JBSVAG Check
Results 1 to 11 of 11
    Jan 2012
    Post Thanks / Like
    handling and wheels
    first id like to say hi to everyone as this is my first post
    ive just bought a 99 audi a3 20v this is my first audi a3 and im looking into getting the handling sorted ive already replaced the rear beam and dogbone mount with powerflex items as these two areas were most worn.my question is what is a good fast road setup i.e bushes,suspension,anti roll bars and best wheel and wheel spec etc (looking at lightweight wheel options not "scene" wheels lol)
    any help would be much apprciated
    aaron
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    792
    Post Thanks / Like
    Hello and welcome.
    Plenty of high powered A3 boys on here with lots of mods.
    I'm sure that their responses will be right around the corner. You might want to consider how much you wish to spend as many will recommend H&R/Bilsteins etc...which can be more expensive but you do essentially get what you pay for in this game.
    Personally, i lowered 20mm all around with a KW suspension kit, put spacers on (11mm front / 16mm back), added 18" RS6 Reps with Michelin PS3s, Forge adjustable Tie Bars (to ensure that camber wasn't too detrimental after lowering), H&R Anti-roll bars, powerflex bushes all around.
    My intention was fast road set up and certainly not track etc...which you will be able to tell by the kit i added as it's adding to the weight in essence of an already heavy car. I'm hoping my hybrid and new mani will ramp it back up again though.
    Good luck with your build!
    310bhp 295lb torque
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless exhaust, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Goodridge hoses, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest with cupholder & TT pedals.
    superkarl's Avatar
    MACH 9
    Mar 2010
    Southport, N west
    3,676
    Post Thanks / Like
    my setup is:
    fully polybushed
    19mm rear arb
    Ap coilovers (lowered about 25mm)
    18 x 8 inch wheels offsets are F:ET30, R:ET25
    LCR top mounts
    adjustable tie bars with geometry at:
    front camber 1.3 degrees
    front toe 0.02 out each side
    rear camber 0.5 degrees
    parallel rear toe
    plus everything (links, joints, ends etc) all replaced
    i consider my setup to be pretty well sorted, i wanted it for fast road and the odd track day.
    the only thing that lets my car down are the heavy wheels, which ironically probably make the most difference out of all the above modifications.
    superangry
    Jan 2012
    Post Thanks / Like
    thanks guys some great specs there, as its my first a3 im still learning ive had mk2 golfs for a long time so this is all new to me lol i want the a3 to be fast road car with the odd track day thrown in thanks again guys
    Jan 2012
    Post Thanks / Like
    which rear anti roll bar is everyone using
    superkarl's Avatar
    MACH 9
    Mar 2010
    Southport, N west
    3,676
    Post Thanks / Like
    well our cars are s3's. i use an R32 rear arb which is 19mm.
    but A3's, most;y being fwd use larger arbs.
    have a read of this, not a road car, but one hell of a setup!:
    Prawns A3 track car / Nurburgring toy
    superangry
    Jimgrim77's Avatar
    Nov 2011
    792
    Post Thanks / Like
    Quote Originally Posted by aaronmk2 View Post
    H&R on mine. They are big...Think they were 21mm. Sorted the handling and 4 wheel drive understeer out a treat.
    But like the previous post says...these are on s3s with the haldex 4 wheel drive system in situ and about 300kg of extra weight as a result.
    310bhp 295lb torque
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    824
    Post Thanks / Like
    I here the eibach from and rear roll bars are good aswell. I think you can get both for around 250ish. supposed to handle 10 times better
    Jimgrim77's Avatar
    Nov 2011
    792
    Post Thanks / Like
    Quote Originally Posted by Paradox1 View Post
    Agreed. Eibachs are impressive and very similar to the H&r ones.
    Body roll improvement is huge. Easy bolt on this for little expense.
    310bhp 295lb torque
    Feb 2011
    Newcastle upon Tyne
    60
    Post Thanks / Like
    +1 for eibach anti roll bar kit, they have transformed my S3. I'm after coilovers now to complete my setup.
    I'm a firm believer that tyre choice can make or destroy a cars handling, chose wisely and don't skimp out!
    Eibach anti roll bar kit, forge 007p diverter valve, Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses
    Jimgrim77's Avatar
    Nov 2011
    792
    Post Thanks / Like
    Quote Originally Posted by scotty_24 View Post
    That's music my ears! Ps3's all the way for me but better stick to the thread...
    310bhp 295lb torque
  1. Handling of and S3
    By DaveMK^ in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2008, 13:27
  2. SE handling
    By mfspen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st October 2007, 19:35
  3. S3 Handling
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2005, 21:59
  4. 19" wheels, ruin your handling?
    By pd130a4 in forum Handling
    Last Post: 24th November 2004, 16:31
  5. A3 Handling
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2003, 12:12
