W8 PerformanceAMD Technik
Results 1 to 11 of 11
    Sm3g's Avatar
    STANDARD S3 (225bhp)
    May 2009
    leeds
    48
    Post Thanks / Like
    Help needed please!!!! dodgy temperature reading
    HOPE YOU GUYS CAN SHED SOME LIGHT ON THIS PROBLEM THAT IM HAVING,
    the otherday i noticed the temperature guage in my 52reg s3,seemed to be just sat at 60 and not moving eventualy eml came on so garage down the road pluged diagnostic in and it came up with coolant temperature guage sender,so iv been to audi this morning and fitted a new sensor its a green one with 4 prongs,and when the car is moving its still just about sitting in between 60-70degrees,but if i stop and let the car tick over it then eventually goes as normal and just sits at 90.
    is it me going mad i know its -2 at the moment outside,but does this all seem normal????
    sideways steve's Avatar
    Dec 2011
    258
    Post Thanks / Like
    sounds like the thermostat is stuck open.
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    well i thought that,so i rang audi up,and they said that if there was a problem with the thermostat my heaters would blow cold,but heaters are ok and blow warm as per normal,but when i left the car ticking over and it reached 90degrees,i left it for just over 5min and the fan didnt kick in either????
    Dec 2011
    258
    Post Thanks / Like
    Thats a load of rubbish, if the stat is stuck open it will do exactly as you have said an you will still get hot air.
    My car blows hot air before the temp gauge has even moved when I leave for work in the morning.
    It is definately your stat, I had exactly the same issue on my A4 not so long ago. Also buy a genuine one, I have used ones from Euro and GSF a few times and they have been faulty from new.
    s3black's Avatar
    Aug 2011
    Scotland
    71
    Post Thanks / Like
    Im having this problem just now my friend. Changed sender and stat but didnt do the seal. Going to change it and see if it sorts the problem out. If not then it must just be chilly lol. At least yours reads 70 and not 60 haha
    SCOTLAND - Audi S3 2001
    Cat-back system, Coilovers, forge recirculating dump valve, stage one re-map.
    Back rolling on 17" Avus wheels
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    thanks mate,il bob out tomoz and get one from audi think there only a tenner,do you have any idea on how hard they are to fit mate,as id rather tackle it my self if its easy enough to do,rather than folk our a few quid in labour charges?
    s3black's Avatar
    Aug 2011
    Scotland
    71
    Post Thanks / Like
    Quote Originally Posted by Sm3g View Post
    Good man. I went about it by taking the intake manifold front / top plate off two screws (not the manifold) and then droping the altinator forward two long bolts (slip the belt off) this way i could access the thermostat housing (two bolts). Taken me about 45 mins all in and im not a mechanic lol. Get the new seal too as i didnt and have to do this all over again
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    thanks mate, i got one this morning from audi but when i said does it come with a new seal they said it dosnt list that you need a new seal with a new thermostat,so i dont know what to do for the best now as im going to get my local garage to fit this for me on monday?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,002
    Post Thanks / Like
    I didn't replace seal. Re-used mine and not had issues
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Sm3g's Avatar
    May 2009
    leeds
    48
    Post Thanks / Like
    thanks for all your help guys,rang a few garages up and they were quoting me 2.1/2 hours in labour thats £100,surely its not that much of a big job to do? S3 BLACK. thanks for your fitting advice i will print of how you said was the easiest way to change it and give it to the mechanic in the morning as im not up for getting ripped of and paying silly money for a job that can be done in half the time!!
    so in the meantime i think it would be rude not to go out now in the snow and put the 4wd quattro through some power slides
    Dec 2011
    89
    Post Thanks / Like
    I had this same problem, was the thermostat mate. It was not actually stuck open, it just opened too early, infact hot tap water opened it. Changed it and it sits at 90 all the time now.
    2.5 hours labour for a thermostat changing? No. more like 1.5 at most.
  1. Outside temperature reading
    By Smithymartyn in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2012, 10:21
  2. dodgy temp reading
    By iain audi a3 1.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2011, 13:35
  3. Temperature Reading
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2009, 21:23
  4. Dodgy temperature sender?
    By kohoutec in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2007, 15:35
  5. temperature gauge over reading?
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2005, 16:45
