Forge MotorsportAWEsome GTI
    Feb 2012
    10
    Post Thanks / Like
    A3 Turbo Running Temp
    HI,
    Can anyone tell me roughly what temp an A3 Turbo should run at, Mine seems to run at 60 all the time only gets more when not moving.
    Sometimes it runs even less then 60, The heaters work fine and feel nice a warm.
    Is it low because its so cold out?
    Regards
    Jay
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    scummybrummie
    1,126
    Post Thanks / Like
    Its probley your stat or temp sensor dude, best bet is to get it on vag com
    2002 51plate Audi A3 1.8T sport AUM, Minger blue, xenon conversion, piano black recaros, forge 007p, jet ex filter, cold feed, silly tip. That's the good stuff listed
    Feb 2012
    10
    Post Thanks / Like
    Thanks mate, how much does it cost to get someone to put the vag on it?
    Do you know of anyone near Bristol that has it?
    Many thanks
    Nov 2010
    scummybrummie
    1,126
    Post Thanks / Like
    Ahhh mate your in for a treat, check out a place called badger5 enough said
    Feb 2012
    10
    Post Thanks / Like
    Sound job mate, Just looked them up Looks wicked, Will get in touch with them tomorrow.
    Thanks for the help much appreciated
  1. Running rich and temp
    By Shug1874 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2008, 14:24
  2. Running temp fluctuation.
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2008, 09:47
  3. Running Temp Issues
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2007, 19:15
  4. A4 TDI 110 running temp?
    By rob1380 in forum General Technical / How To
    Last Post: 4th July 2007, 17:20
  5. A-6 2.7T running temp???
    By Jims5543 in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 6th June 2004, 16:31
