Volks AutosMonster Motorsport
Page 10 of 55 FirstFirst ... 3456789101112131415161720 ... LastLast
Results 361 to 400 of 2165
Like Tree355Likes
Thread: Stacey's Belated Yo Yo Build Thread
  1. #361
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Top mount GT30 surely? or going Precision 6262
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  3. #362
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Sam_ View Post
    Core won't be changing
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  4. #363
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Quote Originally Posted by Westy View Post
    just edited so it doesn't sound to suspect lol
    "Heavey session" is an understatement! We all got steaming, you could have been arrested, we nearly got in a row with a load of huge Germans who were chasing you, we then destroyed James' bed tipping him upside down at the hotel, I then broke my toe in the morning with my hangover and staggering into a jack that was stupidly positioned at the end of my bed
    Happy days
    That was a blinding weekend with some very haisy patches lol
    Keep forgetting how much we really got up to that night
  5. #364
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I would get that power steering pipe changed Stacey, a few Vauxhall Insignias have gone up in flames where the power steering pipe ruptured near the exhaust.... it was on watchdog a couple of week ago..
  6. #365
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Ohh not good
    Cheers for the info I will look and see if I can source one
    On another note things are going together smoothly even the downpipe as I ground down one of the flame rings so can actually slot it together now
    Well that was all smooth until I managed to slip with a 3/8 ratchet and hit my knuckles then causing me to drop the ratchet which fell and hit me in the mouth which has now given me a nice fat top lip......what a penis!
  7. #366
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Right decisions decisions?
    Top mount tubular v band manifold but unsure whether to wait until the end of june for it to have 1.5 inch pipe on the wastegate or get one a lot sooner with 1.25 but bill had a recent car suffer with boost creep and couldn't get the boost below 18psi
    Turbo housings... Atp are being helpful and i am going to change to a tial v band hotside as only $20 more than my one but not sure what ar to go for .63 or .82
    Comp cover i can now go to the full sized anti surge cover but is it worth it? Should just be able to exhange my one for it?
    Ideally want the car to be as responsive as possible which points to the .63 housing but is it worth doing if cant bring the boost in early due to surge?
    Opinions guys?
  8. #367
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,275
    Quote Originally Posted by StaceyS3 View Post
    Opinions guys?
    I say, take your time and get everything that's needed. If you know that another car suffered with a smaller wastegate pipe then wait and get the larger one.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  9. #368
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    maybe the smaller wastegate will be ok with .63? i dunno.
    this reallly is a yoyo thread lol.
  10. #369
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Wait for the right mani mate... the boost creep was a mare...
    Tough call on the 0.63 vs 0.82... only really seen 0.63's on 1.8's with a GT30... Bill runs a 0.82 but on a much larger turbo so is inherently laggier...
    The LCR looks like this...
    The early spool is partially due to the extra capacity but the TSR runners are slightly smaller ID than the mani's Bill normally uses which will help spool too...
    The Tial hotsides look quite small compared to the Garrett cast jobbers but thats due to the process used (investment casting)...
    The GTX wheel you have is designed to flow more and spool quicker so maybe a 0.82 would be a better fit...
    As for the antisurge housing... the GT3076 on the TT still surged with one fitted so don't know if they are really that good... the smaller comp housing you have will make fitting easier for sure and surge can be mapped around at the end of the day... think about it realistically... surge is brought on by a certain volume of air not being able to flow at a given time... if mapped around the surge lines then you are no worse off than using a smaller turbo that doesn't surge as it can't produce the vol of air at the surge point of the bigger turbo (if you follow) so you aren't losing much other than a little torque from boost that could well be balanced out by adding ignition timing at that point...
    I would be tempted to run the current smaller housing for the time being, still run a 100mm TIP but reduce to 76mm for the turbo so if you really need to then you have the option... as for space... that will dictated by the fitment given with the manifold anyway... you can also (seeing as its a vband fitting) swivel the turbo round centering the housing in the gap you have so there is the same clearance either side... this way at least if you do have to for the larger comp housing you have given it enough room...
    Or just buy one anyway...
