Originally Posted by
aragorn
Dont ever compare retrofitted HID's in some reflector headlamps with proper factory HID's.
Proper HID's have a very controlled beam that puts the light exactly where its supposed to go. Retrofit crap almost invariably doesnt. It scatters light all over the place. As a result yes you can see more, but the glare it causes then pisses off everyone coming the other way.
Its a bit like saying "I can see more with my main beam on, so i'll just drive around with that on all the time".
With a broken level sensor the height adjustment system winds the lamps right down as far as they will go, so you end up with a superbly lit area 3ft infront of the car, then darkness. Fixing it will make a huge difference.
