Volks AutosJMB Retrofits
    imported_kennyf
    Coilover and air filter help.
    Just got the eibach coilovers fitted and the car looks higher??? They have had to set the rears at two difrent heights to get the car level. Wots really strange is that the standard suspension had a snapped spring and the car sat level then , any ideas???
    Plus the BMC filter just sukes in hot air from the engine bay , as they couldn't fit the ducting anyone else had this prob, would i be better reverting to OE filter or try and get the BMC more efficient.
    Help please [img]/ubbthreads/images/graemlins/mad.gif[/img]
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    Re: Coilover and air filter help.
    You shelled out your hard-earned cash for coilovers and a BMC CDA, and the shop didn't install either correctly!?! I'd be screaming bloody murder!
    Re: the coilovers, what type are they?
    Re: the CDA, the ducting to draw cold air is absolutely essential, it's what the whole thing is about. Figure that if they can't do it right, get a refund and take it to someone who can!
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Thats ridiculous.
    As for the coilovers... If the old spring had been snapped, then i guess over a period of time, the rear beam could have warped and found a new level...i dont know.
    BMC - A3 or S3? If its an A3 then the ducting will go down the side of the battery into the space behind the bumper...This will be the best place. if its an S3 then it will have to be fed through the inner wing.
    Rich
    Sep 2004
    Glasgow
    919
    kennyf - name and shame!!!
    imported_kennyf
    I've managed to improvise with the filter and adapt the supplied ducting to utilise the OE ducting as the "mouth" area is the same as the BMC , just a bit more oval .
    Took the car back in this morning to get the coilovers re-adjusted as it was half an inch lower on the offside reaer that the near side [img]/ubbthreads/images/graemlins/shocked.gif[/img]
    So hopefully all will be well when I collect .......
    Ian, it was Drivers that did the work. Ian was it ure S3 i seen outside Yates minus its wing mirrors one night a good few weeks ago?
    And folks thanks for the replies, might post some pics later for comments on my DIY filter and the final look of the coilovers.
