EM TuningRevo Technik
Results 1 to 35 of 35
    Pushing the limits..
    Jan 2011
    Australia
    269
    Post Thanks / Like
    Exclamation Oil level increasing and freaking me out urgent help need plllleeeaaase!!!!
    Hey guys, my S3 AMK's oil on the dip stick is increasing and i dont know why the oil isnt mikly, it has been changed two months ago, no black or white smoke but im worried ill blow my oil seals. i require some proffesional help as i really dont know what do to. i already spent 4000$ AUD on this baby to get my clutch DMS , water pump timming belt, and vanos all replaced allong with belt tensioner and idler. and im quite drain on $ atm. im thinking of buying some Motul 5w 40 exceed once again and change the oil to the correct level but i dont know what is cause this problem, i also have a air pocket in my coolant system which ill be fixing along with a new thermostat from Awesome. i dont know why its doing this guys please help ill upload picture of my dipstick at 2 intervals just so worried please help me
    Jan 2011
    Australia
    269
    Post Thanks / Like
    rThats on the 31/12/2001 around a month ago
    Thats today =[
    please any help would be great.
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    Checked in the same place each time? Left to stand for a good while before checking?
    I would change the oil or drop some out to be noticably under the max line, ( to me your almost over it on the first picture)
    Then keep and eye on it. Check maybe every week. Leaving the car over night before checking the level.
    Done under fill it, Be just above say half way, Dont drive like a loon and keep an eye on it.
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Nigger beater
    Miltek cat back exhaust
    3inch cock down my pipe and decat
    stage 2 shirt lifter
    Forge TIP , Boost hoses and DV
    3.8 bhp /40.7 torque
    huge cock on my head
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,839
    Post Thanks / Like
    You sure your not just checking them at different times?
    Ie some oil is still draining back from the cylinders/head etc?
    Or maybe the ground isnt flat?
    The only thing that it could be is fuel dilution, but you'd have to be running REALLY rich to cause any significant change in oil level.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    Jan 2011
    Australia
    269
    Post Thanks / Like
    i drive quite reasonable change on 2 to 2.5 rpm , there is no white or black some the car has power when i put the pedal down " on occasion" do you reckon i just change the oil but if so what would be the symptoms some told me either petrol or coolant , but i dont see the oil to be mikly as you can see in the picture
    Jan 2011
    Australia
    269
    Post Thanks / Like
    the ground is flat the car hasnt been turned on in over 40 hours, i use V power all the time too i dont know if thats any difference
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    "Bore Wash"?
    that would show real poor MPG would it not?
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Nigger beater
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    If it was coolant the oil would be grey and emulsified.
    I just cant see how you could get that much petrol into the oil on an engine that runs normally with no faults.
    Jan 2011
    Australia
    269
    Post Thanks / Like
    i dont think to my knowledge does it look grey but i can smell some petrol on the dipstick however was told it was normal not sure though, my only fault at the moment is that the idle is rough and the car vibrates esp on start up
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    The oil in your photos just looks golden brown to me?
    Oil and coolant mixed would look something like this: http://i27.photobucket.com/albums/c1...m/DSC01208.jpg
    scanned for any engine related fault codes with a vagcom lead?
    Jan 2011
    Australia
    269
    Post Thanks / Like
    yes i did , it told me i had low battery voltage, my o2 sensors need to change possible turbo temp sensor however that was plausible turned out to be fine allong with the battery , cause i disconnected the battery earlier to reset the ecu and faults.
    Jan 2011
    Australia
    269
    Post Thanks / Like
    any ideas as to why this oil level is increasing im quite baffled and looked at all the scenarios. My S3 is my pride and joy and hate to see such a problem with it. my only thought is the exhuast o2 sensors but again not sure. im so lost it aint fun
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    If those faults are still present then its entirely possible the engine will be running very rich and could explain the oil dilution.
    Did you fix the EGT and Lambda issues?
    Jan 2011
    Australia
    269
    Post Thanks / Like
    i have the lambda's at home ready to go on just dont know how to do it need to take it to mechanic although was told a 15min job each, but if i may ask a stupid quesiton sorry but what is an EGT ?
    many thanks for your help quite humble to be honest
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    exhaust gas temperature sensor, its stuck in the Turbo i think
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Jan 2011
    Australia
    269
    Post Thanks / Like
    ah okay , would that also be the problem ? i have the lambda's already cost be 180 pounds from awesome gti, but it seem that i need that too or should i replace the two o2 snesors on the exhaust and see how it goes or do it all once hit and service the haldex and engine ?
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    You really need to fix that EGT fault, as the engine will run extremely rich while its present.
