EM TuningVolks Autos
Page 17 of 55 FirstFirst ... 710111213141516171819202122232427 ... LastLast
Results 641 to 680 of 2165
Like Tree355Likes
Thread: Stacey's Belated Yo Yo Build Thread
  1. #641
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    just a bit of advise stace, dont be using that tomato ketchup as assembly lube. Hp brown is MUCH better
    Yeah them pictures have got the bad side lol
    The left hand side of my shelf has all my food related stuff as you probably have noticed.... But I do swear I have actually got tools in my work cupboards
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  3. #642
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Been having more issues with the throttle body, to the point it threw a wobbly 4 times in 20 miles, so have now bought one off of eBay for £25 posted and can hopefully start running meth again
    I will hopefully try running the dv off of the new tb as it still doesn't open quick enough all the time which causes an obvious noise and you can see the inlet temps spike, although it only seems to happen when letting off when the turbos spooling up
    Am hoping that the bigger diameter nipple and 6mm Id pipe will flow enough to open it quicker??
  4. #643
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    This is a pain with WMI. Luckily mine hasn't been working long enough to eat a TB lol
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  5. #644
    Reesy's Avatar
    East Sussex
    3,604
    Quote Originally Posted by StaceyS3 View Post
    You spaz, I have about 3 Throttle Bodies I want to get rid of, and would have done it for that price at the most!!
  6. #645
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    even comes with a 10 minute warranty
  7. #646
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Quote Originally Posted by Westy View Post
    Am hoping the r32 tb will hold up a reasonable amount of time as will get expensive in future
    Having driven a reasonably long drive tonight I can say I mish running WMi and is noticeably different without it
  8. #647
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Quote Originally Posted by Reesy View Post
    Cheers mate didn't even cross my mind but as Karl pointed out a lot of your parts are notorious for short life expectancy's lol
  9. #648
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    can you actually see what the meth has doen to it, or is it unoticable?
    i've not heard welly has been through one recently, was his just the one? because i thought it was a bit of speculation as to whether wmi was the cause.
  10. #649
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    I know that since it first started playing up it's gradually got worse but Tuesday I eventually took it apart and cleaned the tracks on the circuit board with some electrical solvent and has been fine since
    I physically haven't seen any water or anything in there when I think welly found his full before?
    It would suggest that something had been deposited on the circuit board on mine at some point and WMi seems the obvious thing but there isn't any concrete evidence of this apart from I would have thought it would help the seals deteriate quicker?
  11. #650
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    just a quick daft suggestion, is there no way to bodge some sort of silicone around the TB so the water meth mix wont get in to it, surly there must be a hole that could be siliconed up to not let the mixture in.
  12. #651
    Westy's Avatar
    Dec 2008
    17,273
    This is why I looked at a TB sandwich plate after the TB to attach the nozzle too but I was told that the mixture wouldn't be able to atomise as well into the charge airs being so close to the inlet mani.
    S3 Build Thread
  13. #652
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by coatesy View Post
    The throttle plate has to move so i dont think that would be good...
  14. #653
    coatesy's Avatar
    Oct 2010
    1,901
    it was just a suggestion, iv never taken a TB apart before... ill just go back to my corner lol
  15. #654
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Silicone isnt really an option but once I've got the new one I will be looking to see if I can replace the o ring to fix it
    From what I've read the closer to the inlet you get more of the meths properties (less knock/higher octane) where as the further away you get more of a cooling effect which will also reduce knock slightly through lower IAT's
    Would quite like to try 2 nozzles....one at throttle body and curious to how a small one just after the turbo would work as this is when temps are at there greatest??
  16. #655
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Lol...all ideas and suggestions are helpful mate
  17. #656
    RIP S3dave
    May 2004
    nr Glos
    7,157
    wellys failure was seizure ultimately
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  18. #657
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,357
    S
    I don't think it would work. it'd surely just condense through the intercooler core and pool? Also I see no benefit in adding the cooling early on post turbo, as you're just giving it more chance to heat the meth mixture on it's path to the TB. Injecting it post IC and late makes sense in cooling terms, just needs to be a distance away from the TB to allow it to atomise before going into the engine.
  19. #658
    RIP S3dave
    May 2004
    nr Glos
    7,157
    ..... a small one just after the turbo would work as this is when temps are at there greatest??
