AWEsome GTIGNJ
Results 1 to 11 of 11
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,013
    Post Thanks / Like
    DIY DIS replacement
    has anyone replaced the DIS them self, if so how hard was it to replace?
    thanks Jay
    Current mods
    Forge 007P, front mounted intercooler, smoothed airbox with jetex panel filter, boost gauge, wideband AFR, 312mm brakes, 3" downpipe/decat,straight thought, s/s backbox, stage 1 remap, coilovers, silicone TIP
    WantedS3 upper strut brace
    Feb 2012
    kent
    41
    Post Thanks / Like
    Quote Originally Posted by jay1601 View Post
    thanks Jay
    im looking into the same hope this helps Danio's A3 - from tiny A3 to S3 lookalike model.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,013
    Post Thanks / Like
    mines got the screen as standard but its lost some lines. apprently you need to solider the new screen off/on. don't want to fook the dials up so wonna know if is hard to do
    Current mods
    Jun 2009
    Leeds
    2,046
    Post Thanks / Like
    I have a DIS screen if you need one
    Stroked 2067cc (2.1) S3. AEB Ported & Gas flowed head, Piper cams, Valve + Spring kit, Big intercooler, IE rods, JE Pistons, CP rings, Milltek, GTX3076r Turbo, External Gated, 870cc injectors, Twin pumps, Wide Band conversion, ALD Custom inlet with R32 T/B, MkV TSI Coilpacks conversion, Fluidampr pulley, 4kg Billet steel flywheel, 4 paddle clutch, Coilovers, R32 rear ARB, Blue Haldex, 350mm 6 pots fronts & 330mm rears. Going for 550bhp, 600bhp with new injectors and more boost
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    5,499
    Post Thanks / Like
    Did you do yours yourself andrew?
    Aug 2009
    Cheltenham
    270
    Post Thanks / Like
    I have done it. Quite easy. Remove clear cover, Mark position of pointers at rest, remove pointers, remove dials, take a few other bits off, unsolder dis flexi, solder new one on, then refit everything.
    Warning...don't let thisbe your first soldering experience... the dis flexi has quite a fine pitch
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,461
    Post Thanks / Like
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Jun 2009
    Leeds
    2,046
    Post Thanks / Like
    No got someone to do it for me
    My mate had his done by a local TV repair guy lol he just soldered it in
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    5,499
    Post Thanks / Like
    Haha class.
    audi-a6's Avatar
    Aug 2011
    christchurch
    174
    Post Thanks / Like
    i had the same thing, i just took clocks apart to expose the dis, then carefully heated up the solder, with a heat gun (wallpaper striper) and put a bit of pressure on the ribbon, left to cool, now it works 100%
    sideways steve's Avatar
    Dec 2011
    258
    Post Thanks / Like
    I've done mine. Its not as simple as some people would have you believe so dont go jumping in until your confident you can solder well.
    You need to be carefull not to overheat the PCB and you need to very gently remove the old screen as if you go too quickly you will pull the tracks off the board which will mean you cannot solder the new one back in !
    It takes time and patience and a steady hand with a good quality fine tipped soldering iron.
    Personally I would not do it again unless I really had to !
  1. DIS LCD Replacement - guide
    By Cabbyfan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3 Weeks Ago, 20:34
  2. A4 Cab DIS replacement
    By Cabbyfan in forum Parts Requests
    Last Post: 4th April 2011, 18:55
  3. DIS REPLACEMENT HELP PLEASE
    By dany2k in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2011, 21:32
  4. DIY rear brakepad replacement help
    By lepablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2010, 22:57
  5. DIY Front Pads & Disks Replacement - Tool Checklist
    By vanilla_ice in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2007, 20:27