    <tuffty/>
  11. #370
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    I'm on a 0.63 with my 2.1 and GTX3076r if that helps
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  12. #371
    BENJAMIN's Avatar
    Mar 2011
    472
    I'm running a T25 flanged GT3071R .82 housing. 18psi @4200rpm. 10psi around 3500rpm. Hope that helps!
  13. #372
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Cheers for the advice guys especially paul with your detailed essay as was a great help
    I read the whole thread for the lcr yesterday and it was on a .82 hotside iirc that is the main thing that has given me mixed thoughts although he does have more capacity being a stroker?
    Think i will wait on the mani to get the right one but the main problem is that from june through till the baby is due in sept i will be working nearly 7 12 hour days a week due to being holiday season and the overtime will need covering, so time to fit it all will be limited but think i should definately do it right
    Think i will give the ported housing a go as from what i understand from disscussions with atp i think i am going to be able to swap them as it was just an option when i bought it but if it does cost then will leave it and stay compact and be a test mule
    I'am definately leaning towards the .63 ar especially as i now know you are running it Andrew but will make the decision over the weekend
  14. #373
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by Andrew@A.L.D View Post
    thats too small a hotside for your spec. you have built a diesel in power delivery terms.. lol
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  15. #374
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    What size hotside in your opinion would you go with on mine bill?
  16. #375
    RIP S3dave
    May 2004
    nr Glos
    7,175
    0.6x as you are only normal cc
    www.badger5.biz
    bill@badger5.co.uk
  17. #376
    Jun 2011
    S.E. Melbourne/ Australia
    146
    Sorry to highjack can some one post a link to the LCR thread?
    I like that power graph.
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
  18. #377
    Jun 2009
    Leeds
    3,469
    seams to be ok for power delivery but i was to change how much would it cost?
    FOR SALE
  19. #378
    RIP S3dave
    May 2004
    nr Glos
    7,175
    its a balance/trade off between spool and flow ability
    2.1 its should spool nice enough to sacrifice a little for the top end flow benefit potential
    its what i would spec for a 2ltr with mods... especially yours being 2.1 and cams also mentioned?
    www.badger5.biz
    bill@badger5.co.uk
  20. #379
    Jun 2009
    Leeds
    3,469
    Piper cams are in the post and will get the housing swapped as i've had a look at my last dyno chart when it did 440bhp and you can see the short power band and were the power tails off
    FOR SALE
  21. #380
    RIP S3dave
    May 2004
    nr Glos
    7,175
    as a guide.. my ibiza.. 1900cc, stock crank, cams, largeport, SEM etc etc.... peak power is at my softcut limiter and climbing... which is what I would expect for yours also.. but yours would all start happening sooner than mine given its bigger displacement.
    I was looking at GTX35 comp maps only this morning, seeing what the GTX35 compared to the GT35 I ran before.. (closest to the actual Precision 62 comp wheel I actually run, which does'nt seem to have any published comp maps unfortunately) - Plotting the actual dyno results I have run so far on 12psi and 25psi, it sits pretty much on the centreline right of the middle.. and correlates very close to my 2 figures seen. More revs = more flow for same boost in my instance, so to find more power I would have to rev more... which I can do of course, or wind up the boost for the same revs and force more airflow thru. again, its a balancing act.
    turbo comp charts here are what I am looking at> Products | Turbochargers
    click the ones to compare... and see where your boost was and look for its lb/min flow... and as a guide.. 10lb of flow is 100bhp *ball park*
    www.badger5.biz
    bill@badger5.co.uk
  22. #381
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,370
    Is where the suggestion that the ko4 hybrids can do 350bhp comes from Bill? as it has a 35lb compressor wheel?
  23. #382
    RIP S3dave
    May 2004
    nr Glos
    7,175
    yes.... exactly.
    and as we all know now.... or bloody well should do if they have been reading these hybrids threads for months and months..... lol, then just because the compressor can have this rating, everything else around it also has to be suitably sized for it
    www.badger5.biz
    bill@badger5.co.uk
  24. #383
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Cheers think I will go ahead with the .63 ar and if I ever do fit a tfsi crank at a later date I can change it then
    Iirc mines quoted somewhere around 55lb/550bhp but will never hit that figure and can't imagine 500 is possible on my set up with this turbo
  25. #384
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,370
    yes.... exactly.
    I wonder if I could be the first person to get a ko4 hybrid to reach 350bhp?
