) an worst case senario would turn a couple of fuel rail spacers
    Looks like worry solved
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  3. #1082
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Is a lot better with the spacer cups removed
    Although not completely happy with how far the o-ring sits in the fuel rail so may just take a couple of mm off of the mounts to make it sit lower?
    The injector nozzle position looks 100 times better (pics aren't to brilliant on the iPhone)
  4. #1083
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    I managed to dissapear for 20mins yesterday to the carpark and quickly whipped off my phenolic transition spacer to be ported for the new engine, am now running my small port mani direct onto my largeport head which isn't ideal but it'll do
    To my supprise the IE inlet mani runners are ever so slightly bigger than a largeport gasket, I roughed out the spacer with a carbide burr then bolted that and the gasket to the mani to port match it
    You can see where material has been removed off of the gasket, it only seemed to be the outer side of each port if working from the center of 2 & 3?
    I have removed the lip with a de-burrer as didn't want it to effect the seal
    Pics with the gaskets on after matching the other side to the head and a close up of the lovely porting which Andrew@A.L.D done
    Nice velocity stacks
    Still fits in the cupboard, although its getting tighter
    Started to make a heatshield (utilising Prawns CAD techniques) to protect the rocker gasket and coil pack wiring by deflecting and channeling the hot air away
    Homemade bender using some plate and box section
    It will have some more trimmed off of it and some more bends
    Not sure whether to cut it down to just over the rocker gasket height or to try an bend it to shield the turbo and downpipe as had originally planned?
  5. #1084
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    looking very good indeed mate! Is the engine fully assembled now then? I had somehow missed that bit!
    Any ideas when it's all likely to find it's way into the car?
    As for the injectors, rather than machining down the rail, could you not use the spacers as intended on top of the injectors and space the rail up a few mm?
  6. #1085
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Cheers mate
    All is pretty much assembled exept cams and belt as was waiting for cams and followers from the states
    Will all being well be putting the followers and cams in tommorrow (have been waiting for followers to soak in oil for a couple of days) my agn head should have been here by now but won't be till next week now so am waiting for the vvt unit and a spare rocker so can mod mine
    Once I'm pretty much done ill take it to my friend to do all the turbo lines, plan is to do as much as poss in hard lines near the turbo
    Then as far as I can think of its ready to go in which hopefully will be doing mid/end of march, which will allow me to make up the charge & Tip pipework, install and plumb the surge tank and then trailored to Bill when ready for downpipe and mapping
    The only thing which will dramatically change it all is if we are excepted for this house....waiting to find out today as its between us and another couple
  7. #1086
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Well as much as I hate to say it I think the car will be put on hold with regards to anything that costs money.....as we have just had confirmation that we've been accepted for this house which is fcuking brilliant
    At least I can now have a man cave/workshop as has got a garage
  8. #1087
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Nice one! Couple of calendars from work and you're in business. Jealous mate.
    StaceyS3 likes this.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  9. #1088
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    HOUSE PARRRRRTAYYYYYYY!
  10. #1089
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    I want a house :'(
    Congrats mate!
  11. #1090
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,772
    Cracking news! This build with your own garage will be epic
    <Jay A3 build thread>
    241bhp K03s - R Tech
  12. #1091
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Cheers for the kind words guys am over the moon
    It only was advertised last wed as a part buy part rent with 25% starting share, viewed it on sat, which was narrow to 2 on Monday and we fcuking won
    Don't worry there will be a house warming party as soon as we get it before it gets decorated (is pretty disgusting and carpet is held down by duck tape in some areas, but at least wont have to worry lol) and shouldn't have to worry about neighbours to much as is detached
  13. #1092
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    You'll have no money left for the car now mate. My house is draining all my car funds
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  14. #1093
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    It's a bonus I have bought pretty much everything now, the only big expenditures left are downpipe and mapping
    At least it will release funds selling the old engine and turbo kit
  15. #1094
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Managed to get a few bits done at work Saturday, although not as much as would have liked to, as had hoped for a quieter day but can't complain really
    Like a muppet I spent a good couple of hours in the morning researching degreeing cams to find out they're preset and marked up lol
    Fitted the new lifters after having them soaking for a couple of days
    Had to turn a tapered sleeve to aid getting the camshaft seals on as would have had to force them on a bit possibly damaging them in the process
    Once had got the seals on I torqued up the cam pulley bolt and also the trigger wheel on the inlet cam, this required holding the cam firmly in a vice but used 2 thick blocks of plastic each side of it to not damage it as iirc the arp cam bolt has to be torqued to 55ftlb
    I managed to get the exhaust cam in but run out if time to finish off with the inlet and the timing
    I fitted the injectors with the injector spacers on the top and it now fits lovely with small fuel rail spacers, will see how it all lines up with how I want my breather system to be
    Goubo1 likes this.
  16. #1095
    RIP S3dave
    May 2004
    nr Glos
    7,139
    nice progress Stacey
    those ports not so much ports as caverns
    this is going to be mental... :D one day
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  17. #1096
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Check the bolts on the vernier cam sprockets (inlet iirc) for clearance on the VVT unit mate... had to 'machine' a little off the VVT on an engine Bill had in as the bolt heads contacted the VVT unit and undid themselves!
    <tuffty/>
  18. #1097
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Dude you're going to join Andrew's 'elite club' soon. How do you feel?
  19. #1098
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by Sam_ View Post
    Is that the skint club?
