Adrian S FluxEM Tuning
Results 1 to 7 of 7
    Dec 2011
    nottingham, uk
    100
    Post Thanks / Like
    must have the worst luck going!! overheating :(
    well i must be cursed!! had the car at c and r enterprises the other day to have my car vcds read....came back with a few fault codes and had the throttle reset. no other major codes realy. but taking the car home it felt like a new car, boosting right, not sluggish at all, nice and smooth! thought that my luck had changed for the better. but no i went to pick the missus up from town last night and took a steady drive (about 4 miles) everything seemed ok! then when we were quite litterally 100 meters from her door, the temp shot straight past 90 and i got three beeps, a red light on my dis and a yellow one on the top (for those who dont know, my dis screen is blank as clocks been tampered with by previous owner.) and then the coolant popped the tank cap and shot its load all over the bonnet and engine bay. i switched ignition off and rolled the car for the remainder....but just looking for an opinion of what it could be? any help would be great, im at my wits end now if im honest.....the a3's are lovely and id like to keep mine, i just think ive got a ringer of a car tbh....if its worst case scenario then engines aren't overly exspensive are they?! (agu)
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,002
    Post Thanks / Like
    Water pump stopped working so coolant wasn't circulating?
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
  4. Thanks argyle89 thanked for this post
  5. #3
    Dec 2011
    nottingham, uk
    100
    Post Thanks / Like
    possibly. my top rad hose was very hard if thats of any use?! just remembered.
  6. #4
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,002
    Post Thanks / Like
    Probably due to pressure. As coolant would of been boiling like a kettle. When was water pump last changed?
  7. #5
    Dec 2011
    nottingham, uk
    100
    Post Thanks / Like
    tbh mate, in the service book it says 104 thou. but my clocks have been tampered with and the engines on 200 thousand....previous owner sold it me saying it had only done 120k
  8. #6
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,002
    Post Thanks / Like
    I'd get a cambelt and water pump service done ASAP then if your unsure. Local indi Audi specialist should do that for £300
  9. Thanks argyle89 thanked for this post
  10. #7
    Dec 2011
    nottingham, uk
    100
    Post Thanks / Like
    yeah looking into it mate, been up to the car today, sorted coolant level out and started it up. no warning lights, but my fans didnt work, even with the blowers on in the car.....car runs fine, drive ok, so not got a clue....bloody wierdo german thing!
  1. If i didn't have bad luck I wouldn't have any luck!!!
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2011, 19:59
  2. Worst car luck EVER! new turbo fitted..car still has zero boost and white smoke!
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2011, 13:43
  3. Wish me luck
    By Matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2007, 12:45
  4. just my luck
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2007, 00:01
  5. Just my luck
    By batwad in forum General Chat
    Last Post: 25th January 2007, 20:30