  19. Thanks Sevv thanked for this post
  20. #18
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    when your EGT is playing up your ECU will dump fuel to keep the engine from breaking it self so you end up running super rich. Whats your fuel economy like?
    Alex S3 AMK
  21. #19
    Jan 2011
    Australia
    269
    Post Thanks / Like
    alright so that would be my only issue besides the o2 sensor after that she should be just fine im guessing ? just waiting on some more parts from awesome to come from the UK and ill book it in, in the mean time i wont drive it. also is it a big job to do it or is it something i can do on my own ?
  22. #20
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    Quote Originally Posted by Sevv View Post
    can you not source parts from Aus?
    btw an EGT sensor aint cheap either, sorry
    Alex S3 AMK
  23. #21
    Jan 2011
    Australia
    269
    Post Thanks / Like
    i loose quarter of my tank doing 47.2 miles roughly sometimes less
  24. #22
    Jan 2011
    Australia
    269
    Post Thanks / Like
    in Australia i think the EGT is around 500-600 AUD $$ from Audi dealership in the UK i think its 160 or 180 pounds i was told
  25. #23
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Mayonnaise people.....if you've got coolant - its mayo in the engine ( under the oil cap classic case )
    Did you by any chance put an engine flush / engine cleaner in before the car got drained? I only ask because the oil on the pic look alright, maybe its the shot, but personally - and i mean personally.....
    I would drain the oil out completly, and tick it over for 30 seconds. Then check to see what comes out.
    Marcus
  26. #24
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    , pretty **** then (~15 mpg)
    Alex S3 AMK
  27. #25
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    again,
    Alex S3 AMK
  28. #26
    Jan 2011
    Australia
    269
    Post Thanks / Like
    yeah ill try to go tomorow and buy som 5w 40 full syn oil, and no i dont do engine oil flush i was told it could F*** up the einge
  29. #27
    Jan 2011
    Australia
    269
    Post Thanks / Like
    Quote Originally Posted by Alex C View Post
    again,
    i agree but 160 pound is more like 220-250 AUD$$ some thing i can swallow to keep this baby happy
  30. #28
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    Quote Originally Posted by Alais DJA View Post
    lol, again,
    Alex S3 AMK
  31. #29
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    yeah i just worked that out, you pay about £350 for an EGT in Aus, wow...
    Alex S3 AMK
  32. Thanks Sevv thanked for this post
  33. #30
    bez101's Avatar
    Jul 2008
    3,403
    Post Thanks / Like
    realy id never start my car for 1 second with no oil
  34. #31
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    "Really"...
    Anywho, with a proper oil, all parts within the engine are "pregnated" with oil and lubricants while heated.
    30 seconds with a "drained tank" will not mean that your engine has no oil in it, it purely means there will only be a small amount in there (probably remaining on the parts ) - then add engine cleaner for 30 tick over, and empty....
    Saying that, looks like oil wasnt the problem after all.
  35. #32
    S3 Paul's Avatar
    Oct 2006
    2,154
    Post Thanks / Like
    Personaly i would never run an engine once i had dropped the oil.
    Just seems such a foolish thing to do,
    Yes in theory there would be no damage... but i will never do this as i quite like the oil pump to be sucking up oil whenever the engine is running
    I had the EGT and lambda faults on my S3 a few years back... I did the egt sensor first... it turned out i didnt need the lambda probes, The faulty EGT was making the car over fuel so much the lambda probes threw their teddys out of the pram
    Pink 2001 S3
    Brembo Stickers
    Koni coilovers
    Nigger beater
  36. #33
    "Stick a V8 in it!"
    11,839
    Post Thanks / Like
    Running with no oil is a bloody stupid idea.
  37. Likes Powelly liked this post
  38. #34
    Jan 2011
    Australia
    269
    Post Thanks / Like
    yeah no i wouldnt in a million years start my engine without oil as much as i do get Alais point. i dont have the balls to do that quite frankly. and yeah Alex its quite expensive here in australia i.e. 3000AUD $ for OEM clutch flywheel and labour which is over 2000 Pounds. and there are many many more. ill try to order the EGT this week or the next and get everything going smootly i hope
  39. #35
    Jan 2011
    Australia
    269
    Post Thanks / Like
    And i must say the response i got off all u lads was awesome honestly very thankful for all your help at least i know my problem now
    Hats Down
  1. oil level??
    By paulsb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2011, 18:33
  2. Oil level low warning light - what oil to buy, on xmas day?
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th December 2009, 11:32
  3. Oil Level
    By hodgy0_2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th August 2009, 20:58
  4. Increasing displacement ( increasing bore size)
    By emery1990 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2009, 17:32
  5. oil light dripping on ! oil level ok ??
    By AUDI@WRC in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th May 2008, 12:48
