UnicornBadger5
Results 1 to 7 of 7
    Feb 2012
    Post Thanks / Like
    Audi A3 1.8TQ, 2000 model, ABS light comes on once in a while..ideas?
    Hello,
    ABS light comes on after driving for a while. A guy with a code reader said it was intermittent error on the unit sensing motion change or something. I believe this is located on the ABS pump on drivers side, in engine bay. Am I right so far?
    WHat can I do with it in order to repair?
    Regards
    Boerge
    Apr 2011
    London, United Kingdom, United Kingdom
    101
    Post Thanks / Like
    theres a plug on the back of the fuse holder mine came out a lil and i've been having the same fault until this evening. just drove 20 miles and it has seem to fix it
    Feb 2012
    Post Thanks / Like
    Ok, thanks for info, I'll check that. Sorry for this Q, but do you mean fuse holder in engine bay or under steering column? Regards B.O
    Apr 2011
    101
    Post Thanks / Like
    fuse holder, theres like a plug i believe mine wasn't pushed in properly
    Feb 2012
    Post Thanks / Like
    Ok, checked the fuse holder (Left side of dashboard, behind cover), but it seems to me that the cabling goes straight into the fuse holder. No plugs that I could see there.
    I also tried to look (In the engine bay) for the ABS pump and the related electronics module, couldn't find that, although it was quite dark..
    Can anyone explain to me where the ABS pump and associated module can be found. This is a LHD car.
    Welly's Avatar
    8L S3 - Badger 5 Edition
    Aug 2009
    Gloucestershire
    10,175
    Post Thanks / Like
    Replace the 3 x 30 amp fuses on top of the battery - they are forever causing ABS lights for no reason and don't even have to be gone to do so...
    "When I held that gun in my hand, I felt a surge of power…like God must feel when he’s holding a gun."
    Homer Simpson
    Welly & Bumble
    FP Green - 445 BHP/328 LBFT
    Badger 5 Edition....
    Feb 2012
    bedfordshire
    147
    Post Thanks / Like
    Gonna give this ago then as I sometimes have my light come on
  1. 2000 S6 Avant - 70,000 miles ABS Light and ECP Lights coming on during acceleration
    By Des Carroll in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 10th April 2011, 20:33
  2. for sale section (audi s4 2000 model)
    By Allan mac in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th September 2008, 21:09
  3. 2000 AUdi A3 Facelift model....
    By jibbajabba in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2007, 08:31
  4. 2000 A3 1.8TQ - Underperforming
    By VaulterTim in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2006, 00:52
