Revo TechnikBadger5
Results 1 to 8 of 8
    Nov 2011
    Sturminster Newton
    131
    Post Thanks / Like
    007p or 008 help please?
    Hi all
    I am looking at buying a 007p valve but came across the 008 valve witch i think looks a bit better and apparantly works better aswell i was wondering if anyone could shed anylight on the performance.
    Forge Motorsport | Alloy Fabrication
    Im not after the load dump sound after a bit more performance as i plan on getting k04 turbo (with everything new manifolds injectors.....) so every bhp counts :P
    Graham
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
    Jan 2012
    Exeter
    Post Thanks / Like
    In all honesty mate just save the £13 and buy the 007p... it may not look as good but it will do
    exactly the same job.
    I can't see how the 008 can perform better when all they are is a pressure relief valve with a piston and a spring!
    The only reason i brought a 007p over a standard one is that i'm running a stage 2 s3 with quite a few mods..
    but for a standard k04 the standard bosch item is perfectly capable... and about £15 IIRC
    Rich
    Nov 2011
    Sturminster Newton
    131
    Post Thanks / Like
    Yea i know but after i obtain a k04 i intend on about 250 bhp.
    K04 won't be till after summer (my pay rise) Might start acccumalating parts tho such as b5 80mm TIP AEB manifold 3" or 2.75" full exhaust system, 380cc injectors and FMIC so i might aswell add a new DV to that aswell.
    Jan 2012
    Exeter
    Post Thanks / Like
    That sounds like some good mods planned mate..
    like i say the 007p will be fine and cheaper than the 008
    and i agree that you should start buying parts a bit at a time... cos its gets expensive trust me lol
    And i can't recommend the badger5 tip highly enough.. an esential mod IMO.
    Which exhaust and FMIC are you going for?
    Nov 2011
    Sturminster Newton
    131
    Post Thanks / Like
    Not sure on exhaust or FMIC yet as I haven't had a proper look yet im prolly going to budget max 500 each or 400 fmic 600 exhaust something like that.
    Im always open to sugestions for mods all ive ordered so far is some AP coilies S3 front and rear brakes and the parts for N249 delete will be doing all the work next weekend hopefully if not one day in the week after
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    792
    Post Thanks / Like
    Quote Originally Posted by Grazam View Post
    I'm running a lot more than all of that with the 007 in situ.
    Started a similar thread a few months back to the same response.
    The 007 is great and almost identical. 99% of people on here are running it. Save your cash.
    310bhp 295lb torque
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless exhaust, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Goodridge hoses, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest with cupholder & TT pedals.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    3,689
    Post Thanks / Like
    We still sell more of the 007P and it's more then good enough.
    Give me a shout if you need any prices.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    dan_gto's Avatar
    Dec 2009
    Portsmouth, uk
    27
    Post Thanks / Like
    agreed, buy the 007p.
  1. Forge 008 dv - anyone fitted/benefit?
    By Jimgrim77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2011, 11:14
  2. Replies: 22
    Last Post: 6th July 2010, 21:24
  3. Fault code 0287 008 / 012 ABS sensors- any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2010, 19:01
  4. Just got me a 007p
    By joshhatton in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 09:39