    S3 Build Thread
  20. #1099
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Cheers Bill really can't wait to hand it over to you
    Was thinking tthee other day am i going to need a new boost gauge as mine tops at 2 bar
  21. #1100
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    <tuffty/>
    Cheers mate definately don't want that happening, will check when i get this AGN head in the next couple of days as iirc theres 2 slightly different casting shapes depending on age?
  22. #1101
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    What is this 'elite club'? The skint club as westy stated.....i'm without a doubt a member of that club
  23. #1102
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Quote Originally Posted by StaceyS3 View Post
    A guy with a Golf R here runs 42psi on his GTX30 ! Mental.
  24. #1103
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    His 'elite' 500bhp+ S3 club or something in his sig
  25. #1104
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Stacey is already in the 'elite' club if it means the engine is in bits ;P
    <tuffty/>
  26. #1105
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    That's mental! I'm pretty sure we won't be punching that high lol
    Should hopefully pass that magic number but will wait and see....time will tell
  27. #1106
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Quote Originally Posted by ;1805284
    <tuffty/>
    That's what it's all about...having the engine in bits
    Is it bad that this engine will probably be the third type of each engine component in this shell since I've owned it lol
  28. #1107
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    <tuffty/>
    YESSSSSS, im part of a club
  29. #1108
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    The engine may have to go in sooner than i thought
    Where i changed the coolant flange on saturday i rearanged the pipes that go to the rad as they seemed to be putting excess strain on the flange which could have caused the gsf on to fail in under a year?
    I must have forgot to put the hose clamp back on.....bloody muppet
    I was out for a "pleasure drive" after the gym and on the way home the coolant level warning came on, didnt think to much of it as have got used to keep topping it up due to the leak and just thought as its the first time its been up to temp since changing the flange an air lock must have cleared (also liquid was giving normal coolant temp readings)
    So drove home last mile or so to find once stopped there was steam coming out of the bonnet
    Popped the bonnet to find coolant all over the bay where the 3way hose to the rad had come off and it was boiling off of the head where it was rather hot
    Have topped the coolant up and fired it up and all sounds and seems ok except coolant temp was sitting around 105 degrees but assume thats just because everything was still pretty hot?
    Poor pic and cant really see a lot but here it is anyways
    Test will be tommorrow as will take it for a drive and see how it behaves?
    Hope have got away with it?
    Anything anyone can suggest can suggest to check or do?
  30. #1109
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,454
    LOL i'm sure he will be in the elite club its also the skint club and in bits club
    I'm also starting a new club of bent a wrist pin club
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  31. #1110
    Jun 2009
    Leeds
    3,454
    Thanks Bill, I bet it will beat mine in peak power
    FOR SALE
  32. #1111
    Jun 2009
    Leeds
    3,454
    <tuffty/>
    That reminds me i need to change my sig
    Job done
    FOR SALE
  33. #1112
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Quote Originally Posted by Andrew@A.L.D View Post
    Not to sure about that mate, although would love figures like that
    Lol at all these clubs that are forming
    Just looked at your sig...haha brilliant
    Have been looking into arp studs the last couple of days as I've got oem ones in the new block
    Makes me also wonder if its worth trying to tac weld my trigger wheel bolts in situ?
  34. #1113
    Jun 2009
    Leeds
    3,454
    Main studs are on the cards and will be tig welding the bolts in place and the bolt for the oil pump
    nord locking the fluidampr in place now as they worked them selfs loose too
    FOR SALE
  35. #1114
    Jun 2009
    Leeds
    3,454
    And I've still got to get my 1600cc injectors ordered as I had to put them on hold, how wa the service from the place you got yours from?
    FOR SALE
  36. #1115
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    USRT were very good service, speak to Quintin on vortex is probably the easiest way
    Think I may try and put a welding blanket around the area and put a couple of squirts with the mig on the trigger wheel?
  37. #1116
    Westy's Avatar
    Dec 2008
    17,264
    I think you boys are starting to stretch these engine WAY beyond what they're capable of. Might be time to start the Turbo'd 3.2 V6 club
    S3 Build Thread
  38. #1117
    May 2010
    Bedford
    2,877
    You`re getting bad telling people what to mod next! lol. Think we need to start pressuring you into spending more money and time on the car again and not on wall paper and fabrics
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  39. #1118
    Westy's Avatar
    Dec 2008
    17,264
    Quote Originally Posted by Jason.s View Post
    Mate, you know where i'd rather spend my money! Unfortunately priorities change when you buy a house, as Stacey shall soon find out
    S3 Build Thread
  40. #1119
    RIP S3dave
    May 2004
    nr Glos
    7,139
    Job done
    bent wrist pin? wow Tool Steel JE ones next?
    what cyl pressure was that running at I wonder?
    extra stroke loading do you think maybe? some acute rod angles on the big crank....
    bill@badger5.co.uk
  41. #1120
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Quote Originally Posted by Westy View Post
    To be honest I had wished 6 months or so ago that I had done a 3.2 but was in far to deep at that point
    I'm sure we can try and keep pushing them but more and more weak points keep cropping up and you try to budget to start with but ends up turning to open cheque book trying to protect the investment and the inevitable happens
  1. My build thread....
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2014, 20:58
  2. A4 Build Thread
    By AudiSport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th September 2011, 09:45
  3. My Build Thread
    By Triple.O.G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 20:36
  4. A4 Build Thread
    Last Post: 20th November 2010, 22:14
  5. My Build Thread....
    By L0WRiDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 20:28