    And if I was, I wonder how long it'd last for! haha.
  26. #385
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    I think it is possible mate with meth and a ****e load of timing but engine would self destruct if it should fail
    Aem do a failsafe that monitors flow and if flow is to high or low due to a leak or blockage its got a output to drop boost or something else desired
    There's a seat Leon tuned by 0-400 that put out 650bhp (dyno lottery) on my turbo which is rated to 550 but was running 2.4 bar boost and lots of WMi at a strong mixture with a shed load of timing, but get the feeling it would spit bits of the engine to the moon and back at the first sign of a fault lol
  27. #386
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Well it's all up and running all ok after having to get hold of some more high heat steel heat sheilded pipe for one of the turbo coolant lines as the current length broke up on removal, exhaust also sounds better with no blowing noticeable as put all new gaskets in as well as some sealant
    So far downpipe doesn't seem to be fouling on power steering pipe any more as took it for a little drive and so far so good but couldn't really chuck it round a left hander to hard as got my tool chest in the boot till I return to work and it weighs a tonne and didn't want to damage anything
    Will probably give it a good thrash tommorrow night and find out if it's still good when really giving it some beans
  28. #387
    Westy's Avatar
    Dec 2008
    17,275
    What exhaust sealant did you use mate? I've been using fire gum but not too sure how good it is. Also did you use sealant between the turbo to DP gasket as I'll be fitting a new gasket soon.
    S3 Build Thread
  29. #388
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    I used it on both sides of each gasket and v band to be sure
    It was some stuff that tuffty recommended on a prior post earlier on during the week, it was a bit smokey when first started as expected because can't find any sealants that are rated above 300 or so degrees
    While try and see if I can find the post no
  30. #389
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Here you ho matey
  31. #390
    Westy's Avatar
    Dec 2008
    17,275
    I'll use what I've got as I've got a whole tube of it at the moment.
    Did you use anything in between the cat/decat to cat back exhaust system?
    S3 Build Thread
  32. #391
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Didn't as mine is all one piece from engine side of the steering rack to the cat back but if i was going to be taking that end of it all apart i would do
    I know bill uses similar sealant regularly
  33. #392
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,370
    I've been using the high temp silicon instead of gun gum lately on Tuftys recommendation, and I've found it's cleaner, looks nicer, and seems to seal up better for me as well
  34. #393
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Today I've noticed I'm getting a bit of heat on my left lower leg when thrashing it?
    I think have only noticed it today as am wearing shorts but pressume the heat is downpipe related?
    Anyone else had simular issues? I had heard of someone else that had a simular thing think it was Hollie with the TT?
  35. #394
    Westy's Avatar
    Dec 2008
    17,275
    That must be some serious heat to get into the cabin!
    S3 Build Thread
  36. #395
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Yeah it felt like having the air blower on full heat on my leg briefly at times athough of coarse my blowers were off
    Gotta admit i did see a peak of 975 egts on my b road blast this morning
  37. #396
    Westy's Avatar
    Dec 2008
    17,275
    975 is good for you
    It might be worth your time getting under the car and checking for heat damage around the DP. If you can feel the heat in the car imagine how hot it is around the DP!
    S3 Build Thread
  38. #397
    RIP S3dave
    May 2004
    nr Glos
    7,175
    I doubt it... its got a lot of heatshielding....... way way more than you have and a DP which does'nt actually touch anything
    www.badger5.biz
    bill@badger5.co.uk
  39. #398
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    I get this on an OEM downpipe/turbo setup. I think it's called driving it like it's meant to be driven
  40. #399
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,370
    I actually ran for 6 months without the main front tunnel heatshield. One of the most uncomfortable things imaginable.
    Tunnel used to get so hot it'd burn your leg!
  41. #400
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Wasn't on the new setup which i expect is heavily heat shielded
    I'll see if i can find it but iirc she said there was something burning her legs?
  1. My build thread....
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2014, 20:58
  2. A4 Build Thread
    By AudiSport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th September 2011, 09:45
  3. My Build Thread
    By Triple.O.G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 20:36
  4. A4 Build Thread
    Last Post: 20th November 2010, 22:14
  5. My Build Thread....
    By L0WRiDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 20:28
