Badger5Forge Motorsport
Results 1 to 16 of 16
    rob irl tdi's Avatar
    Jul 2010
    239
    Post Thanks / Like
    s3 headlight washers not working
    I tried them a few times and every couple of goes i can hear a motor working. Dont think they pop up and they definately have no water spraying
    Did yours do this and how did you fix it
    2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,517
    Post Thanks / Like
    They only work after a few seconds of using the screen washers and don't come on if the temp is 5 degrees or lower
    <tuffty/>
    Silver 2001 AMK S3. Silver alcantara interior... now with added powarrrrrrrr, torques. VAGCOM + KII-USB.
    My build thread...
    Jul 2010
    239
    Post Thanks / Like
    What the motor i hear working then? Defo tried them for a few mins and its about 5 degrees
    2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,517
    Post Thanks / Like
    Quote Originally Posted by rob irl tdi View Post
    No idea.. the normal washer motor makes a noise...
    I assume you had the lights on too...
    <tuffty/>
    My build thread...
    Jul 2010
    239
    Post Thanks / Like
    Yea I had the lights on and nithing.
    What's the next step? Bumper removal?
    2001 S3
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    11,525
    Post Thanks / Like
    Yes it's a bumper off job,I had the same problem after the big freeze a while back,have you took the bumper off before ?
    Jul 2010
    239
    Post Thanks / Like
    No , only got the car. I have done mk4 golfs before
    Just to clarify they are defiantly not working and I can hear a motor and rear wiper wash isn't working
    Do the sprayers have to be incliped 1st. Before bumper removal?
    2001 S3
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    11,525
    Post Thanks / Like
    This is a rough guide - S3 Bumper removal ( I pressume the A3 is similar):
    1. Open the bonnet. There are 4 black plastic plugs, poke their centres through with a small driver and try to catch them. The plugs then lift out.
    2. There are about 3 or 4 screws in each of the inner front arch which need removing, they have a torx type head. Only remove the screws in the bumper vicinity.
    3. There are two larger bolt/screws on the bottom of the bumper about 12" each way of the centre and two screws in the bottom at each end of the bumper.
    4. The bumper then just pulls off relatively easily. If it doesn't come easily, you've probably missed a screw.
    5. Be sure to have a blanket or similar to rest the bumper on.
    You say your rears aren't working either though you do have to press the rears for a moment or two,I would keep it pressed to see if any fluid comes out before removing bumper.
    I guess there may be just water in there and it has frozen ?
    Jul 2010
    239
    Post Thanks / Like
    No because the windscreen wiper washers work
    Also do I have to unclog the bumper jets before removal?
    2001 S3
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    11,525
    Post Thanks / Like
    Once the bumpers removed you pull the cap up and unclip it and iirc two screws hold the jet in place,jets are 50 quid I think but hopefully it's just a blocked hose Rob
    Jul 2010
    239
    Post Thanks / Like
    Quote Originally Posted by voorhees View Post
    What caused your problem?
    2001 S3
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Jul 2010
    239
    Post Thanks / Like
    Cheers lads. Hopefully I can get them sorted
    The jets just work off pressure do they?
    2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,517
    Post Thanks / Like
    Yes... high pressure pump on the washer bottle... pressure forced the jets up out the bumper...
    <tuffty/>
    My build thread...
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    11,525
    Post Thanks / Like
    Mine was a broken jet which was brought on by carelessness,I didn't put additive in as I was busy and the water iced up and broke it.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    8,517
    Post Thanks / Like
    Process of elimination... check pump is working first... it makes a different noise to the washer pump and is noticeable... if the pump works then take the bumper off an check water is coming out of pipe at the joint, if it is then its gonna be a problem with the jets...
    <tuffty/>
    My build thread...
  1. front headlight washers not working
    By hank3944 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2011, 21:48
  2. Front and rear washer not working, but headlight washers are fine!
    By guinness in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 19:20
  3. Headlight washers not working
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th December 2007, 15:25
  4. Headlight Washers - stopped working
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2006, 13:28
  5. Headlight washers!
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2004, 02:20
