EM TuningJMB Retrofits
Results 1 to 8 of 8
    imported_2219
    Standard alarm going off without siren!!
    alright guys, i was returning to my a3 the other day and noticed the indicators were going off without the sound of the siren?? i had left the windows down and alamed the car, im guessing the wind must off triggered off the senors within the car, any ideas would be most helpful, cheers.
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Re: Standard alarm going off without siren!!
    mine does this...
    as far as i know, the feature can be turned on or off by the dealership easily.
    imported_2219
    so you dont think theres anything wrong with it? any idea off how to turn this back on?
    Feb 2004
    331
    I don't know if this is the case .. but by law your car alarm is only allowed to continously go off for a set period of time before it has to stop ( house alarms have the same thing) which is why they continue to flash.. just to let you know something is a miss.
    Do you know that your alarm didn't go off.. or were you just not there at the time ?
    Aug 2003
    Surrey
    469
    I believe that indicators flash for a set period after the alarm siren stops.
    Stepho's Avatar
    Feb 2004
    Strathclyde
    445
    I had the same thing happen on my S3 a couple of months ago. My first thought was that the siren was gubbed, but after sitting inside and activating the alarm the siren worked fine. I have not had this problem for a while so I let it be.
    imported_2219
    ive also tested it by sitting in the cabin as stepho, im reluctant to take it to audi incase of it being an expensive job, just had to pay to change my gearbox and clutch!!
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Alarm should sound for a maximum of 30 seconds then re-arm the indicators should then flash untill the alarm is unset.
