Sky InsuranceChris Nott
Results 1 to 15 of 15
    Apr 2003
    s.wales
    363
    Glowing Turbo. Bad news ?
    Hi all, been playing with the map in my S3 and TBH is a lot better than it was. Reaches about 1.4 bar maximum, so I thought I'd adjust the actuator. Moved it in about four turns of the nut. Has much stronger mid range now but I think its lost a little at higher revs. Turbo is working quite hard and after a blast tonight for about 1.5-2 miles, flat out, the turbo and manifold were glowing bright orange.
    Is this a bit on the dangerous side, should I back it off a bit ? I'd expect it after a sustained blast, i.e 4-5 miles, but 2 ?
    Anyone had experience of this ?
    Chris.
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Re: Glowing Turbo. Bad news ?
    Mine glows red after I've been giving mine some boot and that is standard. So I wouldn't worry.
    You would probably benefit from an uprated intercooler though.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    I remember seeing a glow from around the turbo on my standard S3 after a long drive, don't think you even need to be going for it!
    Apr 2003
    s.wales
    363
    This was a blatt for about 2 miles. Was driving it very very hard though.
    Coming hard on boost at about 3500. Maybe turbo is working a bit too hard.
    Rich, Glen ? Advice appreciated.
    Chris.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Even running 1.8+ bar peak boost, mine only used to get a red glow out on the road...on the rollers it would go so orange i'm sure I could see the shaft through the casting!
    Personally, I'd be very wary of playing with the actuator rod length without doing some accurate measurememt of boost pressures, EGTs, A/F ratios etc...meaning a rolling road play about...
    PaulS3's Avatar
    UK
    988
    im with Glen on this one.
    Playing with the actuator rod is not the way to do it,
    A remap, is the way.
    The N75 valve is the valve that regulates the wastegate, its just a matter of remapping that to suit.
    Im sure i read that Audi dont touch the actuator at all, if anything comes loose or breaks, the replace the whole turbo assembly, as they come pre set.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Agreed... Asking for trouble is you ask me. It may well give you more power, but with logging AFR, boost .etc i would leave it well alone...a remap is by far the safest way of setting up the car.
    RIch
    Apr 2003
    s.wales
    363
    The same map was used on a LCR and got 1.5 bar peak and about 1.2 at around 6000rpm.
    Mine can only make 1.4 and 1.0 at 6000. Thought maybe this would help me hold it.
    Have turned it back out half of what I turned it in as the turbo was getting way too hot.
    Why do you think I can't sustain the boost ? Air leak ?
    Chris.
    imported_highlander1
    This is what a hot turbo looks like.
    http://www.abbottracing.com/2003/ima...02_testing.jpg
    Great car with a great engine. I'm biased though as I had one as my last car.
    Cheers,
    Deano.
    djjnrj
    i think you're 'loosing' boost because of the turbo on the S3. in standard form the S3's blower is excellent at lower and middle revs, but the small turbine wheel makes it difficult for the turbo to produce good boost figures at higher revs. i may be wrong.
    Apr 2003
    s.wales
    363
    Mates LCR produces constant 1.6 bar
    and the same code as mine in another LCR reaches 1.5.
    Don't think its a K04 thing, just my K04.
    Anyone think I should try a different N75 ?
    Chris.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    Constant 1.6 bar?
    Where?
    1.6 bar at the red line?
    I just can't see that...
    Or do you mean it constantly produces 1.6 bar peak...each time?
    The K04 can make big peak boost, but simply cannot produce big boost further up the rev range...the compressor is simply too small. Even if you rag the turbo to death, using re-maps, N75s, boost machines etc you still strugle to maintain 1.2+ bar at the top of the rev range.
    Certainly on standard ICs you can't run it there...the turbo gets so damn hot, the inlet charge temperature goes through the roof and the ECU retards the timing to protect the engine - making the engine loose performance. Not ideal.
    With modified turbo pipework, 2 x efficient ICs (including a FMIC), Samco Hoses, aggressive re-map and N75 you will struggle to get more than 1.2 to 1.3 bar held to peak power - and the K04 is absolutely flat out at that - way outside it's afficiency range.
    [ QUOTE ]
    [/ QUOTE ]
    Without logging EGTs, Inlet charge temps, IC efficiency, Timing, AF ratio etc...no I don't think you should try it.
    But, log all the pertinent parameters on a decent rolling road and convince yourself it's not going to damage the engine, and prove that you are getting a gain...fine, by all means try a different N75.
    But, you still may not be able to run an alternative N75 out on the road...it all depends on whether the limp mode activation point has been raised, or not.
    If it hasn't - or hasn't been raised enough - you hit limp mode out on the road.
    Changing the N75 on a re-mapped engine is not the best idea unless you are aware of what it's doing, and if your engine is able to cope. Just be wary.
    Apr 2003
    s.wales
    363
    Sorry, that was confusing of me.
    What I meant to say was a peak figure of 1.6 consistantly. Both the LCRs have 1.2 at @6000 , whereas mine can only keep 1.0 bar. Same map in all.
    What are the alternative N75s ?
    Chris.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    The 'H' or the 'J' - both being reffered to by the suffix on the part number.
    Apr 2003
    s.wales
    363
    And the difference between these two is what ?
    Chris.