    IF you cool pre-intercooler, you reduce the intercoolers effectiveness.... as its the temp delta which factors in its effeciency.
    slappy did a bunch of tests on his TT spraying pre and post and direct, so worth asking him how he fared.. It was contrary to what the mainstream suggest, but he did it with logs etc so actual data and results - which i dont recall I'm afraid
    bill@badger5.co.uk
  20. #659
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Had remembered seeing a thread on it somewhere but couldnt remember where?
    I suppose it may be beneficial if still running a really inefficient intercooler setup and things get muchos hot but if your Intercoolers already efficient then not going to gain anything like said
  21. #660
    Westy's Avatar
    Dec 2008
    17,273
    Even atomised meth fluid shouldn't eat the TB too much. It's probably more likely to do with the strength of the mixture you're running. I know for a fact you like it strong cause that pre mixed bottle you gave me was pretty potent
    S3 Build Thread
  22. #661
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    I usually mix a 20 litre container at a time and it's conveniently marked in 2litre increments and do aim for 50/50 or somewhere abouts, maybe that bottle i gave you wasn't mixed after all??
  23. #662
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Also been meaning to ask what water pumps are flavour of the month as know people all went for ones with metal impellers as the plastic ones broke up and then iirc was it the metal ones that have now been discovered to have duff seals??
    Share the knowledge guys
  24. #663
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    I've gone for an airtek plastic impeller pump this time.
    i think it was tuffty and Welly that were talking about the metal impeller ones being off balance and leaking through the spindles, so I went plastic this time around after 2 metal ones previously which both weaped through the seal a tiny bit.
    StaceyS3 likes this.
  25. #664
    Westy's Avatar
    Dec 2008
    17,273
    I hope I'm not running 100% meth
    I have a plastic water pump mate. All the new ones from VW are plastic now.
    S3 Build Thread
  26. #665
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    All the metal impeller ones I have seen to date leak through the shaft.. Bill had one on his Ibiza engine and it leaked... thats does very little mileage in comparison...
    The new OEM pumps should be plastic impeller and of a new design... most if not all of the pumps I have seen destroy themselves are originals from the factory... not yet seen a replacement go
    <tuffty/>
  27. #666
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Okey dokeys oem plastic it is but I've been told that there's a few part numbers when was compiling my parts list, the number I've got is 06A 121 012 GX and was told that you can exchange an old one for about £25?
    Cheers for the help guys
    On a completely random one just updated my tapatalk and found that there's a "like" button
  28. #667
    May 2010
    Bedford
    2,877
    You`ll have to pay the £25 until you give the old one back then you`ll get a refund. Its not refund you £25 from the retail price
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  29. #668
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Yeah did kind of gather that but have got 2 old ones in my cupboard now from stripping blocks :P
    Will they take both and give me £50 lol
  30. #669
    May 2010
    Bedford
    2,877
    Sadly not lol. Got a month to return.
  31. #670
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    TBH even if they hadnt changed the design, its not like the plastic pumps break after a year is it...
    they last 10 years or so, and if you change them with the cam belt you'll never have an issue with them.
    I've unfortunately just fitted a metal pump to my A4 due to it dying and me having to quickly get a replacement from ECP, so no doubt i'll have to take that apart again in a few months and fix it when it starts leaking.
    TD5 Land Rover Defender build
  32. #671
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Well done a couple of little things to the car or bits for the car over the last few days
    Chamfered the bottom of the bores with the trusty dremmel
    I also did a bit of work on the inlet Mani as have just bought some carbide burrs for the dremmel so fancied giving them a go and removed all the casting excess (sorry no pics)
    Have fitted the throttle body and moved the dv onto the fitting on there which has improved it's response massively and am chuffed now can run WMi again
    I thought I'd also get the EBC plumbed in eventually but now have thought about it I'm not sure if it will work in parallel with the N75 like a MBC/bleed valve as the solenoid for the EBC is a 3 port valve, which vents the actuator to atmosphere when trying to increase boost (by the looks of things that is?) so if the N75 try's to open the wastegate it could then just be vented out the exhaust of the EBC valve and I pressume the same would happen the other way round but the EBC trying to open the wastegate and the N75 just venting it into the TIP??
