Revo TechnikAMD Technik
Results 1 to 17 of 17
    Aug 2010
    bradford
    723
    Post Thanks / Like
    Actuater fitted and wow
    Well today I spent hour and half fitting my uprated actuater and what a diffrence it's made.
    Thanks to tuffty and bill for the help
    My hybrid ko4 came with a standered actuater and after months of worries rang Cr turbos and they then sent me a uprated one out wich is a 10psi actuater, fitted this earlier and went out to see what it was like and what a difference feel like a new car lol.
    Switched my liquid gauge in and well
    before and after
    boost 11 psi now 17 psi difference 6 psi
    bhp 210 now 238 bhp difference 28 bhp
    torque 206 now 240 difference 34 pound of torque
    well chuffed what a mod for nowt
    The logs where not flat out either so probly get more if I pushed it running standered map too.
    I take it my old actuater was f......cked then.
    Fitting wise I had to take the bracket off and the coolant hose off the top of the turbo to get the nut out bleeding thing blag it was.
    Silver s3 amk 2001, hybrid turbo, silicone, forge 007p, HID kit, big intercooler, jetex filter, badger 5 3" tip, boost gauge, n249 bypass, xs 3" downpipe & de-cat, privae plate s333 gln, liquid gauge, quick shifter, LCR brembo's, oil catch can, r32 arb, AGU ported and polished Head, genesis 550cc injectors, Milltek non res, kw v2 Coilovers, I.E con rods, s3dave tie arms
    coming up
    xs manifold
    FOR SALE
    standered cat back exhaurst
    s3 side mount intercoolers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    Humm... a 10psi actuator should do around 10psi if adjusted right... although they normally do a little more in reality... I assume you are still running with the N75 un-plugged as you haven't had your engine mapped for the hybrid yet?
    17psi is a little high for actuator pressure tbh.... have you over adjusted the preload?
    Just remember that the std map has very lean fuelling... you will be running stuff very hot and it can be very dangerous... you seriously need to get the mapping done my friend...
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    superkarl's Avatar
    MACH 9
    Mar 2010
    Southport, N west
    3,676
    Post Thanks / Like
    And surely 11psi before hand is around about normal IF its standard map and IF you had the n75 connected?
    Aug 2010
    bradford
    723
    Post Thanks / Like
    N75 is conected at the min as Paul at Rs tunning said will be ok as long as I don't rag it on the standered map.
    Tuffty I did what u said mate turn the outside nut in till hand tight and then 3 hole turns that was bang on as I marked the nut first the tightened the inside nut to that then Paul
    coming up
    xs manifold
    FOR SALE
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    Quote Originally Posted by s3gazz View Post
    Ok... still not convinced about the N75 being plugged in but its your choice...... in theory it should be ok but these things have a habit of biting you in the arse...
    Take it easy doode...
    <tuffty/>
    My build thread...
  7. Thanks s3gazz thanked for this post
  8. #6
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    I would leave it unplugged as that way even if you nail it... all you will get is a "safe" level of boost
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Nigger beater
    Miltek cat back exhaust
    3inch cock down my pipe and decat
    stage 2 shirt lifter
    Forge TIP , Boost hoses and DV
    3.8 bhp /40.7 torque
    huge cock on my head
  9. #7
    Aug 2010
    bradford
    723
    Post Thanks / Like
    <tuffty/>
    cheers mate Ill take it easy 2 month away from all been done not going wrong now lol no way
    coming up
    xs manifold
    FOR SALE
  10. #8
    Aug 2010
    bradford
    723
    Post Thanks / Like
    I no what u mean Paul it's just alot of torque bhp just from fitting a actuater why lol
    coming up
    xs manifold
    FOR SALE
  11. #9
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    5,499
    Post Thanks / Like
    This worth doing on a non hybrid s3? Been offered a forge actuator for £50 delivered, seems a bargain.
  12. #10
    Aug 2010
    bradford
    723
    Post Thanks / Like
    Don't have a clue mate but the forge one iv been told are not that good best speaking to tuffty mate but I think my actuater was nackered for it to have that much improvment
    coming up
    xs manifold
    FOR SALE
  13. #11
    Customboy's Avatar
    Jan 2012
    SE London
    645
    Post Thanks / Like
    Which make and model did u fit mate ?
    p
    THE BLUE BEAST
    RTECH STAGE 2 REMAP NOW RUNNING 222 BHP AND 250 FTLB OF TORQUE
    KO4 TURBO NEXT! STAGE 2 HASN'T EVEN WARMED UP !!
    LOOKING FORWARD TO COMRADESOFVAG MEET OB 26TH MAY, 7.00PM @ COLLIERS WOOD BURGER KING
    SW19 1DN SO POP DOWN AND LET THE PARTY BEGIN !!
  14. #12
    Aug 2010
    bradford
    723
    Post Thanks / Like
    It's a Cr 10 psi actuater pal
    coming up
    xs manifold
    FOR SALE
  15. #13
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    You have more power and torque as you have more boost... its pretty much that simple mate...
    <tuffty/>
    My build thread...
  16. #14
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    I'll take one - who and what number do i call
    Azure Blue, Pearl Effect
    1.8TQS, KO3s
    3" De-Cat - Straight Through
    Upgraded Coils / NGK / Mobil 1
    Carbonio Carbon Air / Bailey dv26
    Custom Stage 1 Re-map -> chippeduk
    Powerflex DogBone Mounts
    Eibach Pro Kit / ARB
    200 Horses Club
    SUMMER 2012 - KO3 hybrid / Wellycooler / TIP / Injectors
  17. #15
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,518
    Post Thanks / Like
    Not had fantastic experiences with Forge actuators on these turbos... they have a tendency to stick and cause spikey over boost and some people have put too stiff a spring in 'to get more boost' and just ended up with rod bending spikes and no boost control...
    I have not known a std actuator to fail although they do go a little soft over time... the turbo normally expires before the actuator does...
    ...and watch the preload too....
    <tuffty/>
    My build thread...
  18. #16
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Yeah, reading back - im sceptical if it really makes that much difference.
    If the car wasnt setup properly to begin with - you may just be experiencing "normal" power that is should be.
    But changing the location of the acuator to get noticable power gains.....i'd have to see it to believe it.
    1.8TQS, KO3s
    200 Horses Club
  19. #17
    www.badger5.co.uk
    May 2004
    nr Glos
    3,851
    Post Thanks / Like
    no no no and no
    unless yours is buggered..
    adding an actuator which had more preload that stock WILL cause boost spikes..
    It can help hold top end boost from what I have seen, but without some means of clipped the inevitable spike which it will also cause, you risk bendy/snapped rods.. MBC in parallel would clip this, but if you dont know what you are doing, just adding one risks your engine.
    Big Brakes, AP Racing, Brembo, Ferodo DS2500/DS3000, Motul RBF660, Remapping, Dyno Tuning & logging, Big Turbo conversions, bespoke fabrication, Race Proven/Winning products and services.
    http://www.badger5.co.uk, Tel:01453822880, Mob:07976 800775
    bill@badger5.co.uk
  1. Just fitted an RS4 Rear Sway Bar - WOW!
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2 Weeks Ago, 08:04
  2. Exhaust fitted and wow
    By IrishDave in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2011, 22:59
  3. !!!!!!!!!WOW!!!!!!!!!!!!!!!!!!! Any one seen this
    By dannyh in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2011, 14:05
  4. WOW WOW WOW!!! LED xenon lights
    By billywhizz1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2010, 19:00
  5. Eibach Pro's Fitted - Wow!
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2009, 00:37
