W8 PerformanceBackdraft Motorsport
Results 1 to 9 of 9
Thread: N75 question...
    Oct 2008
    217
    Post Thanks / Like
    N75 question...
    Sitting in (i cant drive cause of a little bit of snow) traffic Saturday, i thought id have a play with my Liquid gauge (as i never use the bloody thing)... flicked it on to the N75 setting,and even flat in 1st,2nd,and 3rd, it was only opening 90%?? Is this correct, or is there a problem?? I ran a fault code scan, and said it was fine???
    Pete...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    90% duty cycle is pretty much flat out... N75 duty cycle is determined by load and boost request... the ECU will turn the N75 on and off to control boost to the required boost for the load...
    Depending on the circumstances it could be as high as 90/95% or more normally 80 ish %
    People get confused about boost and airflow... the ME7 ECU is a clever little bugger... it will sometimes use less boost to still get the same airflow/cylinder fill its tuned to achieve...
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    Oct 2008
    217
    Post Thanks / Like
    10-4 rubber dick... Message recieved and undersrtood...
    Still debating 1 of Bills TIPs... made fantastic figures when it was on his rollers last time, i quote "most power from a ko4 hes ever seen", but dont know if a 3" TIP woulde finish my already on the edge turbo...
    Pete...
    Welly's Avatar
    8L S3 - Badger 5 Edition
    Aug 2009
    Gloucestershire
    10,175
    Post Thanks / Like
    Quote Originally Posted by warleydaddy View Post
    Pete...
    Do it, do it, do it.
    "When I held that gun in my hand, I felt a surge of power…like God must feel when he’s holding a gun."
    Homer Simpson
    Welly & Bumble
    FP Green - 445 BHP/328 LBFT
    Badger 5 Edition....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    ^^^ + 1
    <tuffty/>
    My build thread...
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Would it be worth contacting bill for a TIP price as it's looking like a hybrid is on it's way
    Im confused as to the N75....its the first ive heard of it.
    Does mine have one already? / and is it needed for the upgraded turbo
    Azure Blue, Pearl Effect
    1.8TQS, KO3s
    3" De-Cat - Straight Through
    Upgraded Coils / NGK / Mobil 1
    Carbonio Carbon Air / Bailey dv26
    Custom Stage 1 Re-map -> chippeduk
    Powerflex DogBone Mounts
    Eibach Pro Kit / ARB
    200 Horses Club
    SUMMER 2012 - KO3 hybrid / Wellycooler / TIP / Injectors
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    Quote Originally Posted by Alais DJA View Post
    Yes you do... its the boost control valve...
    <tuffty/>
    My build thread...
    Oct 2008
    217
    Post Thanks / Like
    Whats Bill crackinbg these out then?? Not been on the forum for ages, as been so busy at work... Im running APY,but have re routed a few pipes to run a silicone TIP,so presume his TIPS are for ESP enabled cars anyway??
    Pete...
    www.badger5.co.uk
    May 2004
    nr Glos
    3,851
    Post Thanks / Like
    yep, for ESP.. and all info in my section in the link in my siggy
    Big Brakes, AP Racing, Brembo, Ferodo DS2500/DS3000, Motul RBF660, Remapping, Dyno Tuning & logging, Big Turbo conversions, bespoke fabrication, Race Proven/Winning products and services.
    http://www.badger5.co.uk, Tel:01453822880, Mob:07976 800775
    bill@badger5.co.uk
  1. N75 question
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2011, 13:19
  2. quick N75 question
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2011, 15:25
  3. N75 Question
    By QuottroA4 in forum Tuning
    Last Post: 6th November 2009, 17:39
  4. n75 j valve and maf sensor question
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2006, 13:14
  5. A quick question on N75??? Valve
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2004, 21:31