    So for now I've plumbed the EBC in by itself so I can get it set up properly as got a trackday booked and up and coming as had a £100 voucher I was trying to save till I got the more egt friendly set up on but it is about to expire so use it or loose it
    Once got it all set up properly I will try it in parallel and see how it all behaves
    I have over the last week or so experienced some slightly higher boost levels with it holding as high as 1.7 bar but when changing the wastegate piping found the cause
    The pipe had been moved down the back of the head previously when was working on something and got forgoten about but you can see how much the oem heatsheild does as have only cut a small slot (down right behind the head) in it as the wastage was to tight to the head and all the pipe was fine apart from an inch or so that sat above the little hole
  33. #672
    RIP S3dave
    May 2004
    nr Glos
    7,157
    you can never have too much heatshielding.
    bill@badger5.co.uk
  34. #673
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Yeah will be welding something back in place of the inch or so lump I cut out for this setup
    What you think about the EBC in parallel bill being that the solenoid is 3 port unlike a MBC bleed valve? Am wondering if they will try and work against each other?
  35. #674
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Well been playing with the boost controller for a good few days now and can't get it to consistently hold the boost throughout the rev range?
    My aim was to get it running what it is mapped at (1.55 bar) and then set a couple of reduced amounts as well as setting up the overboost function for a couple extra psi in short bursts at the press of a button
    I've played with the duty cycle and gain levels but not getting much better consistency, if you pull through lower gears it will hold 1.5-1.6 but tails off up towards the last couple of thousand to 1.3 ish but problem is when in higher gears loaded up it holds 1.8 which not happy about as will just shoot egts up for little gain
    The controller I'm running is gizmo ms-ibc if anyone has had any experience with this particular one or knowledge from others is more than welcome
    On a plus side I've just got a nice tax rebate as wasn't getting the correct tax relief on my pension......so hopefully should see the build moving now and will be ordering my crank and rest of oem bits in the up and coming days as well as sending Andrew my head
  36. #675
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Took the car to a friends today to have the geometry looked at as not been checked since had the front subframe off as well as doing various other work
    I used to have it set up with 2 degrees negative camber on the rear and just over 2 degrees on the front but obviously things were a bit out especially on the rear, had managed to get the front relatively even
    We had issues with the rear passanger side tie arm which the adjuster seems to be seized as the locknuts move freely but cannot budge the adjuster, I've got a horrible feeling that the previous people hadn't done the locknuts up properly and has deformed the threads?
    We got a couple of bits better aligned or at least even, even if it's a bit to much for now, will have to take the tie arm off and free it up as well as maybe repair the threads if needed then will set it all properly
    What would people reconmend getting everything set to for fast road/track as the car is being driven hard more often than sensibly
    My friend has said he's willing to set it a bit more aggressive for the up and coming trackday and return it back to something more sensible FOC afterwards
  37. #676
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    thats alot of camber for fast driving anyway. bit of toe out on the front is also a good idea. i have 0.05 both sides, feels lively and quick.
    i do get alot of inner tyre wear though, mainly because i do alot of long straight driving with it toe-ing out
  38. #677
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Hey dude,
    I need my Geo setup as well, if i come up and see you can you take me to your mate?
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
  39. #678
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Cheers for the replies guys think I may tone the camber down a touch especially on the rear once that tie bars been freed up think I may keep a reasonable amount of front camber as should hopefully keep good turn in and front end grip? Also don't think I will be able to back the adjusters off to much to get it much lower on the passengers side front but will see, will try the toe as said karlos and see how she goes
    If anyone else is interested they (station tyres in witham) will do front alignment for £30 or full alignment for £50 but don't sting you for each individual adjustment like certain places I have been to before wanting >£200 for full set up
  40. #679
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Well the inevitable has happened just thought it would last longer as the last one lasted well over a year and this one has been a mater of weeks, but it does show that my one from qst is nomex or there is big differences in quality
    The two types side by side
    I've got a spare length of the ASH silicon as was cheap that could use as a back up but as it's not lasted that long have cut a length off of the other end at the top of the old elbow
    Was hoping it would be enough to see me until I change it all over to the new set up but with the up and coming track day at Bedford will have to shield it in some way or form
    Got the head all packaged up and sent off today so hopefully ball is rolling with the build again
  41. #680
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Have been going through what is hopefully some of the last few bits to order over the last couple of days, got all my charge piping ordered for the TIP and L shaped charge pipe from the turbo (cheers bill as always for advice on sizing etc)
    Then after seeing a thread on plugs this morning it has got me thinking what plugs do I need?? Will 7's still be cold enough or should I know step up to 8's?
  1. My build thread....
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2014, 20:58
  2. A4 Build Thread
    By AudiSport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th September 2011, 09:45
  3. My Build Thread
    By Triple.O.G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 20:36
  4. A4 Build Thread
    Last Post: 20th November 2010, 22:14
  5. My Build Thread....
    By L0WRiDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 20:28
