Backdraft MotorsportForge Motorsport
Results 1 to 7 of 7
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,013
    Post Thanks / Like
    temp problems again
    A3 is playing up again.
    i've replaced the sensor and the stat a while ago (cheap parts through a mate) been fine since i fitted them. apart from today the temp is not moving at all.
    got no fault codes.
    was thinking that the stat could be stuck open. i've got heat inside the car, not at hot as normal. coolant level is spot on the line.
    anyone else think it would be the stat stuck open ?
    Current mods
    Forge 007P, front mounted intercooler, smoothed airbox with jetex panel filter, boost gauge, wideband AFR, 312mm brakes, 3" downpipe/decat,straight thought, s/s backbox, stage 1 remap, coilovers, silicone TIP
    WantedS3 upper strut brace
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,709
    Post Thanks / Like
    you would still see some temp if the stat was stuck wide open
    red to red black to black blue to bits
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,013
    Post Thanks / Like
    instrument panel ?
    Current mods
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    642
    Post Thanks / Like
    Have u donee the 49c test to check both readings are matching?
    1.8T AGU / 18" Black BBS CH / Piper cross panel filter / Forge 007p DV / Matt white
    R-Tech stage 1 Remap / de cat / Facelift front & rear lights / Vogtland 35mm springs & shocks / 312mm front brakes / Toyo sport FMIC
    To do:
    3" Down pipe and de cat / K03s turbo and tip install / Cat Back exhaust system / Remap / Catch Can...
    Mar 2010
    424
    Post Thanks / Like
    If it was a thermostat stuck open the car would still warm up like normal at standstill and then as soon as you move drop down... is it doing this?
    James
    Now Silver Audi S3....fun in the snow (when it comes ! )
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    Gone Imola Yellow S3...
    and many many cars and bikes in the past!!
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,013
    Post Thanks / Like
    how do you do the 49C check?
    no, the temp gauge has no movement at all. checked for faults codes with the dials. reading no fault codes
    Current mods
    Mar 2010
    424
    Post Thanks / Like
    possible gauge,go into instruments with vcds go to output test and do a sweep test to check the cluster is working correctly
    James
  1. Temp Guage not working - coolant temp sensor changed... now what?
    By car4kids in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2012, 19:10
  2. Temp Sensor
    By taztam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st July 2011, 18:13
  3. Is the coolant temp sensor plug the same as the coolant temp sender?
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 07:54
  4. Brakelight sensor + collant temp sensor
    By womb raider in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2010, 21:38
  5. Outside temp sensor
    By A3.Lee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2009, 17:15
